Zips 2.0 my 98 - Page 52 - JeepForum.com
post #766 of 1644 Old 02-11-2014, 06:04 AM
DNFJ
thats dumb
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #767 of 1644 Old 02-13-2014, 08:09 PM Thread Starter
Luke95
Turd jeep hasn't done jack ****.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #768 of 1644 Old 02-24-2014, 07:39 PM Thread Starter
Luke95
Sold my 30...
Luke95 is offline
post #769 of 1644 Old 02-24-2014, 08:18 PM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
Originally Posted by Luke95 View Post
Sold my 30...
How much did you get for it?
koolaid5 is offline
post #770 of 1644 Old 02-24-2014, 08:33 PM Thread Starter
Luke95
250
Luke95 is offline
post #771 of 1644 Old 02-24-2014, 08:38 PM
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
What were the specs on it? Regeared, locker???? I looked back a few pages to find out, but gave up. I can't keep my attention on one thing that long and I am easily distracted by shiny objects.
koolaid5 is offline
post #772 of 1644 Old 02-24-2014, 08:41 PM Thread Starter
Luke95
Stock zj steering and a spare set f shafts lol. And yes dana 44 swap is a nice distraction.
Debating compacting my thread down
Luke95 is offline
post #773 of 1644 Old 03-02-2014, 08:42 AM Thread Starter
Luke95
Guys I need help.
I don't know if it is the winter being a bit of a trouble maker or what. But here goes 1 I need to do shock hoops I ordered some but the order got canceled. So of I were to plate the uniframe and do ford shock hoops is that me being stupid? It looks like it would work great they would be welded to the frame plates.
Second spare tire problems how do you guys on over 33s mount it?
Third tires: my current plan is to run my 34 swampers till they are dead then I don't know if I want to go to 35 cooper stts or perhaps some 36 iroks or the new falken mt.
Forth I will have my rear axle out of the truck for gearing so I'm tempted to make a truss for it. And either run a traction bar or start a rear 4 link. Because I'm getting wicked axle wrap.
Fifth I'm debating bumping it to 4.5 inches of lift. Pros cons?
6th I'm debating flat skidding it with a steel crossmember then doing a plastic skid like nick did.
And as far as my actual build goes I am working on my axle swap I just need the spindle. I have also fixed my frame up a bit and started gathering some metal for stiffies.
Luke95 is offline
post #774 of 1644 Old 03-06-2014, 05:04 AM
DNFJ
If you're going to run 34s you might as well just stick to what you have until you can jump completely to 35s or 36 IROKs, in which case how exactly do you plan on mounting it? To a bumper? Throwing it in the back of the jeep?
Why can't you get XJ shock hoops? Either way, I personally think plating the frame is the way to go before putting on hoops.
Figure out what's causing your axle wrap, because it isn't necessarily something with how the axle is secured, but potentially something slightly loose or off in the whole rear suspension or driveline for that matter. How do you know it's so bad?
1.5" is a good height, only thing is getting a SYE (dont remember if you have one)
Flat belly is cool, but you have to be careful because you have to clock the t-case and redrill it, if you mess it up it's going to leak forever. Read ibj's guide on a flat belly XJ.
Previous:
DNFJ is offline
post #775 of 1644 Old 03-07-2014, 02:45 PM Thread Starter
Luke95
So I'm thinking about it. Axle wraps do to shot leafs. And you can feel it binding when you get on it.
Figured I'd update this crap build...
Debating a Isuzu corp 12 bolt 1.5 inch axle shafts and a 9.6 inch ring gear comes with 4.56s and disks just needs to be welded. Both in terms of perches and the spiders. Unless its a LSD in that case I may leave it but hey for 45 bucks I won't complain. It is either 58 or 63 WMS so it is possibly going to need spacers I think I'm going to stay on leafs for now. It is a 3rd member style axle so that is a plus and it also is cheap at junk yards. If I do gernade it another 4.56 third is 100 at the yard. Now do I drill it and the rotors to 5 lug like my front or just rock two different lug patters for now?
Luke95 is offline
post #776 of 1644 Old 03-07-2014, 05:19 PM
green97xjsport
1997 XJ Cherokee
Most third members are pretty tough, different lug patterns mean different rims, always looks a little hokey
,======o00o.
/__||_l__l,\___\,___
l_--\__\__l_---[]llllll[]
_(o))_____(o))--o-))
green97xjsport is offline
post #777 of 1644 Old 03-07-2014, 06:13 PM Thread Starter
Luke95
Same d window rims just one more lug nut per rim Is the plan
Luke95 is offline
post #778 of 1644 Old 03-07-2014, 08:05 PM
VegasGT
1988 MJ Comanche
Less talk more progress!! Jesus youre like the President. .!..!.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #779 of 1644 Old 03-07-2014, 08:25 PM Thread Starter
Luke95
Don't you have a couch to fornicate with? .!..!.
Work is coming tomorrow!
Luke95 is offline
post #780 of 1644 Old 03-08-2014, 05:51 AM
ibjeepin95
No ****. Just put something together and wheel it. I don't get on here and ask these newbs 1000 questions before I do something to mine. What are they going to do, tell me to put angry eyes on it? That will definitely help it wheel better!
ibjeepin95 is offline
boost
