you know you drive an XJ when.. - Page 444 - JeepForum.com
 17Likes
post #6646 of 8115 Old 05-05-2013, 12:02 AM
Livin2xs
Originally Posted by 00XJMikey
Your phone's browser history contains nothing but "how to" links. Lol. Did fix my window switch lock problem.
X2 was just sayin that the other day, nothing but jeep cherokee in my Internet history haha
Livin2xs is offline
post #6647 of 8115 Old 05-05-2013, 12:43 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Makes a good contact list.
D3<!L!>3D
S8NNG8 is offline
post #6648 of 8115 Old 05-05-2013, 01:39 AM
Puck81
When you wheel it for 15 hours streight, have lots more damage, and it STILL gets you home with no issues.
Puck81 is offline
post #6649 of 8115 Old 05-05-2013, 03:00 PM
misfit4lo
When the trees have crushed the body past the point of recognition and it just makes it stronger.
misfit4lo is offline
post #6650 of 8115 Old 05-06-2013, 11:28 AM
Abowers
When you look on the passenger floor and theirs an inch of water in it... I Think it's the door seal
Abowers is offline
post #6651 of 8115 Old 05-06-2013, 11:59 AM
BlueBadger
Originally Posted by S8NNG8
I may have a lot of crazy *** ideas, but I do hold function over form. The plastic entry plates have a specific thickness to aid the lame door hinges, and keep the catch pin lined up. If your dp plates are a single flat cover plate, they wouldn't aid the sagging doors on a 2 dr until it is too late. And, nobody would want the dp scratching to hell out of the bottom of the door anyways. Comments on this thought?
Sounds good in theory. I'm at 1/8" flat plate with a 1/2" lip bent 90* down. Very simple.
BlueBadger is offline
post #6652 of 8115 Old 05-06-2013, 12:33 PM
Krikkit
When both front windows are attached to their regulators by picture frame wire.
When you are taking your phone out of your pocket while driving at night and accidentally turn off your headlights
When indicating a turn your hazards come on
You own cat litter, but no cat
You look surprised when you pass inspection
Your front fenders are at least three different shades of green
If you borrow your Mom's car when you have to go more than 30 miles
You turn on your nav lights with the top of your head every time you get in
The last picture you have of it, it is on the back of a tow truck.
Krikkit is offline
post #6653 of 8115 Old 05-06-2013, 05:25 PM
rebelbowtie
None of these apply to my XJ
rebelbowtie is offline
post #6654 of 8115 Old 05-06-2013, 07:11 PM
Steelo805
X2. Lol
Steelo805 is offline
post #6655 of 8115 Old 05-06-2013, 08:44 PM
Luke95
When you break rear shock mounts like no tomorrow.
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #6656 of 8115 Old 05-06-2013, 08:49 PM
Hudson
Make stronger ones!
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #6657 of 8115 Old 05-06-2013, 09:48 PM
Livin2xs
Every Monday you're replacing something ou broke on the weekend
Livin2xs is offline
post #6658 of 8115 Old 05-06-2013, 11:33 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
...when you don't want to pull the motor for the new motor mounts until you can afford the rebuild, and the header.
D3<!L!>3D
S8NNG8 is offline
post #6659 of 8115 Old 05-07-2013, 02:34 AM
Teeters
1993 XJ Cherokee
x2
Teeters is offline
post #6660 of 8115 Old 05-07-2013, 05:21 AM
rmeyer332
You have rolled your XJ so much you decide it just easier to chop the top and finally put in a roll cage
rmeyer332 is offline
What do you drive when you can't drive the Jeep? wyojeep92 XJ/MJ Cherokee Non-Technical Forum 418 10-17-2012 06:55 AM
Converting a 2 wheel drive to a 4 wheel drive Greg_Towle XJ Cherokee Technical Forum 4 09-24-2009 07:42 PM
Drive it into the dirt until it dies, fix it, and drive some more!! SoCal_HEMIHead XJ Cherokee Technical Forum 14 08-02-2009 09:23 AM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 10:09 PM
A 16 hour drive Millwaukee WI, from Brooklyn NY, to drive or no?? arieljeep XJ Cherokee Technical Forum 6 06-29-2005 03:35 PM
