XJ Interior Mods? Whatcha got? - Page 28 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > XJ Interior Mods? Whatcha got?
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 03-30-2011, 08:05 PM   #406
fedx95
1993 XJ Cherokee
blue leds on the lights that turn on with the doors
fedx95 is offline   Reply With Quote
Unread 03-31-2011, 06:10 AM   #407
K-R
Originally Posted by Dbiked View Post
What's the point of the bungies?
Let's say you are climbing a steep logging hill and your 33" BFT loses traction and the rig goes rolling down the hill. The rear seat passengers can reach back and grab the bungies in order to secure themselves better in the vehicle.
No just kidding. Let's say you are hauling bicycles on a hitch mounted bike rack that you have to take the front wheels of the bikes off of in order to carry the bikes. You slide the loose front wheels up inside that bungie and it holds them fairly well and takes up less space than wheels laying flat.
There are probably other uses as well.
K-R is offline   Reply With Quote
Unread 04-08-2011, 07:06 PM   #408
1995_XJ
Steve
1995 XJ Cherokee
Originally Posted by Texsun View Post
nothign to special
and my epic hang man!
I spy a Ar-15 with FDE Magpul CTR and a Matech rear sight! Looks good
1995 Cherokee Sport
1995_XJ is offline   Reply With Quote
Unread 04-09-2011, 11:14 PM   #409
Dbiked
Oh, good plan! have you thought about putting a bungy going across the top of the rig, from where you have the other one mounted going straight back to the hatch, or if you dont really have many people riding in the back often, across to the other side, so that it lines up with the back of the rear seat, and then you could use it to hang crap off of! might be useful.
But in all seriousness, that silly idea gave me a good one. I think I might do. Get one of those dog grates made for the back hatch area of the XJ, and sense its wire mesh crap, you really could hang all kinds of crap off of that and then it would be added protection from all the crap us jeepers tend to carry around in the back of the XJ, incase of an accident, or roll over or something.
Utah jeep crew member #32
Dbiked is offline   Reply With Quote
Unread 07-12-2011, 09:25 PM   #410
lilnapsak
1997 XJ Cherokee
center consol lock
[QUOTE=Back_In_Black;12988070]your not very good at trolling.[/QUOTE]
lilnapsak is offline   Reply With Quote
Unread 08-02-2011, 10:19 AM   #411
3shifty
Originally Posted by lilnapsak View Post
center consol lock
Very Cool!
3shifty is offline   Reply With Quote
Unread 08-02-2011, 07:52 PM   #412
pentastar01
center consol lock
What's up with that passenger door panel?
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline   Reply With Quote
Unread 08-03-2011, 03:14 AM   #413
lilnapsak
1997 XJ Cherokee
thats the inside of my halfdoors before i made door panels for them
and yes i WAS using a shovel to chock my wheel
Unread 08-04-2011, 01:36 PM   #414
1995_XJ
Steve
1995 XJ Cherokee
Originally Posted by 98CherokeeLTD View Post
cb up top
switch panel
Lights off...
Lights on...
What is the thing above your CB? Mine has the same thing, not sure what it is.
Probably a obvious..
1995 Cherokee Sport
Unread 08-04-2011, 05:35 PM   #415
lilnapsak
1997 XJ Cherokee
its for the keyless entry keyfob. they were installed in cars sold to lazy people who find turning a key takes to much effort
Unread 08-04-2011, 08:40 PM   #416
NJXJ91
Has anyone turned the ash tray into a iPod dock or aux port/charger? Tht would be cool to see
NJXJ91 is offline   Reply With Quote
Unread 08-23-2011, 11:28 AM   #417
Chelsea
The clocks ticking, pops.
Chelsea's Avatar
I painted part of the center of the dash blue, as well as the door handle rings.
I also just swapped a TJ gauge cluster into my XJ (white/blue instead of green/orange) and installed a brushed aluminum bezel.
I've also got blue LEDs for the gauges, switches, and shifters.
The last pic also shows my Scangauge II that I use monitor gas mileage and check/clear engine codes. It also has an accurate speedometer. It's kind of nice.
Chelsea
WANTED:
-Jeep Comanche OEM drip rails
Chelsea is offline   Reply With Quote
Unread 08-23-2011, 06:04 PM   #418
TreyXJ
: drool:
I've been wanting to do the painting thing that you did for a while, that looks great! What kind of paint did you use, and what did you have to do for prep? And how did you do the doors? Can you remove the ring to spray it or do you have to tape everything else off? When I do it I want to paint my cruise control things on the steering wheel too...
Gauges look sweet too...but I don't wanna swap and loose my mileage otherwise I'd be doing that too
TreyXJ is online now   Reply With Quote
Unread 08-23-2011, 07:14 PM   #419
chriskeenan
Not Involved
chriskeenan's Avatar
I give you the I-like-being-doorless-in-my-XJ-but-I-also-like-my-front-speakers soundbar and switch panel
And red LED gauge lighting
chriskeenan is online now   Reply With Quote
Unread 08-23-2011, 07:49 PM   #420
Chelsea
Chelsea's Avatar
Originally Posted by TreyXJ View Post
: drool:
Thanks! As for prep, I taped off the outer edges of the center piece because I only wanted the middle/main part to be blue. I sanded the whole thing down then wiped it with prep-sol (acetone or mineral spirits will work too) and let it dry. I painted it with two coats of white first to make sure that the blue would be bright on the black plastic. After that dried enough, I went over it with (I think) two coats of the blue. All of the paint I used was Krylon Fusion, which in my experience works great on any kind of plastic. As with any kind of painting, prep work is everything, so just pay attention to the details
As for the door rings, the front ones just pop out if you pry them carefully. The rear ones, however, do not since there are switches in them. It's been two years and I still haven't painted the rear ones to match because I don't feel like taping everything off. I'll get to it eventually.
And the whole mileage thing... I got really lucky and found a cluster with almost the same mileage as my Jeep has, so it wasn't a concern.
Chelsea
WANTED:
