What will i need to do with a 6.5 lift - JeepForum.com
post #1 of 11 Old 08-20-2008, 10:03 PM Thread Starter
NIN20
I just bought a '00 XJ off a buddy of mine. It has a 3.5 RE lift on it now, but as soon as i can get some money together i want to get a 6.5 rusty's. My question is what else will i need to get along with the lift.
Thanks
PS- I just joined the forum and i'm pretty pumped about my new jeep
NIN20 is offline
post #2 of 11 Old 08-20-2008, 10:18 PM
mofo46
1989 XJ Cherokee
your gonna need a cv driveshaft and a slip yoke eliminator so that your driveshaft doesnt snap
mofo46 is offline
post #3 of 11 Old 08-20-2008, 10:28 PM Thread Starter
NIN20
Im pretty new to the jeep scene, but i want to be like a sponge and soak up as much info as i can, What is a good SYE and cv driveshaft, and where is a good place to get them from?
NIN20 is offline
post #4 of 11 Old 08-20-2008, 10:31 PM
mofo46
1989 XJ Cherokee
uhh idk exactly the kinds of SYEs but id look on rough countrys site they have some decent ones and not that expensive either like 250 a piece
mofo46 is offline
post #5 of 11 Old 08-20-2008, 10:36 PM
famous1688
1989 XJ Cherokee
advance adapters makes a good sye, and i just got a driveline from rubicon express and all the u-joints and cv are spicer... which are very good components...
famous1688 is offline
post #6 of 11 Old 08-20-2008, 10:54 PM
aircruiser
aircruiser's Avatar
check here if you want to learn alot more on slip yoke eliminators
http://www.jeepforum.com/forum/f11/official-sye-slip-yoke-eliminator-thread-all-read-426483/
youll also need to mess around more with the steering. depending on what tires you want to go to and what axles you have, you may need to upgrade as well.
aircruiser is offline
post #7 of 11 Old 08-20-2008, 11:27 PM
littleblackXj
1993 XJ Cherokee
At 6.5" you might want to invest in a long arm kit as well. Not necessary but definitely improves the ride when driving on the street.
1993 Jeep Cherokee
Rubicon Express 4.5" Lift
33" Wrangler Duratracs
30/44 4.88s Disks all around
Rear Detroit/Open front
littleblackXj is offline
post #8 of 11 Old 08-21-2008, 12:54 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
it looks like that kit has a lot of options. so i would get the most expensive arms with the kit (assuming youre not getting the long arm kit). but for $300 more i would get the 5.5" RE lift since its a lot more complete. just my .02
1990JEEPXJ is offline
post #9 of 11 Old 08-21-2008, 08:13 AM Thread Starter
NIN20
Another question that I had was should I go with the 6.5 long travel kit or the 6.5 spring pack kit. What are the differences and advantages of each?
NIN20 is offline
post #10 of 11 Old 08-21-2008, 08:24 AM
XJLI
XJLI's Avatar
1993 XJ Cherokee
you should not go with rustys. that is the disadvantage.
his springs are pretty good and shocks are OK... but other components arent rated too highly.
Factory Four Link
XJLI is offline
post #11 of 11 Old 08-21-2008, 08:51 AM
96cherokeeclass
his springs are good, his shocks are stiff as all hell which is fine unless you have fillings (mine already rattled out). Saying his other components arent rated too high is putting it nice. The best thing you'll get from a rusty's lift is the cool sticker with the XJ flexing.
go to jeepinoutfitter.com
find a lift there, Jason and his whife are great people, they'll take care of you.
and their stickers are pretty cool too.
- 07 WK - CRD
96cherokeeclass is offline
2" Lift, no rear sway bar...should i be nervous on a jack lift Topgun514 XJ Cherokee Technical Forum 4 04-18-2011 01:46 PM
3" Pro Comp lift and Daystar econo lift THEANGRYAX XJ/MJ Cherokee Non-Technical Forum 1 02-05-2010 07:47 PM
Is my informal list of lift parts complete? (3.5-4" of lift not from a kit) GeologistFelix XJ Cherokee Technical Forum 1 12-28-2009 10:10 PM
Any difference between lift brands? AKA: whats the best lift brand? boodis XJ Cherokee Technical Forum 15 01-03-2009 10:26 PM
a Full Traction 3.5' suspention lift and a 1.5' budget lift Supahfly113 XJ Cherokee Technical Forum 8 01-03-2008 08:01 PM
