Wheel spacers... am I going to notice a 1" spacer? - JeepForum.com
post #1 of 10 Old 06-10-2013, 07:03 AM Thread Starter
Xride
Thinking of doing a 1" spacer. I think it will put the wheels where they should be. But at the same time, will I even notice? Will it help me at all? Hinder me?
Is it worth the 120 bucks on a fairly stockish jeep?
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #2 of 10 Old 06-10-2013, 07:26 AM
dcorn
You'll probably notice it while steering at very low speeds. A spacer will increase the scrub radius and make it harder to turn when not rolling. Other than that, you might gain a bit of stability from the wider stance, but hardly noticeable.
It'll look better, and that's all that matters haha.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 10 Old 06-10-2013, 07:51 AM
mike_dippert
mike_dippert's Avatar
I was just reading up about spacers b/c I was thinking about making my own (custom thickness). I discovered that most wheel studs are 1.25" long. The spacer needs to be thicker than the stud length so it doesn't interfere with wheel mounting. You can always cut some off your studs, but then you can't remove the spacers without risking too little thread engagement.
mike_dippert is offline
post #4 of 10 Old 06-10-2013, 05:23 PM Thread Starter
Xride
I have no problem cutting them down if needed. Can always replace the studs.
I'm more worried about if they are hub centric or lug centric. And if there will be any issues getting the wheels centered properly.
Xride is offline
post #5 of 10 Old 06-10-2013, 06:37 PM
mike_dippert
Can't help there. I didn't make it that far before I quit reading.
post #6 of 10 Old 06-10-2013, 06:40 PM
WhiteOut
WhiteOut's Avatar
You want to get hub centric spacers. There is ZERO difference between a properly installed spacer and a backspaced wheel.
WhiteOut is offline
post #7 of 10 Old 06-10-2013, 09:07 PM Thread Starter
Xride
Are these hub or lug?
http://www.ebay.com/itm/Jeep-Cheroke...-/290647243462
EDIT, Hmm those don't seem like a very good deal actually once they add their crazy shipping.
Xride is offline
post #8 of 10 Old 06-10-2013, 11:05 PM
alexrule123
alexrule123's Avatar
Those are lug centric spacers.
These are hub centric http://www.spidertrax.com/Jeep-5-on-...l-Spacer-Kit_2
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #9 of 10 Old 06-11-2013, 06:30 AM Thread Starter
Xride
Thanks
3 lbs a wheel.... that seems heavy doesn't it?
Can I go 1.5" in the rear and like 1" in the front since it seems like the rear is narrower than the front stock?
Xride is offline
post #10 of 10 Old 06-11-2013, 07:36 AM
WhiteOut
WhiteOut's Avatar
Same width front and back.
WhiteOut is offline
