1988 Cherokee Laredo ( my first Jeep ) - JeepForum.com
post #1 of 2 Old 01-10-2014, 11:13 AM Thread Starter
RichieSpark67
1988 XJ Cherokee
Does any body know what the approximate 2" diameter hose with metal wire warped around it the entire length is? It's located under neath the air filter housing but I only see one end hooked up, the other end is just laying against the motor.
Thanks
Richiespark67
RichieSpark67 is offline
post #2 of 2 Old 01-18-2014, 10:56 PM
olliehopnoodle
1982 FSJ Cherokee
I is probably used to duct air that has been blow over the exhaust manifold into the air cleaner. This was used to warm up the engine a little faster. Once the engine warms up there is a butterfly valve that will close and block off the duct.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
