What's your oil filter? - Page 2 - JeepForum.com
View Poll Results: Whats your oil filter?
K&N 2 3.70%
NAPA 25 46.30%
Fram 12 22.22%
Purolator 15 27.78%
Voters: 54. You may not vote on this poll
post #16 of 58 Old 09-21-2012, 06:26 PM
DullesJeep
1995 XJ Cherokee
Am I really the only XJ owner on these forums that uses the K&N filter?
I remember past discussions involving oil filters, and yet again, I was the sole member who used K&N's.
I just like em because of the 1" nut on the top. I think there's other filter brands out there with a similar nut on the top of the filter, but K&N was the first brand I found that had em, so that's what I stick with. And in case you're wondering why I need a 1" nut on the top of my filter, it's because I had a bad experience before involving a cheapo mopar filter that got stuck to the oil filter adapter. Ended up ripping off the can and filter, and using a sawzall and chisel to notch the threaded bottom part of the filter, and get a starting point to hammer the thing off with a chisel.
It's a Jeep thing. Sometimes I don't even understand.
DullesJeep is offline
post #17 of 58 Old 09-21-2012, 08:23 PM
whitexj98
I use a Mopar filter from wallmart. If you cant get the filter off by hand, it was installed way to tight.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #18 of 58 Old 09-22-2012, 02:14 AM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
I use Mopar filters as well.
14JK -
98XJ
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #19 of 58 Old 09-22-2012, 11:41 PM
DullesJeep
1995 XJ Cherokee
Thing is, in that certain incident, I had only installed it hand tight previously.
post #20 of 58 Old 09-23-2012, 12:27 AM
Reptile
1991 XJ Cherokee
Anything BUT Fram. Purolator is the best for your money.
Next time lubricate the filter's gasket with a bit of engine oil before you put it in; you should be able to remove it by hand. If you still can't get it off, get the engine warmed up.
Reptile is offline
post #21 of 58 Old 09-23-2012, 12:51 AM
the_weirdo
the_weirdo's Avatar
Motorcraft FL1A as other stated. Great filter, only $4.
the_weirdo is offline
post #22 of 58 Old 09-23-2012, 06:43 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by WBZ View Post
I have always used fram but a friend recently had some quality issues with some fram products which has made me rethink my allegience
Your friend isn't alone. Ditch the Fram.
Nickname is OCOD. Orange Cans Of Death.
cruiser54 is offline
post #23 of 58 Old 09-23-2012, 07:04 AM
Tdog02
Wix for the Ford FL-1A is 51515 and is quality. If you are changing at 3-4k mileage you could use the FL-1A cause its a little cheaper. It's bigger than stock. Lots of good choices to protect the engine. Make it magnetic by getting some magnets from a craft store and put them around the can, then a strip of duct tape. (Don't judge me, I'm cheap and it works)
it is what it is except when its something else
Tdog02 is offline
post #24 of 58 Old 09-23-2012, 07:16 AM
Camfam07
AGREE'D... Wal-Mart mopar, or WIX all the way..
Camfam07 is offline
post #25 of 58 Old 09-23-2012, 07:59 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Napa Gold/Wix, I will run K&N if they are onsale
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #26 of 58 Old 09-23-2012, 08:12 AM
cactus_jack
NAPA for this guy. (BTW, NAPA Gold filters are made by Wix)
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #27 of 58 Old 09-23-2012, 08:47 AM
Bbasso
Mopar.
Bbasso is offline
post #28 of 58 Old 09-23-2012, 11:30 AM
Trons
Am I the only one who used Mobile 1? Should I change?
'03 TJ Rubicon
'16 KL Latitude
'91 Cherokee Laredo, Stock - Sold
'98 XJ - burned :(
Trons is offline
post #29 of 58 Old 09-23-2012, 02:19 PM
DullesJeep
1995 XJ Cherokee
Going to assume that was the issue, as it only happened once when I first got my jeep and knew little to nothing about working on it.
Since then I make sure to lube up the gasket every time. Also, checking to make sure old gaskets aren't stuck to the filter adapter is something I learned along the way as well. Never had it happen, but I've heard enough stories to know to double check. It's one of those easy to overlook issues that lead to a big PITA once you realize it has happened.
post #30 of 58 Old 09-23-2012, 06:54 PM
stephenfarris
Me too-holds extra oil!
stephenfarris is offline
Bad NEW oil filter?? jdcountryboy91 XJ Cherokee Technical Forum 7 09-29-2009 06:19 PM
Changing Air filter with performance filter vecky4858 XJ Cherokee Technical Forum 2 05-08-2009 09:39 PM
Fuel Filter 99 4.0 Cherokee?? 159.98 for the filter alone? Mike94ZLT1 XJ Cherokee Technical Forum 24 05-07-2007 05:04 PM
Update: Cone Filter VS Drop in Filter ..... trailblaze XJ Cherokee Technical Forum 4 07-08-2006 12:55 PM
New Air Filter Rescue XJ XJ Cherokee Technical Forum 24 09-22-2005 08:22 AM
