2.5L stroker? - JeepForum.com
post #1 of 22 Old 02-26-2007, 09:08 PM Thread Starter
Grey4.0L
1993 XJ Cherokee
2.5L stroker?
From what ive read the 2.5L is basicaly a 4.0 minus 2 cylinders, decreased stroke, and increased bore. So, could i use rods out of a 4.0 and make a stroker out of my 2.5?
93 XJ - 4" Lift, RC Control arm drop brackets / IRO Hack N Tap / 33x10.5 BFG KM2's mounted on 15x8 Cragar D's / Rear Locked / Adj Track bar / Aux transmission cooler / 99+ Intake Manifold / 703 Injector swap / Dynomax exhaust / Bushwacker Flares / KC HiLites / 136A alternator swap / JCR Winch bumper / Warn VR8000 / DirtBound Tire Carrier
Grey4.0L is offline
post #2 of 22 Old 02-27-2007, 04:33 AM
Rock Kustoms
Rock Kustoms's Avatar
rods dont change stroke
Rock Kustoms is offline
post #3 of 22 Old 02-27-2007, 06:08 AM Thread Starter
Grey4.0L
1993 XJ Cherokee
oh ok, yea i really didnt know, im not familiar with these engines at all.
Grey4.0L is offline
post #4 of 22 Old 02-27-2007, 10:52 AM
Gsmyth75
1992 XJ Cherokee
Jp magazine did an article on this, in the March 2007 edition on page 94 "Bag the Banger" They simulated one stroked 2.5L and it "wound up making something like 20 hp over the stock one at a ridiculously high rpm, low end torque was worse than factory at speeds below 4,000rpm also all the parts would be custom with mostly mallory metal to keep it from shaking itself to death", by the time he was done it was in the $4,000 - $5,000 dollar range. "The head doesnt really support any decent power levels anyway." They reccomended a turbocharger instead.
1992 Cherokee Laredo 4.0 L6, Aw4, Dana 30/35, Np242, 201k
Crower p/n 44243 Camshaft, Camsaver High Oiler Lifters, He Pistons .030 Over, Decked Block and MIlled Cylinder Head. Melling High Volume Oil Pump
Flowmaster Super 40/ Cat and Tailpipe Delete, Apn Header, Homebrew Bored Throttle Body, Rustys Cold Air Intake with Spacer
Gsmyth75 is offline
post #5 of 22 Old 02-27-2007, 09:21 PM
bigjohnson69
Changing the rods won't increase the stroke in any engine, it isn't just these engines.
bigjohnson69 is offline
post #6 of 22 Old 02-27-2007, 09:28 PM Thread Starter
Grey4.0L
1993 XJ Cherokee
lol forgive me for my stupidness.
Grey4.0L is offline
post #7 of 22 Old 02-28-2007, 07:13 AM
alexrule123
alexrule123's Avatar
hey, at least you asked a good question
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #8 of 22 Old 03-03-2007, 03:16 AM
hvac59
hvac59's Avatar
Here is some issues with the 2.5;
PROS; 350 lbs vs. 500+ for the 4.0
head work is a good bang for the buck
cams are available
engine compartment room is less of a problem
CONS; 9.3 compresion ratio stock inhibits boost level without a piston change
final power level is going to be about 45 % less than =$ spent on a 4.0
SUMMARY; If one starts a project with another engine on a stand it will be a ton easier. Given that, it can be done in the Jeep,but I would not recomend it. It would be a limited approach ending up with somewhere in the 180 hp range. This is without pulling the engine apart. I have heard reports of 200 hp being achieved and find that sceptical and preignition would be a big/constant issue! Now, If the engine is out and/or time is not a factor. Lower comp pistons, cam and some minor head work could give a big bang for the buck. Only to the effect of somewhere in the 220 to 240 hp range. I say only in respect to the 4.0 potential is a good bit higher. Although the 4.0 weight balance is going to be heavier on the front end(150+ lbs) and cooling issues will need to be adressed. Not so much on a 2.5 due to a 4.0 high capacity radiator is commonly available if not already there ! Is it worth it ? I think so if 220/240 hp is good enough for the need. It goes back to an old saying "Is the journey the goal or the end" This would be a rig with great everyday performance/mpg if kept light. Say less than 3000 lbs. It can be done. If a 6" lift is in mind and lots of armor or hittin' 13's at the strip, then just plain "forget about it" ,,,,,,ain't gonna make no one happy !!!!!!!!!!!!!!!!!!!!
hvac59
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline
post #9 of 22 Old 03-03-2007, 10:36 AM
Rock Kustoms
for a 2.5L id put in some good pistons that dropped the compression to 8.5:1 or so, run a nice EFI system, and about 20psi of boost. big injectors, and youll see well over 300 horse at the wheels
post #10 of 22 Old 04-12-2007, 11:20 AM
bob082484
You said there are other cams available. Ive been looking for a mild one but can only find one from Hesco. Other options?
bob082484 is offline
post #11 of 22 Old 04-14-2007, 06:25 AM
4.7stroker
Yes you will see 300hp for about one trip to redline and all of the oily bits will be sprayed all over the road in tiny little pieces.
Dwayne
4.7stroker is offline
post #12 of 22 Old 05-13-2007, 12:39 PM
BarracudaBlueXJ
Clifford performance makes cams for these engines and many other inlines. I f your old school like me they also have intakes for a 4 barrel carb, and they also list headers.
BarracudaBlueXJ is offline
post #13 of 22 Old 04-13-2010, 10:40 PM
kswyg001
2010 JK Wrangler
did this stroker 2.5 ever come out of idea stage and get built?
kswyg001 is offline
post #14 of 22 Old 04-22-2010, 10:26 AM
silver60th
An all the thread stalking I have been doing over the years, I haven't seen it done.
Just googled it with little results, although I have seen some people mention that they
have seen a 2.7L done. But, that's one of those "a friend has a friend that knows a guy
that saw a guy on a forum do it".
.: Avenger Superchargers :.
A 30-percent Increase in Power and Torque?
Sorry I couldn't be more help. At this time, that may be more viable.
silver60th is offline
post #15 of 22 Old 06-27-2011, 10:56 PM
Trenton
Hey everyone,
im new here, i wouldve made a new thread but wasnt sure how to??
anyway i just have a question regarding all the 2.5 posts...
why do ppl say its so slow and under powered?
Now i own a Dakota, not a Jeep. but since its the same engine and its more
popular in the jeeps i figured this would be the better site. I know the jeep and the dakota
are two total different machines but for a 4 banger truck it moves great. the mods i have done include
cold air intake, headers, downpipe, flowmaster 40, electric fan, and lower temp thermostat. i also have a
4.0 TB i have not put on yet and a set of perf. plugs, wires, dist. etc. Its also fairly peppy.
some of the vehicles i have won against in a race are 79 400 ranger, 97 dodge ram, 04 chrysler 300, 94 s10,
honda civic, etc. i also suprisingly won against my friends 09 warrior 350 4wheeler, me and him both thought
i would get smoked. I did not over exhagerate, the cloesest of them all was the 300 chrysler because i only can
win until about 80mph(when i shift to 4th he passes). anyway point of the post is im just tryin to figure
out why ppl dog the 2.5l so much?? and if anyone has any ideas or tips for my truck feel free to let me know. thanks
Trenton is offline
$800 4.5L stroker RockRodHooligan Engines & Drivetrain 20 09-12-2008 09:53 AM
4.6L Stroker Anyone? mpala96 Engines & Drivetrain 3 06-30-2006 05:42 PM
stroker kit whitemonster Engines & Drivetrain 2 05-24-2006 03:41 PM
Stroker drewguere Engines & Drivetrain 1 10-03-2005 07:40 PM
