XJ Interior Mods? Whatcha got? - Page 27 - JeepForum.com
post #391 of 734 Old 03-16-2011, 08:39 PM
Jeremylerv
2003 WJ
Originally Posted by NJXJ91 View Post
Howd you do the cupholder lights?
Got a pre-wired 5mm LED light from www.superbrightleds.com and just drilled a hole in the center of the cupholder then wired the lights to my headlight switch so they turn on with my headlights.
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
(o)_)____(o)_)--o)_)
Jeremylerv is offline
post #392 of 734 Old 03-18-2011, 08:43 AM
NJXJ91
Is there any glare when your driving from the cup holder lights?
NJXJ91 is offline
post #393 of 734 Old 03-24-2011, 08:32 PM
Jeremylerv
2003 WJ
Not really, the only thing is the light shines up and into my rearview mirror but its not that bad.
.,_______.o_o.
//_|__l__,\___\,___
post #394 of 734 Old 03-25-2011, 07:44 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by jeepin ruby
I did the ole headliner replacement a couple of weeks ago...
Turned out okey. Its a heck of a lot better than it was!
What'd you use the adhere/secure the material to the headliner? Thanks for your time.
95whiteXJ is offline
post #395 of 734 Old 03-27-2011, 06:58 PM
xxxxxxxxxxxxxxxxxxxxxxxxWThorn
Guest
bump.........this **** is inspiring.....lol
xxxxxxxxxxxxxxxxxxxxxxxxWThorn is offline
post #396 of 734 Old 03-27-2011, 07:53 PM
Jeremylerv
2003 WJ
has anyone done the pod gauge thing on the windshield pillar? If so i wanna see it!
.,_______.o_o.
//_|__l__,\___\,___
post #397 of 734 Old 03-28-2011, 04:49 AM
tsvallette
Insteresting I am doing it right now! I am using Universal Gauge Pillar Holders, one that has 3 spots to mount gauges and one that is a single. With a little work these two should fit. As for pics I dont have a few as of yet but I can get some up later today. I picked them up on Amazon but they can be picked up at Autozone.
If its too plain then it can be made better ( Modify )!!!!!
95 Build/Rebuild
http://www.jeepforum.com/forum/f177/my-1995-400-expense-948376/
tsvallette is offline
post #398 of 734 Old 03-28-2011, 10:41 AM
Jeremylerv
2003 WJ
What gauge's are you putting in it? If i get one i know i would do trans temp but what about the other two?
.,_______.o_o.
//_|__l__,\___\,___
post #399 of 734 Old 03-28-2011, 11:15 AM
tsvallette
I lack the funds to pick up any new gauges right now so I am modding the originals to fit in for now. Link to my thread but exactly to the #56 post with images.
95 Build/Rebuild
post #400 of 734 Old 03-28-2011, 08:05 PM
VTEK1
Originally Posted by vx1kxj View Post
heres mine. my interiors dirty because its winter and im pretty upsett by it too
and this
I would really like to know how you set that plug up and what you needed to run to get that going. Such a great idea!!
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #401 of 734 Old 03-28-2011, 08:12 PM
VTEK1
Originally Posted by CT99XJ View Post
Gauge cluster:
Where did you get the gauge cluster??
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #402 of 734 Old 03-28-2011, 08:17 PM
VTEK1
Here is what I did, used a dremel cut out a small hole. and ran the plug to the cigarette lighter. I plugged my GPS and my under dash lights into it. Someday I'll just wire the under dash lights to a switch but until then I like this setup. The 3 plug unit you can get at walmart for like $8.
Only in a Jeep
MΘΣΝΔ ΚΘΒΦΘΡ
VTEK1 is offline
post #403 of 734 Old 03-29-2011, 01:07 PM
K-R
bungees:
K-R is offline
post #404 of 734 Old 03-30-2011, 01:27 PM
TBsCherry
Originally Posted by Jon05Rubicon View Post
70/30 or so split rear bench
I WANT THIS. Hows it done??
Well Done my friend
TBsCherry is offline
post #405 of 734 Old 03-30-2011, 04:52 PM
Dbiked
What's the point of the bungies?
Utah jeep crew member #32
Dbiked is offline
Looking for Interior/exterior Mods Sirus789 XJ/MJ Cherokee Non-Technical Forum 15 10-21-2013 11:02 PM
lets see who got the most interior mods adham XJ/MJ Cherokee Non-Technical Forum 19 05-11-2009 11:06 PM
interior mods MATT123 XJ Cherokee Technical Forum 2 01-02-2008 05:18 PM
Exterior & interior mods MetalliMar XJ Cherokee Technical Forum 3 07-14-2004 09:22 PM
Whatcha think? mission-inc XJ Cherokee Technical Forum 9 12-10-2003 11:12 PM
