What should I do first? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > What should I do first?
Advance Adapters SYE KitsOconee Off-Road Jeep Night!SYE Kits from CCOR! 706-207-4140
Unread 08-20-2014, 06:27 AM   #1
Minnebrew
Hi,
I have been poking through threads but unsure what I should start on first. I have a 01 XJ and have a few small repair projects but am unsure what fun/tinkering items I should line up after I finish my repair projects.
Up for any thoughts or ideas.
I will try to post photos soon.
Minnebrew is offline   Reply With Quote
Unread 08-20-2014, 06:45 AM   #2
MagicNelson
Depends on what your goals are for the jeep. Is this your daily driver? Or do you plan on making it a trail rig?
MagicNelson is offline   Reply With Quote
Unread 08-20-2014, 07:02 AM   #3
DNFJ
DNFJ's Avatar
This, and budget will be the deciding factor.
Wannabe Desert Rat
'00 XJ 6.5" w/ 33s
Built Not Bought #704
DNFJ is offline   Reply With Quote
Unread 08-20-2014, 08:27 AM   #4
caronaxtr
X2. Options are endless
caronaxtr is online now   Reply With Quote
Unread 08-20-2014, 11:17 AM   #5
Minnebrew
It is my daily driver so can't go trail crazy yet. Budget and project wise I want to start small and work my way up. I am capable of almost all projects skill wise but just kinda having writers block on what to do first. Hence why I am open to ideas
I have thought about the improving the mpg project. But would like to upgrade the jeep overall.
Unread 08-20-2014, 12:17 PM   #6
rugsucka
Angry Eyes.
Nightshade.
Monster Energy Decals.
Anything remotely ricey.
Cheap HF or WallyWorld Fog Lights.
Please don't do any of these.
Consider an entire vehicle fluids change, a full cooling system restoration assuming the radiator is fine - water pump, t_Stat, upper & lower rad hoses, serp. belt, coolant flush, and a full chassis and drivetrain lubrication.
Then the rest is personal. A 2" Budget Boost and some trimming can have you driving 31" tires for under $200 plus the cost of tires. That's what I'd consider as my first enhancement of any XJ even if it's only destined to be a DD.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote
Unread 08-20-2014, 12:23 PM   #7
Teej
Jordan's Bish
Teej's Avatar
Truck nuts.
Teej's '01 XJ Build Thread
Instagram: @tj_chciuk
CoTM March 2014
Teej is online now   Reply With Quote
Unread 08-20-2014, 02:50 PM   #8
ladytex70
Originally Posted by Teej View Post
Truck nuts.
Eyelashes..in hot pink and add the matching grill mustache :-)
ladytex70 is offline   Reply With Quote
Unread 08-20-2014, 04:00 PM   #9
Minnebrew
I was thinking body mod it into a weiner mobile
Unread 08-20-2014, 04:02 PM   #10
Minnebrew
I was thinking body mod and turn it into a weiner mobile
Unread 08-20-2014, 06:23 PM   #11
rugsucka
Just pick up a new Cherokee if you want a wiener-mobile.
Unread 08-20-2014, 06:33 PM   #12
wizardPC
Put money back for the eventual "HELP! IT WON'T START!" thread
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is online now   Reply With Quote
Unread 08-20-2014, 09:37 PM   #13
Minnebrew
I grew up in the help it won't start car house
Unread 08-22-2014, 11:35 AM   #14
Minnebrew
Otherwise any good xj builds to recommend? There are so many one can get lost
Unread 08-22-2014, 03:17 PM   #15
AKIQPilot
AKIQPilot's Avatar
As already posted. What do you want to build? Mall Crawler or Rock Crawler? Trail Rig or Mud Buggy?
It's kinda pointless to give you lots of advice until we understand your end goal.
AKIQPilot is offline   Reply With Quote
