xj rear d44 question( brakes) - JeepForum.com
post #1 of 5 Old 01-04-2011, 07:14 PM Thread Starter
BigDeaner
1987 YJ Wrangler
Hi there, couple questions for you cherokee guys. I'm looking at grabbing a rear d44 out of a cherokee to chuck in my yj. No idea what year its from, but it has disc brakes? I just figured it would've came with drums. Would it have come stock w/ discs? Maybe that would help me narrow down what year its from? Thanks.
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
BigDeaner is offline
post #2 of 5 Old 01-04-2011, 07:35 PM
ahuf
As far as I knew d44 off xj's came with drum brakes.
ahuf is offline
post #3 of 5 Old 01-04-2011, 08:01 PM Thread Starter
BigDeaner
1987 YJ Wrangler
hmmmmm, the one I'm looking at also had buckets for coil springs, but i'm 99% positive some one cut off the perches and added the buckets, starting to wonder if the discs were added also.. i cant find any info on the site or online yet to lead me to any info regarding drums/discs.. maybe they're off a zj.. Obviously a bonus if it comes with discs, but without knowing what the heck they're off of, i'm going to have a hell of a time ordering parts for anything on it.
1987 JEEP YJ LAREDO
NP231,AX15,D30,D35
post #4 of 5 Old 01-04-2011, 08:23 PM
motorsports3
1997 XJ Cherokee
It could be from a ZJ or TJ, if it had spring buckets OEM then it is def not from an XJ
motorsports3 is offline
post #5 of 5 Old 01-04-2011, 10:02 PM
jeeepguy
jeeepguy's Avatar
And if its from either, pass. All XJ (or MJ) D44 "Metric Ton" axles came with drum brakes and leaf springs. Also, the ZJ D44 is actually a D44a which has an aluminum center... not what you want as it has no support and is junk compared to an iron D44
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
Brake question, What size rear brakes? BeepBeepGoJeep XJ Cherokee Technical Forum 9 01-05-2012 09:00 AM
Rear brakes doesnt stop rear tires from spinning toates89 XJ Cherokee Technical Forum 6 12-19-2009 01:00 AM
rear disc brakes...question.. white_elephant XJ Cherokee Technical Forum 4 07-02-2007 10:02 AM
No rear brakes Tazjig XJ Cherokee Technical Forum 4 07-19-2006 05:07 PM
rear d44 brakes? randyscj MJ Comanche Technical Forum 4 09-26-2005 10:06 PM
