What's a Chrokeese? (build thread) - JeepForum.com
 2Likes
post #1 of 246 Old 06-27-2014, 04:20 PM Thread Starter
mschi772
1997 XJ Cherokee
Now
(New photos coming soon since autumn suspension install)
Lighting
  • Cibie headlights (ECE) on relays
  • Osram 70/65W bulbs
  • Parking lamps modded to function as daytime running lamps using Webb Electric module purchased from Daniel Stern Lighting
Body
  • HD Offroad Engineering frame stiffeners--front, mid, and rear
Brakes
  • Black magic brake pads with Centric rotors
Ignition
  • MSD coil
  • Magnecore spark plug wires
  • Autolite XP985 iridium plugs gapped to 0.050"
  • Battery cables by Kelly's Work in Progress (aka 5-90)
  • NAPA Legend 8434 battery (1020 CCA @ 32; 850 CCA @ 0)
Engine
  • 703 injectors
  • Pennzoil 5w30 with Wix/Napa [5]1515 oversized filter
Exhaust
  • 2.25" stainless
  • Doug Thorley HDX-634Y header
  • Stainless spun AP catalytic converter
  • Stainless Flowmaster 50 Series Delta Flow muffler
Transmission
Transfer case
  • NP231J
  • Novak Conversions transfer case shifter linkage
Suspension
  • Bilistein 4600 shocks
  • Liquid Iron Industries slider boxes for leaf springs
  • Moog +2 front springs, Dorman rear leaf springs
Steering
Axles
  • 3:55 gear ratio (D30 + Chysler 8.25)
  • P235/75r15 Winter tires: Firestone Winterforce UV (no studs) Summer tires: Kumho Road Venture APT KL51
Interior
  • UltraGauge EM Plus
Audio
  • Custom fiberglass 10" subwoofer enclosure mounted inside cargo "cubby" (similar to JL Audio's Vantage model that used to be made for the XJ)
  • JVC KD-AHD79 receiver with bluetooth
  • Pioneer 10" Stage 4 subwoofer (TS-W252PRS) powered by Pioneer Stage 4 amp (Pioneer PRS-D1200M)
  • Pioneer 6.75" component speakers rear (TS-A1605C)
  • Pioneer5.2.5" component speakers front (TS-A1305C)
  • Clarion 50 x 4 amp (XC1410)
mschi772 is offline
post #2 of 246 Old 06-27-2014, 04:21 PM Thread Starter
mschi772
1997 XJ Cherokee
Then
Sadly, I was not able to snap a photo of it before it was mailed-away to be corrected, but my new XJ was listed on its title as being a 1997 Jeep Chrokeese. Since I'm not a person who names vehicles, I figured that was as good as any for a name for this build thread that I've promised everyone.
Over the next millennium or two, I will be attempting to keep this thread updated with my adventures in owning my 1997 Cherokee SE. I also hope to be able to make some educational posts along the way for others to reference as my particular style isn't represented here quite as much as others' styles.
This vehicle is a daily driver. It will be built with that as it's primary purpose. Secondary to that, it will be required to be capable at or above stock levels. I don't go wheeling for wheeling's sake. I DO go off road for a variety of practical reasons however, and it will be expected to be capable of doing whatever I ask of it at any given time. Whenever possible, it will be improved beyond its factory design. On a spectrum from "Daily Driver" to "Expedition" to "Mudder/Rock Crawler," I aim to land somewhere between DD and Expo.
My old 96 will be providing some of its upgrades to the 97, but this time around I'll try to document their actual installation at least at a superficial level since many things already have write-ups out there that are far better than anything I could compose.
A preview of things to come (not an exhaustive list of plans; subject to change):
  • 3x e-fan conversion
  • Aux trans cooler
  • Possibly an oil heat exchanger
  • Brown Dog motor mounts
  • Addco sway bars front and rear
  • Misc aero mods (modified air dam, front skid and/or custom belly pan made from sheet metal or coroplast, removable grill blocks)
  • Sound deadening using process explained at SoundDeadenerShowdown.com
  • Possibly Grand "Chrokeese" seats
  • Monstaliner paint job (blue/gray)
  • Fringe valve body adjustment
  • Maybe a WJ steering pump
  • Detroit Truetrac in the rear would be nice--if it happens, it would likely be paired with a currently undetermined selectable locker in the front
mschi772 is offline
post #3 of 246 Old 06-27-2014, 04:31 PM Thread Starter
mschi772
1997 XJ Cherokee
I've already found something needing to be fixed after less than 24 hrs. Hooray! It's no big deal--just found the bracket under the center console glove box has broken. I know ccooper1234 over at CherokeeForum has been making metal replacements and selling them for like $60-70 for quite awhile now--http://www.cherokeeforum.com/f74/199...racket-158249/ Would he be my best option?
mschi772 is offline
post #4 of 246 Old 06-27-2014, 04:41 PM
Teej
I got my shipment from Don at sounddeadenershowdown a few days ago. Got CLD tiles, CCF, and MLV (with all the glue and velcro and whatnot) for the roof, both doors, and the hatch. He precut a lot of it for me and everything looks to be top quality. It'll be installed hopefully next week.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #5 of 246 Old 06-27-2014, 04:46 PM Thread Starter
mschi772
1997 XJ Cherokee
How much did you end-up paying? The shipping on the MLV especially must be killer, but I can't find a local source for anything even close, so I suppose I'll have to bite that bullet when the day comes.
I'll likely be doing a full job on the entire floor and doors/sides. I may only use CLD on the liftgate and roof at least at first.
mschi772 is offline
post #6 of 246 Old 06-27-2014, 04:51 PM
DunmerBoy
Glad to see the new beaut! do the aux/fog lights up front work?
COTM October 2014
DunmerBoy is offline
post #7 of 246 Old 06-27-2014, 04:52 PM Thread Starter
mschi772
1997 XJ Cherokee
They work, but they're not on relays (just batt-->switch-->lights-->ground), are garbage, and to add insult, are aimed terribly. I'm ripping it all out as soon as I get around to tinkering.
mschi772 is offline
post #8 of 246 Old 06-27-2014, 04:58 PM
DunmerBoy
gunna replace them or just can the idea?
COTM October 2014
post #9 of 246 Old 06-27-2014, 05:17 PM
ECL
I epoxied my console bracket and so far, a year later, still holding. Just basic marine epoxy from Ace Hardware.
seaweed88 likes this.
ECL is offline
post #10 of 246 Old 06-27-2014, 05:23 PM
ninjakid
1987 YJ Wrangler
Your new Cherokee looks nice.
Can't wait to see what you do to it.
Can't believe I've never heard of those sliders until now.
Better stability, ride quality and a 1" lift over stock?
Three things I've wanted wrapped up in one single package.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #11 of 246 Old 06-27-2014, 05:41 PM
Teej
I live close so shipping for all of it was IIRC $50. So $470ish total.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #12 of 246 Old 06-27-2014, 06:38 PM
AKIQPilot
Man thats a good look Cherokeese. Don't see many 2 door new body style XJ's around here. That one is in great shape.
AKIQPilot is offline
post #13 of 246 Old 06-27-2014, 07:22 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Once you go 2dr you'll never go back.
Nice find on the new XJ.
***Chris***
chris87xj is online now
post #14 of 246 Old 06-27-2014, 07:33 PM
DunmerBoy
are you going 235s?
COTM October 2014
post #15 of 246 Old 06-27-2014, 08:21 PM Thread Starter
mschi772
1997 XJ Cherokee
The sliders are 0" lift. The 1" rake will come from using Up-Country springs.
I thought of JB Welding it, but one side of the bracket is broken into many pieces and can't realistically be salvaged.
are you going 235s?
Yes. When I can, I'm going to swap tires with my 96 since my Kumho SAT's have much life left yet. They're 225's, but in the future I'll be on standard load P235's.
These lights are going bye-bye. When the money is available (I'm not a wealthy person), fogs by Cibie or IPF will go under the bumper. Then after that, MAYBE some pencil/driving lamps will go on top of the bumper and/or on a roof rack that may or may not exist some day.
mschi772 is offline
