When was the last time you saw a Factory Diesel XJ/MJ? - Page 3 - JeepForum.com
post #31 of 61 Old 12-19-2012, 01:03 PM
JSBach1775
1985 XJ Cherokee
Originally Posted by automan2164 View Post
I still haven't found another set of gauges... What do you have?
Rob
I believe a complete gauge/dash set from 85 Cherokee... have to dig it up and check. It also might just be the tach and speedometer set. I have a defective tach read out, with the needle just slowly climbing or dropping, or going all the way to the top RPM... the same happened with the other tach. That is why I obtained the second set. Have to check the sender unit... or whatever it uses for a sender. Likely a problem with that. Just now switching to 192 Thermostat to try ad seal the head gasket leak!?! Otherwise it is another new hd gasket within two years, only thins time proper torquing. It is a great vehicle and in great shape in all other respects... oh, a slight water leak somewhere around the drivers door or windshield?!
JS
JSBach1775 is offline
post #32 of 61 Old 12-22-2012, 02:55 PM
cherokee01_8873
Junior Member
cherokee01_8873's Avatar
Moved to europe last year and am currently looking at a 2000 XJ with a 2.5 turbo diesel and low miles.
Looking for Europe WJ with 2.7 Diesel
01 Cherokee ( Patriot Blue)
2in lift front 3in rear, transfer case drop, 30/9.50/15, Dynomax muffler.Trailer hitch. Alarm with remote start. Upgraded Speakers, Painted rims. Custom Flag mounts for Silver Lake. (Sold)
cherokee01_8873 is offline
post #33 of 61 Old 12-26-2012, 08:19 PM
miceanic
1990 XJ Cherokee
Just found out the MJ next door is a diesel in need of an alternator.
miceanic is offline
post #34 of 61 Old 12-27-2012, 01:10 AM
XJGuy07
1992 XJ Cherokee
I have only seen one diesel xj before. It was in an airplane hanger with its hood up and when I walked over to it I just sat there and stared stupidly at it for about 10 minutes. Someone had to walk over to tell me it was diesel. I felt a little stupid. I didn't even know they made a diesel motor. haha opps
XJGuy07 is offline
post #35 of 61 Old 03-03-2013, 10:47 PM
ILLGETYOU22
I have a 86 Comanche 2.1td that will be for sale shortly 80k 4wd runs good needs work has rust but frame is solid 203 550 2693
ILLGETYOU22 is offline
post #36 of 61 Old 03-04-2013, 09:38 AM
biggerbrowndog
Yep
I work at a gas station.
About a month ago
I seen a xj getting diesel,
But by the time I got out there it was gone,
Sad I wanted to talk to the guy.
Oh well,
Sunoco state at mackinaw
biggerbrowndog is offline
post #37 of 61 Old 03-04-2013, 09:40 AM
biggerbrowndog
Saginaw, mi
Btw
post #38 of 61 Old 08-08-2013, 02:00 AM
KG8893
There is a diesel XJ at the local salvage yard. been there a while, and I don't know if it is the 2.1 or 2.5... but if you are interested in parts I could snap a few pics next time I am there... PM me if interested, I don't get on here much anymore.
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #39 of 61 Old 08-08-2013, 05:41 AM Thread Starter
automan2164
1986 MJ Comanche
PM sent.
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #40 of 61 Old 08-23-2013, 05:09 PM
HawksWin
Wow. Absolutely love this! Checked out your post on comancheclub.com and your in Harvard?! Im down in Garden Prairie! Would love to see this thing! Maybe me and my XJ will see ya when were heading up to Delavan with the boat! I always cut through Harvard! Good find, and best of luck with the resto!
HawksWin is offline
post #41 of 61 Old 08-23-2013, 05:26 PM Thread Starter
automan2164
1986 MJ Comanche
Stop on by if you want, I am home tonight. Shoot me an email if you want to head by. automan2164 @ yahoo.com
Rob
post #42 of 61 Old 09-30-2013, 11:34 AM
KG8893
Diesel XJ at the yard was gone when I went.
KG8893 is offline
post #43 of 61 Old 10-22-2013, 10:21 AM
houseofdiesel
A few notes on the J8S I can share from my Winnebago experiences
change the oil pump driveshaft every timing belt change OR MORE OFTEN!!! It is the number one cause of engine failure after all these years, long shaft looks like an allen key/XZN tool that strips and fails, easily found under the vacuum pump 6" long (runs between the vacuum pump and oil pump)
Turbo is unique to the JEEP application, no new ones but rebuilding is possible still. The Winnebago has a much larger turbo very much like a Mercedes 617.95 turbo (3.0L 5cyl) again no longer available but rebuilding.
Rockauto has lots of parts available out of the UK, shipping is high but GREAT selection, just be sure you click on the EU flag when searching for parts not just USA this is how I get Winnebago powertrain parts at very reasonable prices, the dealer that remains is a crook for parts (compare a cam seal $3 to $20+!!!). There is also a garage just outside of Montreal Quebec Canada Robert Marleau that specializes, he has everything in stock and no problem shipping, no website just phone, speaks no english really just french but amazing person that shares his wealth of knowledge and always has what I need just Winnebago but most of the engine parts are the same.
They are absolutely great motors, so simple and so reliable due to the simplicity of it. Nothing complicated, no vacuum controls like old Mercedes diesels, well designed fuel system that NEVER leaks (injectors have permanent hoses for return lines), simple to work on starter, alternator, adjustments no special tools needed. When they work properly they are amazing little engines, they seem to stay fresher/have fewer issues vs the other european diesels, maybe due to the lack of use and winter driving.
In our Winnebago we manage 25mpg (us gallon) or 10L/100kms all day long, and hill climbs are no problem it has plenty of power on the highway, slow cruising due to the gearing and not fast off the line, but great for what it is.
The Jeep td is pretty rare, I see them once in a while about as often as a diesel Winnebago. I know of two Jeep Cherokee td for sale that are basically parts cars, full of mold inside and sitting for 10+ years, apparently running but far from road worthy and the mechanic selling them wants $5000 for the pair! Just because they are rare is his reason...
houseofdiesel is offline
post #44 of 61 Old 11-04-2013, 11:21 AM
ONX
ONX's Avatar
1986 XJ Cherokee
I just picked up a 86 2 door cherokee TD. I will post pics later today. I would like more info on the oil pump though.
Theres no such thing as overkill.
Originally Posted by urbanassault
And for The sake of humanity, don't pick your nose while driving, if the airbag deploys it will jam your figer up you nose killing you instantly!
ONX is offline
post #45 of 61 Old 11-05-2013, 03:56 PM
houseofdiesel
For the oil pump here are some steps
1-remove the vacuum pump on the drivers side lower engine block (below injection pump sort of behind alternator/ps pump
2-lift the allen key shaped driveshaft out of the hole carefully, with a magnet or pliers and a steady grip
3-inspect the ends of the driveshaft, they typically get rounded off with age not sure where you would source a driveshaft I am sure it could be made with tool stock, the garage I mentioned sells them.
4-replace the Oring on vacuum pump
5-carefully reinstall the driveshaft into the hole, "feeling" for the opening for it in the oil pump yes you can miss easily and drop down into the oil pan, so be patient and careful, use a flexible LED light to guide you it is not the easiest place to get your head into for a look!
6-reinstall vacuum pump, sometimes you need to play around to get the driveshaft to mesh up/mate, might take a couple attempts before it drops down into place
The driveshaft looks just like a long allen key maybe 6-8mm in diameter. I will dig around for my old used one and take a pic, it is approx 6" long.
I managed to change mine in half an hour, not a big deal job just don't drop the shaft!
Do you want a diesel Jeep from the factory? http://jeepdieselpetition.com Grecy XJ/MJ Cherokee Non-Technical Forum 14 12-21-2012 09:59 PM
Factory gas tank skid with factory class 3 trailer hitch??? C-Mil XJ Cherokee Technical Forum 4 04-03-2010 11:02 PM
has anybody swaped liberties turbo diesel, or any other diesel. teamskiawa XJ/MJ Cherokee Non-Technical Forum 1 03-24-2010 11:46 AM
I just replaced the factory steel wheels with factory alloys on my 99. ARgetni XJ Cherokee Technical Forum 1 01-10-2010 07:37 PM
Factory fog lights as well as factory underhood light? White-Knight XJ Cherokee Technical Forum 1 10-09-2002 01:42 PM
