Zips 2.0 my 98 - Page 28 - JeepForum.com
post #406 of 1644 Old 08-04-2013, 10:59 PM
Moose340
It will in duh time
Non timebo mala
Check out my build
Moose340 is offline
post #407 of 1644 Old 08-04-2013, 11:05 PM Thread Starter
Luke95
So with the rubicon your lockers only work in 4 lo?
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #408 of 1644 Old 08-05-2013, 07:34 AM
Moose340
That would be correct sir and only under 10 mph but you can bypass the the switch and do at any speed any t-case position
Non timebo mala
Check out my build
Moose340 is offline
post #409 of 1644 Old 08-05-2013, 08:42 AM Thread Starter
Luke95
Hmmmm.... I'm feeling stupid now.
Wrecked rubicon up the street
D44 and a toy 8 inch.....
I <3 rockrash
Luke95 is offline
post #410 of 1644 Old 08-05-2013, 10:19 AM
Moose340
I <3 rockrash
Go steal stuff!
Non timebo mala
Check out my build
Moose340 is offline
post #411 of 1644 Old 08-05-2013, 10:49 AM Thread Starter
Luke95
Go steal stuff!
Will do later
I <3 rockrash
Luke95 is offline
post #412 of 1644 Old 08-05-2013, 09:47 PM
Moose340
Will do later
I <3 rockrash
Right meow!
Non timebo mala
Check out my build
Moose340 is offline
post #413 of 1644 Old 08-07-2013, 04:07 PM Thread Starter
Luke95
**** you centering pin
I had wanted to rebuild the pack I guess it's time....
Avoid rubicon express centering pins. Mine were properly torqued and installed as were the u bolts thoughs are fine.
Time for tons.
I <3 rockrash
Luke95 is offline
post #414 of 1644 Old 08-07-2013, 09:41 PM Thread Starter
Luke95
Forgot to add, I got clayton lowers without a jj I'm thinking metalcloak duraflex joints for them
Saturday I'm looking for a rear axle at the yard.
I <3 rockrash
Luke95 is offline
post #415 of 1644 Old 08-08-2013, 11:04 AM
ibjeepin95
Time for tons.
I <3 rockrash
Tons won't fix a centering pin...
ibjeepin95 is offline
post #416 of 1644 Old 08-08-2013, 11:18 AM Thread Starter
Luke95
They will.
Along with new leaf packs. And grade 8 pins.
I <3 rockrash
Luke95 is offline
post #417 of 1644 Old 08-08-2013, 11:41 AM
ibjeepin95
They will.
I <3 rockrash
You haven't wheeled hard enough chit to justify tons! You're just having some bad luck dude.
post #418 of 1644 Old 08-08-2013, 12:12 PM Thread Starter
Luke95
I guess
Tearing into it last night I found out I need a new axle shaft.... 8.25 bent the splines on my right shaft.
I <3 rockrash
Luke95 is offline
post #419 of 1644 Old 08-09-2013, 04:59 PM Thread Starter
Luke95
My jeeps back on her own weight but...need to redo my rear brake line it was almost wet to the touch.
I <3 rockrash
Luke95 is offline
post #420 of 1644 Old 08-09-2013, 10:16 PM
Moose340
I <3 rockrash
Tee hee.......wet
Non timebo mala
Check out my build
Moose340 is offline
boost
