3" lift to acomidate 33's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Street Jeep Forum > 3" lift to acomidate 33's
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-14-2013, 11:46 PM   #1
carlsonk27
I have a 2005'rubicon and am looking to lift it. I spend 99% of my time on the pavement but would like to start getting a little off the beatin path. I also want the lift to accommodate 33" tires. I am pretty sure with 3" I will need and want a suspension lift but their are so many of them out there I get easily confused. Do I want long arm or short arm? Will I need shocks?
carlsonk27 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2013, 09:07 AM   #2
biffgnar
biffgnar's Avatar
Go to the TJ Tech and use the search function. There will be thousands of threads where this topic has been beat to death.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-19-2013, 10:19 PM   #3
Trendsetter75
2010 JK Wrangler
Go with 3" Zone or BDS and 33's will fit perfectly. Good tires are Goodyear Duratracs. Short arm lift
2010 JKU (6-spd)
Trendsetter75 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2013, 10:38 PM   #4
TheLazyC
It will work...
Ken Currin
South Hill, VA
[COLOR="DarkRed"][B]2013 Jeep Wrangler Unlimited [/B][/COLOR]
Freedom Edition Oscar Mike Package
3" BDS Suspension Lift
Mickey Thompson 17"x9" Classic Lock Black wheels
Mickey Thompson 35X12.50R17LT Baja ATZ Radial
Mopar Running Boards
Mastercraft Sport Handles
Rugged Ridge A-Pillar POD
KC HiLite SlimLime-Driving
AEV PROCAL
TheLazyC is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 03:42 PM   #5
bfc4lulu
2 rough country will run 33 12.5 15.I've personally seen 6 tjs and look and drive great. it only comes with coils in shock so it's an easy installation but I don't think you'll have any problems whatsoever being A pavement pounder
bfc4lulu is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 12:46 AM   #6
Brass_Body
I'm very similar to carlsonk27, I want to raise my Jeep 3" to accommodate 33" 10.5" tires. 95% of the time I'm on the street but the other 5% I'm on rough and muddy dirt roads that get mangled in the spring with all the water but nothing I would consider Off-Road.
I've looked at the BDS 3" Jeep Wrangler TJ Suspension Lift Kit as was suggested above... the BDS site recommends "A steering stabilizer and fixed lower control arms are also recommended." Is this something I should consider?
Also, having read the details of the Kit, my understanding is that the ride should be noticeably smoother and better than the stock shocks I currently have... Is that correct?
Brass_Body is offline   Reply With Quote Quick reply to this message
