you know you drive an XJ when.. - Page 102 - JeepForum.com
 11Likes
post #1516 of 8109 Old 08-12-2009, 11:53 AM
mavrick480
1997 XJ Cherokee
Originally Posted by xwildman138x View Post
Guess I spoke too soon the air took a dump today. Should have knocked on wood.
mine didn't work when i bought it. Then i thought it would be sweet fun to rear end a guy. ended up with a new compressor and a recharg worked for about a summer then quite working. Had it recharged last summer and tested for leaks they are pretty sure that it is the evap coil. That recharge lasted 2.5 months. They let me know what the price tag was for a evap coil and i said no thanks i'll just install the 60 for 6 system and move on with life.
My wife gripes about having to ride around in the heat i told her how much it would cost to fix it, then explained what the value of the XJ is... She said well we can't afford for you to have a new truck i said so we sit here in the heat.
mavrick480 is offline
post #1517 of 8109 Old 08-12-2009, 12:00 PM
mavrick480
1997 XJ Cherokee
when it requires pliers to pop the hood... Stupid hood latch cable... I'll add that to the list of **** to fix.
When your neighbor comes over to tell you that some one has backed into your car you confirm it was the xj, poke your head out the door to make sure the xj isn't totalled and tell them not to worry about it.
When your list of **** to fix for your XJ is longer than the list of **** to fix on your house.
Hood latch
paint new welds
install new axle because the one i have yolk is complete shot
herc up to first crease
Plugs Wires, cap, and button
seafoam
find a guy who is willing to help me install new gears for a case of beer.
convince my wife aussie locker is totally worth the money
on and on and on
post #1518 of 8109 Old 08-12-2009, 12:14 PM
mattathayde
man, being here in VA ac is worth its weight in gold though, granted RVA isnt as bad as some other places cause its all concrete so not as much humidity but damn
-matt
mattathayde is offline
post #1519 of 8109 Old 08-12-2009, 12:31 PM
SDH
1995 XJ Cherokee
Had an ice cold AC when I bought it last august when it first got warm I went to turn it on and got nothing.......so I just keep the windows down cause i'm too cheap to recharge it.
Red 95 XJ 3" and on 31" BFG AT's
My JEEP
Red JEEP #501
SDH is offline
post #1520 of 8109 Old 08-12-2009, 03:24 PM
mavrick480
1997 XJ Cherokee
-matt
here in central KY the heat and humidity can be quite bad too but it has been really mild this summer.
post #1521 of 8109 Old 08-12-2009, 03:30 PM
mattathayde
it was mild here until the last couple of weeks, then it went through the roof.
-matt
post #1522 of 8109 Old 08-12-2009, 04:31 PM
mavrick480
1997 XJ Cherokee
-matt
Yet i still have no ac and continue to drive it around.
post #1523 of 8109 Old 08-12-2009, 07:49 PM
KINGJB
I dont know what you people are complaining about my AC works great.
Build Thread:
KINGJB is offline
post #1524 of 8109 Old 08-12-2009, 08:02 PM
Kettles
KY is pretty bad.. I want to move to Colorado. It is soooooooooo beautiful, and they actually have winter there! 15 years in KY is enough for me, I need to go back west where I belong (i was born in Mt. Pleasant California) I have some family in Seattle, maybe i could move to Washington... Or I could fix my a/c... that wold be cheaper i bet.
You know you drive an XJ when you want to move across the country because the wheelin is better there. (among other reasons)
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #1525 of 8109 Old 08-12-2009, 08:05 PM
XJMuscle98
Maybe it's just my Jeep, but I know I drive an XJ when I go out to the Jeep with intentions of doing something and 10 minutes later go back inside because whatever you wanted to do is going to turn into a giant project and end up costing way more than you wanted to spend.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #1526 of 8109 Old 08-12-2009, 08:07 PM
Willy36
1990 XJ Cherokee
hells yes for colorado
Willy36 is offline
post #1527 of 8109 Old 08-12-2009, 08:20 PM
mavrick480
1997 XJ Cherokee
It takes a true man to drive around in a vehic with no AC the first two weeks of august in KY... J/K
you know when you drive an xj when you have two oil pressure gauges. One screwed to the top of the dash and one in the dash because the one in the dash decides when it does and does not want to work and after 4 oil pressure sensors you give and and just buy a secondary gauge.
post #1528 of 8109 Old 08-12-2009, 09:25 PM
mattathayde
or when your planed project ends up running into other commitments so you have to relearn on the spot how to speed shower and then get to said commitment w/o speeding excessively
or when a bolt is totally stuck then once you attempt an aggressive extraction (drilling off head, preparing to drill out and retap, etc) it decides to come out finger loose after your almost there
-matt
post #1529 of 8109 Old 08-12-2009, 09:29 PM
Mickey_D
... when you go out to the garage that it's hiding in and just sit in it and go through an entire tube of Armor All glass wipes and an entire tube of the Armor All protectant wipes.
And you never moved from the driver's seat...
This may only apply to people that dug their XJ's out of the back of a wrecking yard and are trying to resurrect them from the dead.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #1530 of 8109 Old 08-12-2009, 09:30 PM
basso4735
basso4735's Avatar
1997 XJ Cherokee
when you fix something, then 3 days later something more expensive breaks.
a/c is kaput yet again.
screw this im going doorless.
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
What do you drive when you can't drive the Jeep? wyojeep92 XJ/MJ Cherokee Non-Technical Forum 418 10-17-2012 07:55 AM
Converting a 2 wheel drive to a 4 wheel drive Greg_Towle XJ Cherokee Technical Forum 4 09-24-2009 08:42 PM
Drive it into the dirt until it dies, fix it, and drive some more!! SoCal_HEMIHead XJ Cherokee Technical Forum 14 08-02-2009 10:23 AM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 11:09 PM
A 16 hour drive Millwaukee WI, from Brooklyn NY, to drive or no?? arieljeep XJ Cherokee Technical Forum 6 06-29-2005 04:35 PM
