Wrangler axles on Cherokee - JeepForum.com
post #1 of 5 Old 05-19-2011, 07:27 PM Thread Starter
Crazystang89
1995 XJ Cherokee
What has to be done to fit Wrangler axles under a Cherokee AND fit the Cherokee axles under a Wrangler? My buddy has a 98 TJ with a D44 rear and D30 front, both have 4.11 gears and ARB air lockers. He wants to sell the Jeep and is willing to trade me the axles for my axles and a little boot. I know the rear will need spring perches since the TJ is coil sprung in the rear but after that I'm just guessing. Thanks guys.
1995 Cherokee Country 4x4
RC 3 inch, 30x9.50 MTs, DD
Originally Posted by BeepBeepGoJeep View Post
LOL heres how I see it....arguing over the internet is like being in the special olympics....even if you win you're still retarded.
Crazystang89 is offline
post #2 of 5 Old 05-19-2011, 07:32 PM
LilyBayXJ
I believe that other than the spring perches everything else should by interchangable.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #3 of 5 Old 05-19-2011, 07:35 PM
BriansCJ
1994 XJ Cherokee
The front will bolt in, but I would just take the ARB and keep your HP housing.
The rear will neew new perches, why not just look for an XJ D44 for like $300.
IMO, its not worth it to swap any XJ axle into a TJ unless its a D44.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 5 Old 05-19-2011, 07:47 PM Thread Starter
Crazystang89
1995 XJ Cherokee
Well the thing is is he is selling the TJ. He doesn't plan to get a premium for the gears and lockers since the kind of people that are interested in the Jeep don't know a D44 or ARB lockers from a hole in the ground. So the plan was to give him a few hundred bucks ($500) AND put my axles under the TJ and then sell it with no one being the wiser. Then I throw those axles under my XJ and save the money of a D44, two regears, and the purchase and installation of the lockers. This doesn't sound like a good idea? I figured I'd be saving at least $2000 in parts and labor for just a little bit of fab work. (Oh, and I forgot about the TJ being low pinion front so we'll figure around that.)
post #5 of 5 Old 05-19-2011, 09:28 PM
tbburg
The XJ/TJ D-44 is a small tube -44, so you can in theory carefully cut the spring perches and control arm/track bar brackets off the -44 and weld them onto your d-35. If you make a jig linking all the pickup points and the pinion, it would make the transfer technically pretty easy. Lot of work though. Depending on the price at JYs around you, it might be easier to get a TJ D-35 from a junk yard that matches your front axle gearing and swap that in.
Regardless, when you finish, you have one more problem. The D-35 drive shaft is 1" longer then the -44 'shaft. It might work on the TJ long enough to sell it, but a pretty crappy thing to do,... If you buy a TJ axle, you can get the shaft with it. Not a problem for your rig, as the XJ shaft can be cut/shortened.
If you're not planning to go any higher then 3" lift, the LP front axle won't make much difference in the XJ. The HP axle might have a clearance issue in a TJ unless it's carrying some lift. Unfortunately, you can't swap the gears between axles, nor can you swap carriers and put the ARB into your XJ(unless you drop to 4:10 gears in your axle).
If you have a reasonable JY around you, it might be easier to buy an axle set from a TJ, swap them out on your buddy's rig, then do whatever mods you need/want to fit the -33/-44/arbs combo into your XJ.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
What Axles Are My 2000 Jeep Cherokee Sport Running? (i Have Pics Of My Axles) DylanYazel XJ Cherokee Technical Forum 23 08-31-2009 10:56 AM
Hey Cherokee owners...Will stock 2005 Wrangler Wheels fit a 95 Cherokee? RedArrow10 XJ Cherokee Technical Forum 3 07-23-2009 11:41 AM
grand cherokee axles under cherokee XJ90 XJ Cherokee Technical Forum 3 10-21-2008 09:35 PM
is there a difference between grand Cherokee and Cherokee axles? 510z XJ Cherokee Technical Forum 13 05-31-2008 05:48 PM
cherokee axles? McWood XJ Cherokee Technical Forum 1 04-25-2008 09:23 PM
