Zips 2.0 my 98 - Page 2 - JeepForum.com
post #16 of 1644 Old 04-11-2013, 05:17 AM Thread Starter
Luke95
Originally Posted by DNFJ
HP30 and 8.25? You can run 35s no problem
16.5 rims so nah.... To much $$$ to get the rims I'd need
Booooooobbbbbsssss
Sent from my black box
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #17 of 1644 Old 04-11-2013, 05:41 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Booooooobbbbbsssss
Cragers are 55 bucks a piece?
also I like dis.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #18 of 1644 Old 04-11-2013, 05:58 AM Thread Starter
Luke95
also I like dis.
Find me a 16.5 rim with a 5x4.5 pattern XD
And yez amazing
Luke95 is offline
post #19 of 1644 Old 04-11-2013, 06:02 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
And yez amazing
Why does it have to be 16.5?
Previous:
DNFJ is offline
post #20 of 1644 Old 04-11-2013, 07:04 AM Thread Starter
Luke95
That's what thoughs boggers were....
I'm debating these tires right now
32x11.5 is more aggressive
33x12.5 bigger ad less aggressive
Luke95 is offline
post #21 of 1644 Old 04-11-2013, 07:46 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
I have never heard of a 16 1/2" wheel. How does that even work?
Previous:
DNFJ is offline
post #22 of 1644 Old 04-11-2013, 08:36 AM Thread Starter
Luke95
Not very well it's a old Chevy size
The tires I posted are for a 16 inch rim
Luke95 is offline
post #23 of 1644 Old 04-11-2013, 08:42 AM
whitexj98
So Why not buy cheap 15 inch steel wheels, there are tons of tires that will fit...
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #24 of 1644 Old 04-11-2013, 08:43 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
OTK/1-ton steering needs 16" wheels with 3.75" bs.
Previous:
DNFJ is offline
post #25 of 1644 Old 04-11-2013, 09:00 AM Thread Starter
Luke95
What he said XD
Views on thoughs two tires?
Luke95 is offline
post #26 of 1644 Old 04-11-2013, 09:16 AM
whitexj98
It would clear under the knuckle with 15s. OTK requires cutting off sway bars, relocating the track bar, trimming the coil buckets and will also hit aftermarket diff covers oh and the dead spot in the steering but that applies to over and under.
I guess what Im getting at is there is much better steering options that dont need a more expensive tire and wheel combo.
post #27 of 1644 Old 04-11-2013, 12:01 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
And when you get into WJ knuckle swaps and etc you will lose that, even with the spacer welded on, personally I would rather have the extra clearance just incase something did happen: for instance without properly BS'd wheels running OTK you barely clear (if at all, depending on which set up you run), if you're on the trail and you bend or brake your tie rod, that 15" wheel is going to eat it if you don't react correctly.
You're right though, I wouldn't make 16" wheels (or larger) a priority at the moment if I was him, though it wouldn't hurt to look into ordering them one at a time or so and building them up for the proper set up while still maintaining the best money spent:usefulness ratio.
Previous:
DNFJ is offline
post #28 of 1644 Old 04-11-2013, 04:25 PM Thread Starter
Luke95
The 16s are to help me cheap out....
https://www.treadwright.com/p-113-26...rax-m-t-d.aspx
or
https://www.treadwright.com/p-115-28...m-t-b2b-d.aspx
Im working on that whole money to usefullness gap thingg.....
Im now looking at maybe working with clayton, I need a job and I heard they are in need of some help.... But if not I have 2 other people to look to.
Luke95 is offline
post #29 of 1644 Old 04-11-2013, 04:31 PM
ibjeepin95
I'd be so jealous if you got a job with Clayton...
ibjeepin95 is offline
post #30 of 1644 Old 04-11-2013, 06:27 PM Thread Starter
Luke95
Why? It's just another lathe or miller to me....
But it would be nice!
Luke95 is offline
boost
