Why do my o2 sensors keep going bad? - JeepForum.com
post #1 of 8 Old 01-24-2014, 08:24 PM Thread Starter
Amcxjkid
So last summer my check engine light came on and I knew what was and I had it scanned to be sure and sure enough it was sensor 2, replaced it and a few weeks later engine light came back on, ok so had it scanned again and came back to sensor 1 and replaced that one to. Well, few months later I was doing some snow wheelin and also hauled a light load of wood to my buddy's and she was running a bit hot but I knew it would be fine. Sure enough I was on my way home and check engine light came back on and now one or both of them are dead again. I'm getting 12.8 MPG and I'm really sick of dumping $160 bucks in o2 sensors in it. Anyone had the same problem or know what I need to do to keep the sensors good?
Also I did out a cheap cherry bomb turbo exhuast in after the cat (obviously) would this maybe have something to do with it? Thanks!
Amcxjkid is offline
post #2 of 8 Old 01-24-2014, 08:31 PM
PaYankee
Why so much? O2 sensors are $36 from rockauto. I replaced my upstream a year ago and have not had a problem. Still have the factory downstream.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #3 of 8 Old 01-24-2014, 08:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What brand O2 sensors ? Universal fit, or direct fit ?
O2 sensor failure can be a faulty heater element, or from running too rich or too lean. A head gasket failure and exposure to steaming coolant can kill a sensor. Some RTV silicone sealants can cause O2 sensor failure. A failed O2 sensor can cause poor gas mileage (1/3 to drop), rough running or idle, stalling and stumbling, with black smoke.
Is your 0331 head cracked ?
CJ7-Tim is offline
post #4 of 8 Old 01-24-2014, 08:42 PM Thread Starter
Amcxjkid
Originally Posted by CJ7-Tim
What brand O2 sensors ? Universal fit, or direct fit ? O2 sensor failure can be a faulty heater element, or from running too rich or too lean. A head gasket failure and exposure to steaming coolant can kill a sensor. Some RTV silicone sealants can cause O2 sensor failure. A failed O2 sensor can cause poor gas mileage (1/3 to drop), rough running or idle, stalling and stumbling, with black smoke. Is your 0331 head cracked ?
Bosch direct fit. I haven't checked my head yet but I thought only the 2001's cracked? This summer I'm doing a full build stroker for it so if it's a cracked head I'll leave them.
Amcxjkid is offline
post #5 of 8 Old 01-24-2014, 08:43 PM Thread Starter
Amcxjkid
they were around $60 my dad picked them up without any of my input haha.
Amcxjkid is offline
post #6 of 8 Old 01-24-2014, 09:09 PM
PaYankee
I got the NTK upstream off rockauto. It's around $35 now.
PaYankee is offline
post #7 of 8 Old 01-25-2014, 11:29 AM
CJ7-Tim
CJ7-Tim's Avatar
Many Jeepers report that Bosch O2 sensors and Jeeps do not play well together. Jeep installed NTK/NGK O2 sensors, so should you.
If the head is not an 0331 TUPY it is more prone to cracking.
CJ7-Tim is offline
post #8 of 8 Old 01-25-2014, 11:39 AM Thread Starter
Amcxjkid
Many Jeepers report that Bosch O2 sensors and Jeeps do not play well together. Jeep installed NTK/NGK O2 sensors, so should you. If the head is not an 0331 TUPY it is more prone to cracking.
ok I will pick some up. Thanks!
Amcxjkid is offline
check engine , check engine light , exhaust , o2 sensors
