Would adjustable shackle fix current shackle angle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Would adjustable shackle fix current shackle angle?
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-27-2015, 06:20 AM   #1
Workman13
1997 XJ Cherokee
http://www.ironrockoffroad.com/10456.html
I have terrible shackle angle on my jeep which causes a terrible ride. I have considered doing the whole new hd shackle kit but also considered just buying a new shackle for little to no lift. I am fine getting an extra 1" of lift but would something like this also help fix my shackle angle?
Workman13 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2015, 07:25 AM   #2
S8NNG8
1995 XJ Cherokee
If you use the lower hole and accept the 1" lift, it may help some. Without relocation brackets you may be better off with JKS dogleg shackles.
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 06-29-2015, 02:11 PM   #3
bluejunior
I've heard ranger shackles have a bit of a bend (like the JKS doglegs) and can improve the angle. They're only like....1.25" longer than XJ shackles so it shouldn't lift more than maybe 3/4" and they're about half the price of the JKS kit.
"I just need to do a couple tweaks on my jeep, I'll be done in a couple hours." - gone 3 days
bluejunior is offline   Reply With Quote Quick reply to this message
Unread 07-01-2015, 05:32 AM   #4
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
A longer shackle is only going to maintain your current angle with more distance from eye to eye. The angle is usually only resolved by changing the mounting location (i.e. - relocation brackets).
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
