3.8L performance tuning help!! - JeepForum.com
post #1 of 17 Old 01-03-2009, 06:54 PM Thread Starter
cuminsmokethis
What would the best performaance chips and programmers be for a 2009 wrangler unlimtited 3.8L......... and how big of a horepower gain TIAthanks
cuminsmokethis is offline
post #2 of 17 Old 01-03-2009, 08:47 PM
jeep95xj
1995 XJ Cherokee
It's a mini van engine leave it alone
jeep95xj is offline
post #3 of 17 Old 01-03-2009, 09:04 PM Thread Starter
cuminsmokethis
So there is nothing you can do
post #4 of 17 Old 01-04-2009, 09:14 AM
qf4phlyer
qf4phlyer's Avatar
Hypertech programmer will be your best bet. Fill out your profile info, would be easier to help you, if we know what tranny, tires, gears ect.
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline
post #5 of 17 Old 01-04-2009, 03:09 PM Thread Starter
cuminsmokethis
So would an auto tranny be ok with that programmer or would the tranny slip
post #6 of 17 Old 01-18-2009, 06:13 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
too funny.
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #7 of 17 Old 01-19-2009, 12:46 PM
xJoshxx
2012 WK
i knew it was coming. inline 6's are so much better than v6's haha
xJoshxx is offline
post #8 of 17 Old 01-27-2009, 07:31 PM
tricked919
do a search in the JK forum... you'll find nada. Its all a waste - seriously. You're better off flushing your money.
Trying to tune a JK is like polishing a turd.
tricked919 is offline
post #9 of 17 Old 01-30-2009, 09:55 PM
leftlanetruckin
XJ on 37's
classic......
post #10 of 17 Old 01-30-2009, 10:16 PM
alexrule123
alexrule123's Avatar
They offer superchargers for the 3.8 and one company claims like over 100 more hp from it but it costs like $5k =( That would really be the only way to make decent power with the 3.8.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #11 of 17 Old 05-17-2009, 05:05 AM
Prot
Prot's Avatar
2014 JK Wrangler
Hesco, Avenger, and Ripp Mods all offer supercharger kits with varying results. The best bang for the buck in giving the JK more get up and go is to regear the differentials. The 3.8L has to rev to make power. It has the opposite power band of the 4.0L. The 4.0L makes power from idle to 2,500 rpm. The JK's power band starts at around 2,300 RPM and continues until it redlines. The redline on a 3.8L is higher than a 4.0L and the engine does not feel like it is going to shake itself to pieces when turning several thousand rpm's like the 4.0L does. That's why regearing works so well on a JK. 5.13's on 35's with an automatic gives an ideal ratio. With 35's and a manual transmission, 4.88's are more generally accepted as a better combination. The reason is because the manual transmission has a different overall ratio than the automatic. Ripp Mods unit is a clean install but leaves the air filter out in the open, subject to getting saturated with mud and water, but I think their system will accomodate a snorkel. Avenger's supercharger works more on the lower rpm's than ripp mods does, but requires cutting the hood and installing a goofy looking scoop. Most people don't want to do that, especially since the scoop that is available so far looks stupid. Then there is the Hesco, which is what I am leaning towards. It seems to have some of the best attributes of the previous mentioned two with none of the downsides of either. I'm still investigating it and have not made a decision on it.
And before someone chimes in and says 5.13 gears don't leave enough material and make the gears weak, research before you speak. JK axles and gears are stronger than previous models. People are running various displacements of hemis in JK's with stock D44 axles that have been regeared to 5.13 without a problem. As a matter of fact, people that running 37's on JK's usually run 5.38 gears. It just shows you how gearing is the key to JK performance.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #12 of 17 Old 01-09-2010, 08:12 PM
garmrshprd
2007 jeep engine mods
there is plenty you can do w/ a cold air intake like K&N or Banks, plus free flow exhaust w/mufflers and pipes. and if you are really motivated replace exhaust manifolds w/ headers. yes all this readily available for 3.8l v6. you'd be amazed at the power once you get all that air in and out efficiently.
garmrshprd is offline
post #13 of 17 Old 01-15-2010, 02:27 AM
archy333
Hmmm not sure bro !
archy333 is offline
post #14 of 17 Old 02-09-2010, 08:44 PM
GEM1N1
Heard of a lot of people going with the superchips programmer but it's pretty expensive and I'm not sure how much power you would actually get out of it. I considered doing a cat back but I really don't want an exhaust on a jeep that sounds silly going down the road. Does anyone know of a cat back that is quiet???
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
GEM1N1 is offline
post #15 of 17 Old 10-05-2012, 08:10 PM
Chem-E
JK Power
I actually had great results with the Superchip Vivid Link system. 0-30 went from 7 seconds to 4.2, 0-60 went from 22 seconds to 13. Plus I went from 15.2 MPG in town to 17.6 MPG in town. I currently have 35's with 3.73s but I plan on 4.88s.
Chem-E is offline
"Performance chips" OBD2 plug in fpr 4.O L6, jet performance, whats the deal? jamoka3 Audio, CB & Ham Radios, GPS, & Electrical 6 10-27-2009 11:35 AM
Tuning the I6 258 johnoverbaugh Engines & Drivetrain 2 09-30-2008 04:39 PM
Need Tuning Help Atari.fan3000 Audio, CB & Ham Radios, GPS, & Electrical 11 10-21-2005 09:11 AM
Tuning Flyusaf2002 Audio, CB & Ham Radios, GPS, & Electrical 10 03-26-2005 08:22 PM
cb tuning help hockeynhoots10 Audio, CB & Ham Radios, GPS, & Electrical 2 08-09-2004 09:12 PM
