What's a Chrokeese? (build thread) - Page 6 - JeepForum.com
 3Likes
post #76 of 255 Old 07-24-2014, 12:45 PM Thread Starter
mschi772
1997 XJ Cherokee
Originally Posted by Teej
I've got sound deadener sitting in my living room for install maybe this weekend. Total weight is just over 100 lbs IIRC, and this is for the roof, hatch, and all four doors. Should be fun, though. And quiet.
I probably won't be doing a full sound deadening this year, but I'll probably deaden the firewall and floor while I have the dash out. I'll probably do the rest next year.
Sent from my phone
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #77 of 255 Old 07-24-2014, 02:00 PM
jeepkid03
Winning
jeepkid03's Avatar
In addition to blocking outside noise it should also enhance the quality of sound from your speakers.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #78 of 255 Old 07-24-2014, 03:00 PM
CEScuzzy
Originally Posted by mschi772 View Post
I will be painting it in the pattern pictured earlier...
I want to see how it'll look with the color combination, because I'm thinking about doing a two-tone on my '01 in similar colors, but with the light grey/silver below the ridge in the door.
Excited to see how this turns out!
-Scuzz
"Some Assembly Required" is a target, not a deterrent.
CEScuzzy is offline
post #79 of 255 Old 07-24-2014, 04:34 PM Thread Starter
mschi772
1997 XJ Cherokee
Yep, I'm looking forward to that as well. I'll be poly filling my sound bar as well as baffles that will be wrapping my front mids (component tweets will be likely).
Sent from my phone
mschi772 is offline
post #80 of 255 Old 07-24-2014, 06:26 PM
VegasGT
1988 MJ Comanche
Keeping an eye on this one. Nice choice on the HD Offroad stiffeners, btw. Some form of stiffeners are pretty crucial to an XJ build if you intend to get a long life from one.
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline
post #81 of 255 Old 07-27-2014, 05:47 PM Thread Starter
mschi772
1997 XJ Cherokee
Swapped my 703 injectors from the 96 today. Still gotta swap the 5-90/KWiP batt cables over as well as a pair of speakers, then the 96 will be full unmodded and ready to be sold (I won't be parting it out--it doesn't need much to be back to normal and driving around again).
Tune-up is coming soon and will consist of:
  • MSD coil
  • Magnecore wires
  • Autolite XP985 plugs gapped to at least 0.045 if not as high as 0.065 if I can get away with it
  • brass cap/rotor
I ordered these parts through Nick Ianuzzi (aka Kolak kolak@aol.com). While his kit usually has Autolite Platinum plugs, he is willing to supply iridiums to me for a little extra, and I always try to support quality Jeep vendors when I can.
P.S. I'm also trying to keep post #2 updated with the current status of the Chrokeese from now on.
mschi772 is offline
post #82 of 255 Old 07-28-2014, 06:48 PM
ninjakid
1987 YJ Wrangler
You probably already know about it but autolite has a rebate on their plugs.
I was ordering ap985s at the time so I wasnt really paying attention to the others but I believe it's a 2.50 rebate a plug for the xp's.
Gotta question for you.
For the brake clunk you have, if you jack up the side making the offending noise and push/pull the tire in and out can you move the axle shaft in and out of the axle a small amount?
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #83 of 255 Old 07-29-2014, 03:41 AM Thread Starter
mschi772
1997 XJ Cherokee
Yes, and that is quite normal for C-clip axles like the 8.25 as long as it is only a very little amount. It is not the source of the noise. I recently loosened my lugs, wobbled the butt of the Jeep back and forth a bit, and retightened the lugs. The clunking is gone, and I'd say any irregular braking forces (surging) have been reduced by 90%. I'm almost totally certain my problem stems from the decayed drum brake pilot flange as described in the TSB I linked earlier. I'll deal with that at a later date.
mschi772 is offline
post #84 of 255 Old 07-29-2014, 10:28 AM
ninjakid
1987 YJ Wrangler
Got it thanks.
Recently the rear left brake on my families XJ started making a clunking/thud sound on braking.
I took it apart and the only thing that seemed to possibly be a issue was I could push and pull the axle shaft a tiny bit and it'd clunk each time.
Although now that I put it back together the noise has at least temporarily gone away.
Since 96 was the changeover year for the 8.25 I might be dealing with the same flange issue you are.
ninjakid is offline
post #85 of 255 Old 07-31-2014, 11:38 AM Thread Starter
mschi772
1997 XJ Cherokee
Despite the gas that was leaked during the injector swap and the gas that was lost when one of the injector o-rings failed (no fire, but a reminder to get a fire extinguisher in case I'm not as lucky next time), the last mpg check came out to be 19.7 mpg for my mixed style commuting.
Sent from my phone
mschi772 is offline
post #86 of 255 Old 07-31-2014, 11:51 AM
DunmerBoy
Sent from my phone
thats great! I'm sitting over here hoping for 15 of a similar style commute haha
COTM October 2014
DunmerBoy is offline
post #87 of 255 Old 08-02-2014, 10:21 AM Thread Starter
mschi772
1997 XJ Cherokee
So I can't find anyone to install my frame stiffeners. There's a welder next door to where I work, but after seeing the job they just did to one of our (my company) machine's trailers, they won't be getting my business EVER (awful prep and terrible welds). Every reputable body shop (and many that I've heard nothing about as well) closes before I ever finish work or can get to them after work. None are open on Sat despite some of them claiming otherwise on their web sites... I leave my house at 5 am and am rarely home before 5 or 6 pm. I will not drop my vehicle off with anyone without first meeting them, seeing their shop, and getting an estimate first--won't happen. How's a guy with a real job supposed to ever get something like this accomplished with all of these places open until 5 on weekdays only? At this point, all I want are estimates, and I can't even get that.
Yeah, I'm frustrated.
Sent from my phone
mschi772 is offline
post #88 of 255 Old 08-02-2014, 06:19 PM
Teej
Hey man, I started my SDS deadening today. Took a video of an untreated door vs a treated door. Thought you might like to see the difference. The door shutting doesn't sound too different because my doors are removable and therefore don't line up 100%, but the difference in knocking is HUGE.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #89 of 255 Old 08-02-2014, 06:31 PM
Muddy97Cherokee
1997 XJ Cherokee
Nice two door!! Makes me jealous! Good build so far and liking the future plans!
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #90 of 255 Old 08-03-2014, 03:50 PM Thread Starter
mschi772
1997 XJ Cherokee
Changed the oil filter adapter O-ring today. I did this on my 96 shortly after buying it, and it was hell then. Even applying some of the things I learned that time around, my neighbors got to hear lots of colorful language today.
I know I've been light on photos lately. I have so much to do (not just Jeep stuff) and so little time that I haven't been remembering. When I tackle larger projects, I'll likely remember.
mschi772 is offline
