2017 Wrangler Unlimited Winter Edition - JeepForum.com
 1Likes
  • 1 Post By AftonJeeper
post #1 of 11 Old 08-03-2017, 06:19 AM Thread Starter
BlownOne
Just bought a fully loaded granite Winter Edition for my fiancÚ two weeks ago from Dave Smith Motors in Idaho. It will be mostly used on the streets for daily purposes, but we will still go wheelin in it. I'll be doing a mild build on it keeping it on the oem plus side of things, which means just refining what it already has.
So far I've replaced the antenna with a black AntennaX 13" piece, interior lights, plate light and drl/front turn signals with 6k white leds. I have front fender smoked marker lights with white leds headed here tomorrow as well as a black stainless mesh grill insert. Juts tinted it yesterday with 5% around the rear and 35% on the driver/passenger fronts. Also, I'll be tinting the tail lights with vht night shades in the next day or two.
Stock bulb vs 6k Led bulb
Sent from my iPhone using TapaIlf
BlownOne is offline
post #2 of 11 Old 08-03-2017, 06:28 AM Thread Starter
BlownOne
I also couldn't stand the center brake light as it looks totally out of place, so I cut it off lol. It really cleans up the rear imo. I removed the spare, disconnected the wire harness from inside the rear door, removed the tire mount from the rig and cut it off near the base with a saw. Used my die grinder to round the edges of the cut and colored over the exposed aluminum with black. Cleaned it off and remounted everything. Pretty simple for anyone who wants to ditch the giraffe neck light hahaha.
BlownOne is offline
post #3 of 11 Old 08-03-2017, 06:43 AM Thread Starter
BlownOne
I also setup the rig for towing with a basic Reese 2" drop/ball with lock for the "max tow" package it came with. Usually we only tow my jet ski, but even that showed how underpowered these jeeps are and how their brakes could use some help, which brings me to my next mods. I'll be adding a Wilwood or Baer brake kit front/rear with steel braided lines to both make it look good and stop even better. As soon as she puts a few thousand miles on the clock then I'll be adding a Procharger P-1x to help this thing move out! All of my cars and toys are either supercharged or turbocharged, which explains my screen name lol.
Hitting the lake
BlownOne is offline
post #4 of 11 Old 08-03-2017, 10:21 AM
AftonJeeper
Registered
AftonJeeper's Avatar
Mopar makes a big brake kit for the JK, it's standard on export models. I stuck them on mine with a set of Black Magic pads. Here is the thread if your interested. I'm the only guy in our group that can lock up 35's on dry pavement.
BlownOne likes this.
97 TJ, 4.0 Auto and 3.07's
17 JKUR, 3.6 Auto with 4.10's
AftonJeeper is offline
post #5 of 11 Old 08-03-2017, 12:32 PM Thread Starter
BlownOne
Originally Posted by AftonJeeper View Post
Mopar makes a big brake kit for the JK, it's standard on export models. I stuck them on mine with a set of if your interested. I'm the only guy in our group that can lock up 35's on dry pavement.
I thought I saw some oem upgraded brakes on Jeep website when I was originally building it. They had a bunch of parts spread out and pictured next to jk. Thanks for the input...how much does the molar bbk run?
BlownOne is offline
post #6 of 11 Old 08-03-2017, 12:34 PM Thread Starter
BlownOne
Just checked out your link and it was $900 at the time you did it.
BlownOne is offline
post #7 of 11 Old 08-03-2017, 12:54 PM
AftonJeeper
Registered
I shopped around a bunch trying to get the best deal on it. Got the big brake kit for under 800, tossed the pads that came with it and put in the Black Magic pads. Ended up being on back order for 2 months and I wish I would have just ordered the kit from Black Magic and been done with it. Driving with 35s and stock brakes really sucked and pulling a trailer was plain stupid.
post #8 of 11 Old 08-03-2017, 04:35 PM Thread Starter
BlownOne
Yea I could see 35's making the underperforming brakes that much worse, especially towing. Thanks for the input brotha!
I'll try to keep this this thread updated with every mod I do to the jk...stay tuned!
BlownOne is offline
post #9 of 11 Old 08-05-2017, 12:09 AM Thread Starter
BlownOne
Swapped out the orange front fender marker lights with tinted white led's. Looks pretty close to the granite color during the day and matches the led headlights/turn signals at night.
BlownOne is offline
post #10 of 11 Old 08-05-2017, 05:48 PM Thread Starter
BlownOne
Got her a black "bling" plate frame so it's girly, but not too girly lol
BlownOne is offline
post #11 of 11 Old 09-20-2017, 11:51 AM
leavercm
2005 WK
Not that I am an expert, but 3rd brake lights have been mandatory since 1986 for cars and 1991 for trucks. It might take some time before you get stopped and cited. Worse will be if you get rear-ended. It could very likely become your fault for not having the legally required signalling.
First-time Jeep owner. Please bear with me!
05 WK Limited, 5.7L Hemi, QDII, 2" lift (Sold!)
leavercm is offline
