Zone 4.5 on 30" tires? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Zone 4.5 on 30" tires?
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 11-25-2015, 12:14 PM   #1
Azzy
I was looking at their 3, but it doesn't come with the LCAs, and I got this track br and a set of bumpers... which, it will end up probably at 3.5"
But, how off will that look? Got a set of 30x9.5x15's sitting waiting to be mounted in the shed.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 01:42 PM   #2
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
I'm guessing slightly smaller than 31s would look...
| Project Motörcharge 2.0 - MJ | June 2015 COTM |
Motorcharge is online now   Reply With Quote Quick reply to this message
Unread 11-25-2015, 01:59 PM   #3
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
http://www.jeepforum.com/forum/f11/x...v2-0-a-983075/
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 11-27-2015, 06:34 PM   #4
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Tires larger than 30x9.5 start loosing road manners pretty quickly, but I'm afraid they'll look pretty tiny under 4.5" of lift. 3.5" is probably the upper limit.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is offline   Reply With Quote Quick reply to this message
Unread 11-30-2015, 08:38 AM   #5
Azzy
My main concern is a quick sagging lift with bumpers and rear quarter armor, and a small cage inside (roof mod, cage needed). My 3.5 I had at one point ended up being 2" after a year and a pair of bumpers.
Unread 11-30-2015, 10:53 AM   #6
nolanbalzarini
nolanbalzarini's Avatar
my re 3.5 kit is just now at 3.5 (started around 4.24) after 6 years and about 1000 pounds
Cherokee Of The Month. September 2015
nolanbalzarini is online now   Reply With Quote Quick reply to this message
Unread 11-30-2015, 11:31 AM   #7
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
That has more to do with coil and spring rates, do research into the different lift companies and their rates. The stiffer the spring, the less it will sag, but the harder it will ride.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
