Will stock wheels with 33s work? - JeepForum.com
post #1 of 24 Old 02-28-2013, 10:24 AM Thread Starter
gasperooch
1988 XJ Cherokee
Hey all, I picked up a 88 XJ and I want to do a 4" lift with 33" tires but I kinda like my stock rims. Can I run that size of tire with stock rims or will the offset be too shallow to fit that big a tire?
Sent from my ADR6400L using AutoGuide.Com Free App
gasperooch is offline
post #2 of 24 Old 02-28-2013, 11:47 AM
moses21
The stock rims have to much backspacing, your going to rub.
moses21 is offline
post #3 of 24 Old 02-28-2013, 12:24 PM
Spokes
you can run them you will just need spacers.
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #4 of 24 Old 02-28-2013, 12:36 PM Thread Starter
gasperooch
1988 XJ Cherokee
Oh duh, I don't know why I didn't think of running spacers. Thanks
post #5 of 24 Old 02-28-2013, 01:03 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
That all depends on width. A 10.5" wide tire would work
1990JEEPXJ is offline
post #6 of 24 Old 02-28-2013, 01:15 PM
Motorcharge
10.5 will still rub LCAs.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #7 of 24 Old 02-28-2013, 01:27 PM
ibjeepin95
Originally Posted by motorcharge
10.5 will still rub lcas.
x2
ibjeepin95 is offline
post #8 of 24 Old 02-28-2013, 02:41 PM Thread Starter
gasperooch
1988 XJ Cherokee
Would the 10.5 rub The LCA even with the spacers? Also I'm looking at a RC 3" lift that comes with new LCA's. Will it even be an issue then?
post #9 of 24 Old 02-28-2013, 02:42 PM Thread Starter
gasperooch
1988 XJ Cherokee
post #10 of 24 Old 02-28-2013, 02:47 PM
JeepinJeremy
you can get a zone 4.5" for 100.00 bucks more. Search rockridge 4wd here on the forum. You get a full kit including shocks. I got mine from them and love it. Way better than that ebay RC kit. O he also sells RC with a better discount than ebay too.
JeepinJeremy is offline
post #11 of 24 Old 02-28-2013, 03:29 PM Thread Starter
gasperooch
1988 XJ Cherokee
What kit did you go with?
post #12 of 24 Old 02-28-2013, 04:22 PM
Motorcharge
No, it has to do with having the right backspacing. Spacers simply change the backspacing on your existing wheels.
|SOLD|
| June 2015 COTM |
post #13 of 24 Old 02-28-2013, 07:31 PM
JeepinJeremy
http://www.rockridge4wd.com/4-5-Jeep...-fslash-j9.htm
Pm the guys over at rockridge4wd through jeepforum and he will give you a sweet price. His post shows the discount is going on through april.
post #14 of 24 Old 03-01-2013, 07:14 PM
rugsucka
Aside from backspacing, stock rims are only 7" wide and not a good choice for typical 33x12.5x15 tires. They would be fine for less common (but still easily found) 33x10.5x15 tires.
IF you run a 12.5" tire
-A 12.5" wide tire would crown too much on a 7" rim causing middle of the tread wear unless you ran low air pressure which fatigues the sidewall.
You would be better running a 8" wide wheel for a 12.5" tire.
If you run a 10.5" tire
-the 7" stock rim would be fine once you added spacers to eliminate rub.
If you buy a lift kit - full length AAL or new leaf packs is a must - no blocks, no lift shackles on STOCK leaf packs.
rugsucka is offline
post #15 of 24 Old 03-01-2013, 08:24 PM Thread Starter
gasperooch
1988 XJ Cherokee
Re: Will stock wheels with 33s work?
I'm sorry, I'm still learning. What's a AAL?
