XJ Interior Mods? Whatcha got? - Page 37 - JeepForum.com
post #541 of 734 Old 01-03-2013, 10:12 PM
Project1
Originally Posted by fedx95 View Post
Is that yours? If not, can you post a link to where you found those?
No its not mine ... guy does really nice work. I'm going to skin my doors like he did, and when I was reading about It i found his xj.
Here's his sight:
http://deanomurray.blogspot.com/
Project1 is offline
post #542 of 734 Old 02-10-2013, 12:47 AM
jesse12296
1994 XJ Cherokee
Some Great ideas!!!! Need some more! Want something cool to do to my jeep tomorrow!
3 inch RC Lift. 220k Trail Digger M/T 31x10.5x15 Crager Rims Dirtbound offroad Extreme Winch bumper
http://www.jeepforum.com/forum/f22/1994-jeep-cherokee-slow-highschool-build-1398809/
jesse12296 is offline
post #543 of 734 Old 02-10-2013, 11:57 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Here's his sight:
That's a cool setup, but without having a place to store it, it'd end up looking like the snow covered piles in the junkyard:i.e.no windows.
D3<!L!>3D
S8NNG8 is online now
post #544 of 734 Old 03-26-2013, 03:09 AM
jayphillip
1993 XJ Cherokee
Originally Posted by chriskeenan View Post
Its the rear sound bar out of a pre-97 XJ, fiber-glassed to the headliner board, then covered in foam backed fabric.
The speakers are standard depth infinity 6.5in 2-ways with polyfill inside the cavity.
The switches are running a 10 circuit relay box mounted under the passenger seat via two cat5 cables, the second switch panel hasn't been built yet but goes where the passenger side aluminum cover plate is, the wires are already ran to it.
The key switch allows for the switched devices to run either on accessory power (only while the engine is running) in the right position, or run from the battery (anytime) in the left position, or be locked out entirely by removing the key in the off/center position, the key is only removable in the off/center position.
The red LED gauge cluster lights are #74 LED drop-ins, from SuperBrightLEDs.com, theses specificaly, you'll need 5 total to do the gauges. The stock dome light also has an LED in it, this one, with wire leads soldered to the pins to attach to the OEM connections.
The sound bar was done so i'd have music while the doors are off, and to give an overhead mounting area for switches, it works well for that. Car audio snobs will say the imaging sucks, which it does, but for 99% of the people that doesn't matter or they don't know why it matters, its a loud door-less XJ not a movie theater.
Some people also hit their heads on the bar while getting in the vehicle, once they remember its there the problem fixes itself. I'm 6'1" and have no issues with hitting my head while driving or getting in and out.
You do great work man! Do you have a write-up on how you wired your relay box? I have been wanting to consolidate wiring as much as possible, and the key addition is genius!
jayphillip is offline
post #545 of 734 Old 03-26-2013, 08:13 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Boom!
D3<!L!>3D
post #546 of 734 Old 03-26-2013, 02:06 PM
modsjeep11
When r u eligible?
modsjeep11 is offline
post #547 of 734 Old 03-26-2013, 02:56 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
What makes me not eligible?
D3<!L!>3D
post #548 of 734 Old 03-26-2013, 03:02 PM
chriskeenan
Originally Posted by modsjeep11 View Post
When r u eligible?
uhhhh, what?
chriskeenan is offline
post #549 of 734 Old 03-26-2013, 03:17 PM
chriskeenan
thank you. no write up on the box, its fairly simple, just some relays, snap together terminal blocks for the relays, some diodes, a fuse panel, and in/output terminal strips. got all the parts from allied, i think it ended up being about 120$ for everything.
post #550 of 734 Old 04-13-2013, 08:25 PM
commander0374
1997 XJ Cherokee
I added some storage to my cargo area.
It ain't pretty but it's functional. All I did was take 2 milk crates that I had laying around used some wood to join them together and create a lip so items would stay in.
I then screwed an eye ring into the side paneling and zip tied the whole thing to that.
commander0374 is offline
post #551 of 734 Old 04-15-2013, 12:08 PM
burnsst96xj
Just finished painting my fake wood paneling with black high gloss interior plastic spraypaint. came out very well.
I also added toggle switches for the lights yet to come.
burnsst96xj is offline
post #552 of 734 Old 04-16-2013, 09:23 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Here's my next interior mod...
... this'll give me back the interior space that my full size spare takes up.
D3<!L!>3D
post #553 of 734 Old 07-01-2013, 05:14 PM
TimHaw
1992 XJ Cherokee
[IMG][/IMG]
Here are a few of mine. Rear window racks, mag mount, bottle opener. I got an old pa siren unit from the local police department and installed it under the center council tray and wired the nobs out so it was hidden away.
TimHaw is offline
post #554 of 734 Old 07-27-2013, 12:39 PM
islandsnow
Replaced headliner this summer.
islandsnow is offline
post #555 of 734 Old 07-28-2013, 02:39 PM
Cjvillar
Hey does anyone know where or how I can get an adapter for my 96 XJ antenna to hook up to a 2004 chrysler pacifica radio? The plugs don't line up, the stock one just pushes in but on the radio the antenna wire has a center piece and then another ring that goes in if that makes sense. Thanks.
96 XJ
Cjvillar is offline
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Looking for Interior/exterior Mods Sirus789 XJ/MJ Cherokee Non-Technical Forum 15 10-22-2013 12:02 AM
lets see who got the most interior mods adham XJ/MJ Cherokee Non-Technical Forum 19 05-12-2009 12:06 AM
interior mods MATT123 XJ Cherokee Technical Forum 2 01-02-2008 06:18 PM
Exterior & interior mods MetalliMar XJ Cherokee Technical Forum 3 07-14-2004 10:22 PM
Whatcha think? mission-inc XJ Cherokee Technical Forum 9 12-11-2003 12:12 AM
