Which XJ to buy?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Which XJ to buy??
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueSave 5% Off Of All Orders In August - Promo Code
Unread 07-16-2015, 01:02 PM   #1
VietVet67
Xj Which XJ to buy??
What were the best years to buy--or to avoid?? Thanks in advance
Silver Jeep club member #76 Semper -Fi my brothers
VietVet67 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 01:04 PM   #2
jonsnw93
Avoid 00-01, other than that it's all preference
jonsnw93 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 01:25 PM   #3
Finallyajeep
As an owner of an 00 that has been well maintained I wouldn't say avoid the 00-01 XJ's at all cost, but be sure that if you are looking at one it is in good condition. This is especially important when it comes to the cooling system since the head cracking can be caused by overheating. Ask the owner if it has ever overheated, check the oil for signs of coolant etc.
Firefighters Jeep Club
Finallyajeep is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 01:29 PM   #4
Markmontana
Buy the best one you can find- not the first or the cheapest.
I go slow, and make sure I am getting good penetration. Mowillie
Markmontana is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 02:07 PM   #5
jonsnw93
The seller is always going to lie if they can. The truth is unless you are the original owner, you can trust anything someone says. The 4.0 is a great engine, just have to be careful
Unread 07-16-2015, 02:20 PM   #6
S8NNG8
1995 XJ Cherokee
'98-'99 are the best for late models. '95 is the best for early models.
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 07-17-2015, 08:13 AM   #7
FairlanePhil
and get a matching parts car, air tools, a covered workspace and you'll be fine
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 07-17-2015, 10:49 AM   #8
RedJeepster1
RedJeepster1's Avatar
This in combination with looking for one without any rust. If you can find a clean one, with the right parts, you will have it a long time. As far as the issue with the 00-01's, I think there is a lot more hype online than what actually happens. My girlfriend and I both own 00's and have had no head or cooling issues. It would be nice if the front axle was HP30 though, instead of the LP30. Otherwise, the 97+ xj's are pretty nice in that you get cup holders and a somewhat modern looking interior. That is all preference though. The real early xj's (like from the 80's, dont remember exactly what years) with a manual had the ba10/5 transmissions and were junk, avoid those. Check floor pans and rocker panels for rust. I have also seen them rust right at the back of the frame rail by the shackles also. Test drive it when you find one. Make sure the 4wd is working. Make sure it doesn't have death wobble. Make sure it gets up to temp so you can see if its making good oil pressure and then check underneath of it to make sure it doesn't have any leaks. Other than that, its a Jeep. Even a "bad" one will get you where you want to go. Happy hunting!
88 YJ with a 4.6l stroker, 2.5" lift, 4.10's and 33's
2000 xj w/ 325k+, AW4, NP242, 3.55's, HD Crown Leafs, cut fenders and 31's
RedJeepster1 is online now   Reply With Quote Quick reply to this message
Unread 07-17-2015, 11:12 AM   #9
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
Anything 87+ is fine. BA10s are are as hell in XJs.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 07-17-2015, 11:16 AM   #10
RedJeepster1
I had an 87 xj with the BA10 that I swapped into my YJ because I had blown mine up (for the second time). I put it in and it lasted less than a year and I blew it up again. I wouldn't trust the thing as a anchor. They suck!
Unread 07-17-2015, 05:24 PM   #11
Motorcharge
Bandeded
1991 MJ Comanche
They're pieces of crap, but they're not common to find at all. They only used them for a year in XJs/MJs.
Unread 07-17-2015, 07:57 PM   #12
VietVet67
Thanks all whats a BA10???
Unread 07-18-2015, 12:14 AM   #13
shooptube
1997 XJ Cherokee
http://www.novak-adapt.com/knowledge/ba10_5.htm
That piece of junk. ^^
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 07-18-2015, 04:03 PM   #14
Motorcharge
Bandeded
1991 MJ Comanche
On the plus side they're incredibly easy to open up and rebuild lol
Unread 07-18-2015, 04:12 PM   #15
300cpilot
1995 XJ Cherokee
Personally if you find one you want, find out if the owner is on here and then search for there posts or build thread. I would sell you my rust free 95 or 96? Your not to far from me.
300cpilot is offline   Reply With Quote Quick reply to this message
