What's a Chrokeese? (build thread) - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > What's a Chrokeese? (build thread)
Unread 06-30-2014, 08:33 AM   #31
mschi772
mschi772's Avatar
1997 XJ Cherokee
Originally Posted by rjbruzan
It would be nice but I doubt it will get much better than that. Ron
Had my 96 up to 18.5 mpg in 50/50 mixed driving and 22 mpg highway, so you can stop doubting. I wasn't even close to finished with my 96 yet either. The biggest gains were yet to be made (i.e. aeromodding, switch to 235 highway tires from 225 AT's, and more).
Sent from my phone
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is online now   Reply With Quote Quick reply to this message
Unread 07-02-2014, 05:21 PM   #32
mschi772
mschi772's Avatar
1997 XJ Cherokee
Here's a VERY quick example of one of the possibilities for the Monstaliner paint job. I have a couple other ideas, but they'd require much more time to convey properly, so this is all you guys get for now.
Unread 07-02-2014, 05:41 PM   #33
DunmerBoy
me likey
COTM October 2014
- Build Thread -
DunmerBoy is offline   Reply With Quote Quick reply to this message
Unread 07-02-2014, 05:49 PM   #34
ninjakid
1987 YJ Wrangler
That combination of blue and grey looks very nice.
I like it.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline   Reply With Quote Quick reply to this message
Unread 07-02-2014, 05:56 PM   #35
mschi772
mschi772's Avatar
1997 XJ Cherokee
Disclaimer: the rendering's colors are obviously not meant to be a perfect match--it's more about conveying the pattern/idea. These are the likely two combo possibilities.
Unread 07-02-2014, 06:01 PM   #36
DunmerBoy
first combo in my opinion
COTM October 2014
- Build Thread -
Unread 07-02-2014, 07:57 PM   #37
Kevin108
+1 first combo, contrast FTW
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline   Reply With Quote Quick reply to this message
Unread 07-03-2014, 05:38 AM   #38
mschi772
mschi772's Avatar
1997 XJ Cherokee
Yeah, the first combo was my choice as well, but I figured I'd include the next darkest shade in case others disagreed with me.
Hmm, do I allow that gray to continue around the tailgate or stop it at the taillights (all blue on the tailgate; maybe paint the plastic piece above the lis plate gray)?
Unread 07-03-2014, 10:43 AM   #39
DunmerBoy
Originally Posted by mschi772
Yeah, the first combo was my choice as well, but I figured I'd include the next darkest shade in case others disagreed with me. Hmm, do I allow that gray to continue around the tailgate or stop it at the taillights (all blue on the tailgate; maybe paint the plastic piece above the lis plate gray)?
Definitely go around.
COTM October 2014
- Build Thread -
Unread 07-03-2014, 06:32 PM   #40
mschi772
mschi772's Avatar
1997 XJ Cherokee
Throttle body cleaned, Seafoamed the intake and fuel tank today. Had my fingers crossed that the neighbors wouldn't call the fire department--so much smoke. Throttle body and what I could see of the intake manifold was very dirty; previous owners were definitely "normal" people who never did this kind of stuff.
Hopefully I'll get brakes swapped from the 96 (had just put Black Magic pads with Centric rotors and Bendix shoes/drums on it) and the oil filter adapter O-ring changed this weekend.
Unread 07-04-2014, 02:08 PM   #41
Dezman121
Good build thread and look forward to more.
Dezman121 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2014, 03:11 PM   #42
Project1
clean xj !
Project1 is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 11:45 AM   #43
mschi772
mschi772's Avatar
1997 XJ Cherokee
Swapped brakes with the 96 today. Black Magic pads, Centric rotors, Bendix shoes and drums. New wheel cylinders and springs as well.
Unread 07-05-2014, 01:51 PM   #44
DunmerBoy
Man I am so jealous of that thing, are those the brands you recommend for the breaks? I'm starting I get some creeks from the back so I'm thinking y drums need work
COTM October 2014
- Build Thread -
Unread 07-05-2014, 03:03 PM   #45
mschi772
mschi772's Avatar
1997 XJ Cherokee
I love the Black Magic/Centric kit, and Black Magic is a member vendor here as well. Highly recommend them for the front. I went with Bendix due to reputation more than anything else. Rear drums: hard to tell if something is much better than another really.
This is literally what I bought:
Relined shoes-- http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
New drums-- http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
With Amazon Prime, it cost me $100 and I had them two days later. New wheel cylinders and spring kit cost me $29 at NAPA. If you need parking brake hardware, that's sold separately. I'd have gotten that if I had remembered it was separate, but I forgot and am reusing the old stuff (it seems to be relatively new anyway).
$230 for the pad/rotor kit from Black Magic (they sell a kit with new calipers as well if you happen to need them as well; if yours are fine, there's no need to waste the money on new ones)
http://www.shop.blackmagicbrakes.com...-477-67022.htm
You WILL need a 3/8" brake line wrench (aka flare nut wrench) and Kroil/Liquid Wrench/PB Blaster if you want to change your wheel cylinders. The bolts that hold the cylinder in place rust, and when I did this on my 96, one actually broke (the cylinders don't come with new bolts, so take care or have new ones on hand; not sure of their thread/length offhand, but they're 10 mm head). The nut on the brake line also likes to twist the line if you're not careful. I had to gently hold the line with a vice grip (take care not to crush the line) in order to break the nut free of the line.
The wrench is pretty much necessary. If you want to try a plain crescent wrench, just remember that I warned you that it can very easily strip the nut. They're not expensive; use the right tool for the job.
Tip: if you change your drums' shoes, when you remove them, you'll see areas on the backing plate where the shoes rest and rub (you'll know these areas by their smoothness and lack of rust compared to the rest of the plate. Before installing your new shoes, dab just a thin layer of grease on those areas--your shoes will move more freely and will be less likely to *CLUNK* when braking. I use Evinrude Johnson Triple-Guard Grease. It's sold online and in most boating stores. This is also an FANTASTIC grease to use on your slip yoke by the way and is the primary reason I have some in my garage.
