XJ Interior Mods? Whatcha got?
#16 | |
Come out and play.
Interior mods to my '01:
- '98/'96 ZJ seats (still working on the 60/40 rear) - Installed an overhead console, '98 XJ --Most of my aux lighting switches are mounted in the overhead console with a fuse block --Replaced the stock lighting in the console with LEDs (Cargo light too) - Auto-dimming rear view mirror, '98 ZJ - Replaced the stock stereo - Rocklight switch mounted to the right of the instrument cluster - Cargo net over cargo area, '97 ZJ - Mounted 3-cell flashlight to the outside of the driver seat - Fire ext. mounted in the rear cargo cubby - Replaced stock footwell lights with 4" LED bars - Mount 4" LED bars under driver/pass seat to light the rear footwells Still planned: - LED dash lighting - Aux power plug or inverter mounted in cargo area - Hurc the interior - Pick and install a CB (maybe) - Install padding at panel & dash mounts to silence any squeaks/rattles I think thats it...
#17 | |
2000 forest green pearl coat xj, 3" RC lift with full packs, bilstein 5150's with jks BPE's, amc long black swap from a '95, K&N drop in, Helix throttle body spacer, IRO 2.5" cat back, mopar gas tank skid, mopar engine skid, mopar trans skid, jks quick disconnects MOOG v8 zj steering. 31" firestone destination A/t on factory steelies. tan seats removed in favor of black ones. |
#18 | |
Ron Paul 2012
![]() 2 sets of foglights ![]() ![]()
XJ Non-Tech FAQ | 1/20/2013 The End of an Error | Ron Paul '12 Quote:
If you find my post to be good or helpful please take a second to click the "thumbs up" icon near the quote option. Thank you.
#19 | |
*Center console *Gear Shifter *Emergency Brake Lever *Heater duct under it There gear shifter and emergency brake lever are direct bolt in's. The heater ducts you need to cut about 8 inches off the front of the newer one and about eight inches off the front of the older one and duct tape or melt the older front onto the newer duct and put the duct into place. Then the proper way to install the console would be to drill and mount the back bracket for the new console, but I didn't install the rear bracket because the front ones hold it down enough and it doesn't move. And that's it. -------------------- I'm not to worried about the wiring as long as I can find a good diagram of what each wire goes to and well I'm doing it I might go ahead and make it so I can unhook the wires so I can go door less if I want to.
1992 Jeep Cherokee Laredo 5 speed, 4x4, 149k miles, all skids, tire carrier, cargo cover, factory radio/speakers, 10k miles on following items; rebuilt motor, new tranny, rebuilt rear diff, complete exhaust system, complete brake system, radiator, 30" tires, suspension. No dents or scratches in the paint. ONE OWNER UNTIL NOW. |
#20 |
thanks, I'm going to look for one.
#21 |
Love the blue lighting... how hard was it to switch out the factory lights for the LED's? I have been contemplating the same mod as I have a Premier (Pioneer) head unit as well as a Tsunami Cap and love the blue lighting.
Any shots of the conversion, any parts that were hard to do, cutting etc? What lights did you use? Thanks!! Oh and I love the Husky Liners, just got a set a couple of weeks ago.
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#22 |
Ive got Gaping holes in my floor boards, that count?
.,_______.o_o. //_|__l__,\___\,___ l_--\__\__l----[]llllll[] _(o)_)____(o)_)--o)_) Daily Driver Jeep #16 Utah Jeep'n |
#23 |
Come out and play.
I think it should. Especially if they're sealed off with something high-tech like seran wrap...
#24 | |
“If it rolls, floats, flies or shoots, runs on gasoline or gunpowder, goes fast or shoots a big bullet and makes lots of noise, thus producing torque and recoil — it’s cool.” Do you want 6,000 acres of land open to OHV's? Sign the petition for Northumberland OHV Park |
#25 |
I've got:
- Pioneer Stereo with iPod hookup for listening/charging. - iPod mount for the plastic area between my steering wheel and stereo. - Maglite holder on the lower door sill on the driver side next to the seat. - Rear tire cover from an Orvis edition Grand Cherokee (lots of pockets). - Cobra 19 CB Radio under the steering column near the 4x4 lever. - FitchVA's light switch box mounted above the rear view mirror. - eBay cup holders to replace the crappy one on the side that falls off all the time. Coming soon - iPhone mount/charger/aux since my current setup doesn't work with my iPhone. - Smittybilt G.E.A.R. seat covers front and back. - Husky floor liners. - Need to fix my dome lights...they stay on all the time so I pulled all the bulbs out. - maybe LED backlighting for my gauges, dash.
1993 XJ 2 Door Country 4.0 Litre HO, AW4 Suspension: 3" Rough Country lift with full leaf packs and HD lower control arms | RE Gen2 Swaybar Quick Disconnects Wheels & Tires: 31x10.50R15 BF Goodrich All-Terrain T/A KO | Cragar Black Soft 8's 15x8 4" BS Recovery: Rock Lizard Rock Monitor Front Bumper | Drawtite Rear Hitch | Hi-Lift All Cast 48" | Hi-Lift Wheel Adapter Lights: Four 6" Round 100 watt lights | Two rectangular backup lights | Two Hella 500FF lights on front bumper Other: Surco 45x50 Sarari Rack | Tranny cooler | Smittybilt G.E.A.R. Seat Covers Coming Soon: Detours USA Tailbone Tire-Carrier | AJ's Super Rock Rails |
#26 |
Lets see..
FitchVA inspired switch box with tuned Uniden Pro520XL mounted underneath Jensen (yeah I know but it works fine) in-dash DVD/GPS/Ipod Control ![]() ..and don't worry that rearview isn't mounted nearly as low as it looks in the pics, its maybe an inch lower than it would be stock visibility hasn't been affected for me. Focal entry level components, possibly the best thing I've installed thus far ![]() ![]() Viair 90P mounted under rear seat ![]() Custom Cargo Box in the rear for a full tool set, hydraulic jack, spare parts, spare clothes, etc etc. Also has a dual 10" enclosure incorporated into it. ![]() Cheap fogs installed onto hatch lid to shine into rear enclosure area or to sides of jeep (positionable) Also have a mag mounted on the side of my console up front, some Michelin rubber floor mats, ipod mounted inside center console, one amp under rear seat, one in storage box... I think thats about it. Now for what I need a new headliner and some seatcovers! |
#27 |
#28 |
Thanks it was a fun project and it would not have turned out so nice had I not had a engineer helping me (my dad). It is a tight fit too, it was actually assembled inside the jeep and won't move unless it is dissasembled. In hindsight if I were to do it again I would have made one of the openings big enough to drop in a cooler, and also think it would be cool to have a table underneath the entire thing that comes out and is supported by several slides. I just don't know how much weight something like that could support, who knows maybe I will get around to it one of these days...
#29 | |
There ya go.
I have an xj and it is blue |
#30 |
I see a project in my near future... thanks for the link!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
