Where to buy metric 10.9 bolts? - JeepForum.com
post #1 of 7 Old 05-07-2011, 11:48 PM Thread Starter
DerMeister
Where are you guys getting your grade 10.9 metric bolts?
I am getting down to the last steps on installing my offroad bumper with tie in brackets and re-doing my hitch. The bumper takes 10mm metric bolts, but I can only find grade 8.8(Grade 5). The nutstrip for the hitch takes what I beleive to be M12 bolts, but once again I can only find grade 8.8.
Do you guys think that grade 8.8 will be good enough? There are a total of 18 bolts back there holding the bumper, tie in brackets and hitch together.
DerMeister is offline
post #2 of 7 Old 05-08-2011, 12:09 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Fastenal.com, find a local branch.
If you have to mail-order, also check MRO houses - I usually use MSC Direct (www.mscdirect.com)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #3 of 7 Old 05-08-2011, 03:08 PM
mynameismyles65
1994 XJ Cherokee
napa carries them I'm pretty sure
mynameismyles65 is offline
post #4 of 7 Old 05-08-2011, 04:05 PM
no5son1962
I get them fron Ace Hardware
95 ZJ 4.0L 3 inch Lift
99 XJ 4.0L 4 inch Lift
no5son1962 is offline
post #5 of 7 Old 05-08-2011, 06:13 PM
Jcool
1993 XJ Cherokee
Fastenal is also where i got my bolts
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_) 1993 Jeep Cherokee Sport 4.0L
Jcool is offline
post #6 of 7 Old 05-08-2011, 06:14 PM
compcrasher86
fastenal or mcmaster carr are my favorite sources. In a pinch Ace or Loews works too
Matt
compcrasher86 is offline
post #7 of 7 Old 05-08-2011, 07:07 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I'm losing faith in hardware stores - most of their stuff is made in China anymore.
"Made in China" = "Counterfeit" probably nine times out of ten.
Case in point - I recently had to replace an oil pump for someone, the screws were bent. I went and got new screws - two different packages, for two different lengths of 5/16"-18 screw.
Both screws snapped with less than 20 pound-feet of torque applied!
I pillaged through my junk bin, found two screws of the right size, and put them in. Finished the job, then wrote an email to the fastener buyer at my hardware store and complained. No, they haven't changed their line - but it's a start.
"Cheaper" != "better" in most cases. I don't mind paying more for something that I know will work.
5-90 is offline
LT into Metric sizes?? 94HOCHEROKEE XJ/MJ Cherokee Non-Technical Forum 1 01-04-2009 06:42 PM
Metric? dirtdad XJ Cherokee Technical Forum 7 11-29-2007 03:18 PM
Metric Ton 44 vs reg D44? 9mmprn XJ Cherokee Technical Forum 4 02-16-2007 03:13 PM
Why metric..? beaterjeep XJ Cherokee Technical Forum 24 08-26-2005 09:05 PM
Metric Fubar XJ Cherokee Technical Forum 6 07-23-2004 09:06 PM
