Zips 2.0 my 98 - Page 10 - JeepForum.com
post #136 of 1644 Old 05-16-2013, 08:27 PM Thread Starter
Luke95
I want more droop, idears?
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #137 of 1644 Old 05-17-2013, 04:14 AM
DNFJ
longer shocks
long arms
longer brake lines
quick discos
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #138 of 1644 Old 05-17-2013, 04:25 AM Thread Starter
Luke95
Originally Posted by DNFJ
longer shocks
long arms
longer brake lines
quick discos
No sway bar
Long brake lines
Long arms I dunno if I want them yet
10 inch shocks are the most I can fit with my bpe
Luke95 is offline
post #139 of 1644 Old 05-17-2013, 05:36 AM
DNFJ
Originally Posted by Luke95 View Post
No sway bar
Long brake lines
bpe?
also get control arm drop brackets then
Previous:
DNFJ is offline
post #140 of 1644 Old 05-17-2013, 05:41 AM
ibjeepin95
bpe?
Skip the db's at your height. Get control arms with JJ's at each end. Make sure you are actually using your shock completely up. As in, at full bump, make sure there is almost no shock shaft left. Also, trim your lower shock mounts so the CA will clear it. Bump stop correctly. Get a double shear track bar. Get crossover steering. I could keep going....
ibjeepin95 is offline
post #141 of 1644 Old 05-17-2013, 05:54 AM
DNFJ
DB are still a good idea, even with adjustable control arms.
Previous:
DNFJ is offline
post #142 of 1644 Old 05-17-2013, 06:01 AM
VegasGT
1988 MJ Comanche
You still running stock LCA's?
Edit: nvm, ibjeepin95 has you covered pretty well up there ^
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #143 of 1644 Old 05-17-2013, 08:17 AM Thread Starter
Luke95
I have a double shear tb
Would Hiems work?
I haven't maxed out a shock
I'm bump stopping with a reasonable fender trim to keep them happy
Cross over steering I'm debating Hiems vs 1 ton
Luke95 is offline
post #144 of 1644 Old 05-17-2013, 09:47 AM
ibjeepin95
Would Hiems work?
Are you asking if Heims would work on a CA? If that's your question, then ye answer is yes. As for steering, what do you mean "Heims vs. 1 ton"? You can run Heims on most any setup, including a 1 ton setup. That's what I run.
post #145 of 1644 Old 05-17-2013, 09:53 AM
DNFJ
Since we're all asking.
ibjeepin, my XJ will never see over 35s, what steering set up should I run?
Previous:
DNFJ is offline
post #146 of 1644 Old 05-17-2013, 10:07 AM
ibjeepin95
I'd suggest running upgraded steering on anything over 31's honestly. I've seen an XJ bend a stock tie rod on 32s like it was made of rubber. When it comes to what setup to run, I'd suggest a complete setup that includes a tie rod and drag link, just because once you upgrade one of them, the stronger of the two will end up bending whichever item you left stock. If you want a stock feel but want strength, go Currie. I run the IRO kit and I like it, but it's cross over, not an inverted Y setup like stock. It also runs heims, not TRE's. Some people are against Heims on steering, but I'm not sure why. I like them, though though can get noisy. I'd just suggest to stay away from a an inverted T setup. I ran one once and I hated how it felt. Too much tie rod roll.
post #147 of 1644 Old 05-17-2013, 10:16 AM
DNFJ
So like this set up? http://www.currieenterprises.com/ces...t.aspx?id=1219 (I've eyed it in the past)
I've also thought about this one: http://www.ironrockoffroad.com/Merch...Category_Code=
Which would be better? (If you remember right, my XJ is expedition/overlanding and not strictly crawling)
Previous:
DNFJ is offline
post #148 of 1644 Old 05-17-2013, 02:29 PM Thread Starter
Luke95
I am thinking of a v8 tie rod for now
But am wondering how bad would dual Hiems be for a dd on control arms?
Luke95 is offline
post #149 of 1644 Old 05-17-2013, 07:34 PM
ibjeepin95
Yeah, no on the V8 tie rod. I've never ran it, but there is a thread in NAXJA now where guys are saying it's far from an upgrade, it's just merely an improvement from stock. Main reason being that it has a huge bend in it and that it makes it vulnerable to bending.
I say go for it on the heims. Look at most all 3 link/4 link builds on NAXJA or Pirate. They all run heims on both ends. What's the difference with a stock short arm setup? It's still a TRUE 4 link. Hell, still better than a radius arm . I see no problem.
post #150 of 1644 Old 05-17-2013, 09:16 PM Thread Starter
Luke95
Touché
I am not complaining on flex but want some better droop
I think your right and it should be decent.
I need some long term ideas.
Wj swap idk
8.25 disk hell yes
Turbo is going good so far, few things then ill start.
I dunno what else besides the hiem steering and control arms
Luke95 is offline
boost
