you know you drive an XJ when.. - Page 397 - JeepForum.com
 11Likes
post #5941 of 8109 Old 09-17-2012, 09:06 PM
aamuthers
1987 XJ Cherokee
Originally Posted by xj_noob
When you have withdrawals from not working on it :'(
Thats me right now.
Feel free to work on mine, I need tie rod ends, ball joints, a wheel bearing and I have to fill my power steering fluid just about every other day
aamuthers is offline
post #5942 of 8109 Old 09-17-2012, 09:25 PM
cherokeekid58
When your going on your 4th engine...
When your friends and family tell you to sell it and get a "practical" car...
When you sacrifice your Grand cherokee that was your DD for the new short block for your XJ...
[QUOTE=sonoran_Tj
"If we collect data long enough, we may discover the root psychological cause for the "jeep thing".
So far it seems correlated to OCD and the need to look at one's poop."
cherokeekid58 is offline
post #5943 of 8109 Old 09-18-2012, 01:05 AM
Ih8Hondas
How do go through more than one engine in an XJ? The 4.0's and 2.4's are built like brick ****houses. Mine's had an engine swap though. No idea what PO did to it to make it need that.
Also, how can you get a more practical vehicle than an XJ without buying a full-size truck? XJ's have loads of room for stuff, seating for five plus the cargo area (who know how many people you could cram in there), they're awesome in the winter, they can pull some things, they're good if you need to make little off-road excursions to get where you're going, and if you want a trail rig they're great for that too.
1998 Jeep XJ: 4.0, AX15
2006 Yamaha YZ250: Stock
Ih8Hondas is offline
post #5944 of 8109 Old 09-18-2012, 02:13 AM
AttackAttack
When you can hear air getting sucked into your intake over the sound of the muffler
AttackAttack is offline
post #5945 of 8109 Old 09-18-2012, 07:21 AM
xj_noob
When you have a PO
xj_noob is offline
post #5946 of 8109 Old 09-18-2012, 08:30 AM
cherokeekid58
They think the bad MPGs are the reason i should get rid of it, and its always in need of repair lol.
Engine #1: cracked head, coolent in oil caused front con rod bearing to explode into dust. Still drove it 15 freaking miles home with no bearing! Theb drained 5 gallons of oil and anti-freeze out of the oil pan. That explains why it was cranking over extremely hard.
Engine #2: piston #4 droped half the skirt into the oil pan. Still drove it 5 miles home. Knocking like crazy.
Engine #3: one of the con rod bearings went again. Idk why.
So now im swaping in #4.
Sorry for getting off topic.
[QUOTE=sonoran_Tj
post #5947 of 8109 Old 09-18-2012, 09:22 AM
xj_noob
Well there we have it. A pure testimonial that shows even though the engine was barely running, the 4.0 will still get you where you need to go......... with a slight limp.
xj_noob is offline
post #5948 of 8109 Old 09-18-2012, 10:23 AM
accorn
1989 XJ Cherokee
When you run into a mint 96xj w/tire holder in a scrapyard, with a fully detailed engine bay, clean interior, new speakers and full skid plates. Then scratch your head and and begin to try and determine what went so wrong that it came to this... Then struggle internally for 15min over buying it and stripping your 89 to upgrade it or just strip it for upgrades.
When your rear passengers start to compare your xj, while off road, to a rollercoaster unfavorably. So you speed up and the reviews get better untill the yota owner in the back needed to hurl
When you can race down a mountain pass like a sports car, but the strait flat portion at the bottom makes you worry.
When you need those KC's to light up a mile of freeway because thats about the stopping distance for stock breaks from 80 in your pre 95 xj.
accorn is offline
post #5949 of 8109 Old 09-18-2012, 10:34 AM
jeepkid03
Winning
jeepkid03's Avatar
What year engines did you swap in? If I were you I'd be building my own by #4.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #5950 of 8109 Old 09-18-2012, 10:48 AM
cherokeekid58
First was original, second was a 2003, third another 2000, (junk yard special) lol. And the 4th is gonna be a 1993 short block with the 2000 head swaped over. If i blow this one up, its getting a diesel swap.
[QUOTE=sonoran_Tj
post #5951 of 8109 Old 09-18-2012, 10:49 AM
joshrad
1997 XJ Cherokee
When you need to make a u turn on a 6 lane street, but they are getting ready to repave it and have it all torn up in the middle except for one lane each direction, and after they stop traffic for a back hoe and a couple trucks, the construction guys still keep traffic stopped and wave for you to cut across the torn up lanes
Originally Posted by EJames1226 View Post
Once the members of jeepforum get drunk enough, anyone can be a lawyer.
Originally Posted by Spaz_Soldier
Wait! Does that mean XJs are Xtreme Jeeps?
joshrad is offline
post #5952 of 8109 Old 09-18-2012, 02:18 PM
jeepkid03
Winning
jeepkid03's Avatar
If you want that motor to last I wouldn't put the 2000 head back on unless you bought a different head with the improved casting.
-Josh
Build Thread:
post #5953 of 8109 Old 09-18-2012, 02:35 PM
cherokeekid58
Yeah i know. Im thinking about leaving the 1993 engine alone and just fabbing up brackets to hoild the coil packs on. Then throwing the whole en chalada in.
[QUOTE=sonoran_Tj
post #5954 of 8109 Old 09-19-2012, 11:34 PM
vx1kxj
yep exactly what i did. i put a 95 motor in that actually had more miles on it. call me old school but the 91-95 HO motors are the best...forget this powertech crap in the later models. best mod ive ever done.
00 xj clayton 3 link and yadda yadda yadda...
vx1kxj is offline
post #5955 of 8109 Old 09-20-2012, 05:07 AM
BlueBadger
4bt!!!
BlueBadger is offline
What do you drive when you can't drive the Jeep? wyojeep92 XJ/MJ Cherokee Non-Technical Forum 418 10-17-2012 07:55 AM
Converting a 2 wheel drive to a 4 wheel drive Greg_Towle XJ Cherokee Technical Forum 4 09-24-2009 08:42 PM
Drive it into the dirt until it dies, fix it, and drive some more!! SoCal_HEMIHead XJ Cherokee Technical Forum 14 08-02-2009 10:23 AM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 11:09 PM
A 16 hour drive Millwaukee WI, from Brooklyn NY, to drive or no?? arieljeep XJ Cherokee Technical Forum 6 06-29-2005 04:35 PM
