you know you drive an XJ when.. - Page 13 - JeepForum.com
 11Likes
post #181 of 8109 Old 04-21-2008, 08:03 PM
Bobandbeans
when your working on it and you find a bolt that makes you can this design is stupid
2000 xj Lifted, Locked
1996 xj my dd
"I swear to God, I'll pistol whip the next guy who says shenaningans!"
Bobandbeans is offline
post #182 of 8109 Old 04-21-2008, 08:29 PM
400wagon
when you've owned your heep for less than a month and are already familiar with nearly everything in this thread
400wagon is offline
post #183 of 8109 Old 04-21-2008, 08:33 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
You know you're driving an XJ, when people comment, "I didn't even know they made lift kits for Volvos."
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #184 of 8109 Old 04-21-2008, 08:33 PM
etjoyride
etjoyride's Avatar
when a strange clunking noise starts in the front left end, it's not the alignment, it's not the suspension, so you choose to just let it be until it becomes obvious (unless someone on here miraculously knows what the problem is???)
We have a lot of jeeps...and other toys....that is all.
etjoyride is offline
post #185 of 8109 Old 04-21-2008, 09:02 PM
aircruiser
aircruiser's Avatar
no one understands why you want to take the doors off
aircruiser is offline
post #186 of 8109 Old 04-21-2008, 09:12 PM
cheapfix
1991 XJ Cherokee
You keep entering the same numbers into the calculator to figure out your mpg, muttering "that can't be fricken right", and shaking your head.
Recovering moparholic
cheapfix is offline
post #187 of 8109 Old 04-21-2008, 09:18 PM
aircruiser
aircruiser's Avatar
in study hall in school, when you finish your homework, you try and figure out in what order to do your next mods and how much they will cost
post #188 of 8109 Old 04-21-2008, 10:27 PM
thebigt
2005 WK
when you go over a speed bump too fast the radio turns off
thebigt is offline
post #189 of 8109 Old 04-21-2008, 10:33 PM
4.0H.O.XJ
Ball joints, and yeah, I cant figure out why the left side wears out faster than the right either.
4.0H.O.XJ is offline
post #190 of 8109 Old 04-21-2008, 10:55 PM
XJHACK
You carry two tool boxes. One with JB weld epoxy, the other with JB weld hardener
XJHACK is offline
post #191 of 8109 Old 04-21-2008, 10:55 PM
Mr_Random
1986 XJ Cherokee
Your radio has to "warm up" with the engine before you can get it to not skip (I think it's just the crappy player, not messed up wiring in the jeep).
You can flash your lights by playing with the power lock switch (fixed with new battery).
If you actually have door side arm rests, when you lean on them too hard the door rattles REAL bad.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #192 of 8109 Old 04-21-2008, 11:05 PM
JoeJeepWMU
1997 XJ Cherokee
When you wake up every morning and look down into the parking lot to stare at your jeep rather than up at the sun.
1997 Jeep Cherokee Country 4.0 4X4 8.25 rear
2006 Jeep TJ Sport Auto White Jeep Club #90
Originally Posted by TheMightyGoat View Post
I'll do you one better. Friday afternoon.
Though to be fair I have washed my balls off in the sink once or twice.
JoeJeepWMU is offline
post #193 of 8109 Old 04-21-2008, 11:20 PM
slowerisfaster
..when you buy one thinking it'll take just a few bucks to get it perfect and before you know it you've driven 740 miles to get floor pans from a complete stranger, bought all new rear suspension parts, and bought a mig welder, angle grider, and spot weld cutter in order to replace the rusted out floor you discovered in spite of the fact that you've never welded anything in your life before.
^(I hope there aren't any english teachers reading this )
..when you have to take frequent breaks to rest your arm when searching for radio stations because the seek buttons are 300 MILES away from the driver's seat.
..when people look at you funny when you make a sharp turn in a freshly paved parking lot and your tires squeal.
slowerisfaster is offline
post #194 of 8109 Old 04-21-2008, 11:58 PM
mca1977jpsnet
Check your Track Bar and / or Track Bar frame bkt / bolts.
mca1977jpsnet is offline
post #195 of 8109 Old 04-22-2008, 12:00 AM
4.0H.O.XJ
Originally Posted by slowerisfaster View Post
........and before you know it you've driven 740 miles to get floor pans from a complete stranger, bought all new rear suspension parts, and bought a mig welder, angle grider, and spot weld cutter in order to replace the rusted out floor you discovered in spite of the fact that you've never welded anything in your life before.
Hey! I know that complete stranger! Ill kick his *#@ when I see him! Seriously, if you need any assistance with that, gimme a call. I was thinkin' bout that today. Hope you made it home allright.........
What do you drive when you can't drive the Jeep? wyojeep92 XJ/MJ Cherokee Non-Technical Forum 418 10-17-2012 06:55 AM
Converting a 2 wheel drive to a 4 wheel drive Greg_Towle XJ Cherokee Technical Forum 4 09-24-2009 07:42 PM
Drive it into the dirt until it dies, fix it, and drive some more!! SoCal_HEMIHead XJ Cherokee Technical Forum 14 08-02-2009 09:23 AM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 10:09 PM
A 16 hour drive Millwaukee WI, from Brooklyn NY, to drive or no?? arieljeep XJ Cherokee Technical Forum 6 06-29-2005 03:35 PM
