What to look for when buying used Cherokee?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > What to look for when buying used Cherokee??
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 03-13-2014, 05:44 PM   #1
Bot
I'm familiar with TJs but looking at a 1998 Cherokee Classic with 158K on it. What should I look for specifically? Are there any known issues I should check for before pulling the trigger. The guy wants 2700.00 which strikes me as cheap. He states it is in excellent condition with no rust. I'm assuming it came from down south.
This woudl be for our daughter to drive so I want to be as picky as possible.
98 Sahara project underway. 2.5 RC lift and that's about it so far
Sold 2005 Rubicon 3" lift, 33 MTZs, Superwinch, A to Z bumper and rock rails
Bot is offline   Reply With Quote
Unread 03-13-2014, 06:02 PM   #2
BlueRidgeMark
1994 XJ Cherokee
Crawl under it and verify that "no rust" claim. Especially the frame rails. It's a unibody construction, and you don't want any rust there.
If it has power windows, operate ALL of them from the driver's controls, AND from each individual door. Also, do it both ways while moving the driver's door through it's full open to full closed. It's not unusual to have frayed wires going to the driver's control, which results in the other window switches not working reliably.
Other than that, all the usual stuff. Check all the fluids, both for level, appearance, and SMELL. Drive it long enough to get it good and warm, and make sure the electric fan comes on.
If it's really as cherry as he says, with that mileage it's a really good price.
BlueRidgeMark is offline   Reply With Quote
Unread 03-13-2014, 06:22 PM   #3
Bot
Thanks for the advice. I'll check out those things tomorrow. The guy has a small used car lot at his mechanic shop and just buy these at auction, put a little work in them and sell. He even said he would warranty it for 30 days bumper to bumper and then 1 year on the engine and tranny. That helps my decision as long as the body and frame are clean like he says.
Unread 03-14-2014, 07:48 PM   #4
rugsucka
Take a large flat head screwdriver and poke around the frame where the gas filler hose passes thru, poke around the foot wells - especially the driver side foot well, poke the rockers at the rear door just in front of the rear tire. These are all very common rust areas.
When you inspect the engine and under it, a small oil leak at the back of the engine is probably the valve cover gasket leaking down (engine tilts to the back) and is most often NOT the rear main seal. Easy fix.
It would also be wise to get the front axle up on jackstands and verify the condition of the tie rod ends, the ball joints, and the unit bearings. Easy to do if you have the time and tools, expensive to have done by a mechanic.
Put it in 4WD on gravel or dirt or grass and drive it turning the wheel to full lock in both directions. This will confirm that it can shift in and out of 4WD and also give you an indication if the axle shaft Ujoints are shot or not. As above, not hard or expensive if you can do it yourself. 20-30 bucks in parts per side, but multiple hours if a shop bills it by the book.
Take the rad cap off and look at the condition of the coolant. It should be bright green, not rusty or oily looking.
Remove the Oil Cap and look inside for excessive sludge, signs of coolant contamination (white sluge - a bit can be from winter short drives and moisture. A significant amount of white sludge is a bad sign that the head gasket is gone.
Take a look at the rear bumper caps where they cover the lower quarter panel - this is a good place for rust to start as well. Rust around the front windshield frame is not necessarily common, but happens.
Oil Pressure should be 50+ under load, and can settle to low teens at idle when warm. Nothing to worry about for a 4.0L engine.
Look at the rear axle - if the bottom of the axle housing is a flat lip as opposed to roundish it will have a good 8.25 rear axle. Inspect the front and rear pinion seals as well when you're under there. They are common leaks, and once again are cheap parts, but need to be done correctly or it gets $$$.
I've been a bad boy to my '00 XJ and pounded on it wheeling, but always maintain the cooling, engine, tranny, and axles. I'd drive it across the country if it wasn't such a pig on fuel and not as fun to drive on the highway as it was when it was stock many years ago. I trust it to be reliable explicitly.
Good Luck with the Purchase.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote
