Where to find the Disco bracket... - JeepForum.com
post #1 of 4 Old 04-09-2011, 05:56 PM Thread Starter
newxj
1990 XJ Cherokee
I bought a set of skyjacker disconnects for my XJ and they didnt come with the brackets (for attaching them to the sway bar)... where can I find them?
I'm talking about the D looking thing with a hole in the top and two on the sides.
I've looked at Tractor Supply, but no luck.
Thanks,
Brian
newxj is offline
post #2 of 4 Old 04-09-2011, 06:08 PM
JFcavedweller
contact the vendor you bought them from, they should send them to you. if they don't, don't do business with them again and then let skyjacker know (hopefully you didnt get them straight from skyjacker and then they wont give you the part lol). skyjacker should send you the parts if the vendor fails, and im sure they will have some words for the vendor
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
JFcavedweller is offline
post #3 of 4 Old 04-09-2011, 11:45 PM
Dbiked
You could make those puppies pretty easy, Go to ACE "The helpful place". Get some fairly thick steal, Cut said steal to size with grinder, or saw, sense they sell it in strips you would only have to make one cut. Put in vise, bend, drill, and tada.
I would call first though. :P
Utah jeep crew member #32
Dbiked is offline
post #4 of 4 Old 04-10-2011, 08:51 AM Thread Starter
newxj
1990 XJ Cherokee
bought em used, so contacting my vendor or skyjacker is probably outta the question. I'll probably go to metal by the foot Wednesday and see if I can buy a 2" length of channel and just make my own.
newxj is offline
D30 vac disco, replace axle shaft from 89 D30 non vacuum disco? lyleorszulak807 XJ Cherokee Technical Forum 2 03-02-2010 03:07 PM
Somebody needs to find a seat bracket solution!!! compcrasher86 XJ Cherokee Technical Forum 1 02-23-2010 09:25 PM
Where can I find headlight adjustment assembly/bracket? SouthTXBowhunt XJ Cherokee Technical Forum 4 01-11-2009 09:47 PM
where to find rear hook bracket? JGriff99xj XJ Cherokee Technical Forum 1 07-01-2007 08:56 AM
Switching axles disco 30 to non-disco 30 bigjeepman XJ Cherokee Technical Forum 2 01-21-2007 04:34 PM
