What kind of MPG's do you get out of your cherokee? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > What kind of MPG's do you get out of your cherokee?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 02-15-2011, 11:04 PM   #16
DerMeister
I get 10mpg winter.
About 17mpg summer, with 19mpg being best possible.
DerMeister is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 11:10 AM   #17
bdodge
1997 XJ Cherokee
Some people say that a stretched timing chain could be the culprit, I've tried everything to get back up to my 21 mpg highway, timing chain is next there is quite a bit of slop in mine, can hear it slapping the cover lol.
97' Cherokee sport 2 DR / 4.0 Power Tech, 5 spd MAN, Command trac / Dana M30/181MM front axel, Corporate 8.25 rear axel / 6.5" Bastard lift, 31X10.5 Daytona futura's on Cragar 15X8 soft 8's, Logans Metals Front winch bumper, Flowmaster super 44, Magnoflow high flow cat
bdodge is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 12:51 PM   #18
smitty81
Well, I did use the 4x4 a LITTLE.
Maby with that and the extreme cold and old ignition parts, it all added up.
I will run it again with techron, no 4x4 and the ignition tune up and see what happens.
Temps coming up slightly here.
smitty81 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2011, 04:47 PM   #19
phmaris
Originally Posted by DerMeister View Post
I get 10mpg winter.
X2 on those numbers. This past month with all the snow and freezy temps, Im lucky to go 200 miles on a tank of gas.
phmaris is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 01:09 AM   #20
toyotaguy
I've been amazed how much my mpg dropped when I use the 4x4 even a little, it makes a big difference, but when the roads are rough it's worth it.
toyotaguy is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 02:05 AM   #21
1990JEEPXJ
1990 XJ Cherokee
13-15 here on 33's and stock gears
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 02:09 AM   #22
Swagger_Wagon
14-17 on 3:55s and 31s. It's gone down since I've put on my flowmaster super 44 though. Nothing wrong with the muffler, it just makes me want to floor the skinny pedal at every light
Not to mention my roofrack with my spare tire and hi lift on it acts like a mini sail on the highway
Just imagine a brick traveling at 70 mph with a mast and sail hanging of the top
P.J. O'Rourke
The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve. Okay, were a little crazy to have a Jeep for a daily driver. But if we go off our meds, we might wind up in a Prius
Swagger_Wagon is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 06:17 AM   #23
Millermagic
10. I do 100% city driving and constant short trips. Combine that with the cold and it's just bad gas mileage.
However, on the highway cruising it gets 18 or so.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline   Reply With Quote Quick reply to this message
Unread 02-17-2011, 09:45 PM   #24
c0ncEpT
1995 XJ Cherokee
I get 10mpg winter.
Somewhat similar here.
I get between 8 and 10 in the winter and between 13 and 16 in the summer.
35's and 4.88's here.
95 XJ. Longarm'd, Geared and Locked on 35's
c0ncEpT is offline   Reply With Quote Quick reply to this message
Unread 02-18-2011, 04:52 PM   #25
Codeman91
I figured mine out today, and it was just over 14. I was a little surprised since the last time I calculated it last year it was over 18. But I do 95% city driving, to and from school.
White 2001 XJ: stock
White Jeep Club member #138
Codeman91 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 12:12 AM   #26
BravoTeam127
1995 XJ Cherokee
I thought that it didn't matter mpg if a wheel was steel or aluminum
BravoTeam127 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 07:50 AM   #27
Darkstardevil26
The only way it would make a difference is the weight. But I wouldn't think it would make too much of a difference, especially when most of us are running 31"-35" tires.
Out if my 3 xjs my 2 aw4 autos I averaged 19-22 70/30 highway/city. My 5 speed averaged 20-24 same ratio. Those were when they were all stock. My xj now on 4.5" lift 33" tires and 3.55s gets between 12-14 50/50 highway/city. When I take road trips I can pull about 16-17. All this mileage is hand calculated and over about 35k miles. And the mpg with 33" tires is corrected by hand also. I'm a but for logging on all my cars.
Sounds like you're a bit off, or just use the skinny pedal a bit much. Most of your mpg is determined by your driving habits. Since you just did your tune up, maybe your o2 sensor like you said.
-Jeremy
Darkstardevil26 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 08:25 AM   #28
Xride
I get maybe 12mpg. But I drive like I stole it and have a bad O2.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline   Reply With Quote Quick reply to this message
Unread 12-15-2013, 08:16 PM   #29
nolanbalzarini
nolanbalzarini's Avatar
i get 12. All of the time, no matter where or what im doing, but i do have; a winch on a bumper with lights, and a roof rack with spare tire, spare tire on a rear tire carier, rock sliders, 31 inch tires, 3.5 inch lift, and stock gearing.
nolanbalzarini is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 10:45 AM   #30
jeepkid03
Winning
jeepkid03's Avatar
That's not bad for stock gears and ethanol gas.
-Josh
My 0331 Head Swap How-To Thread:
http://www.jeepforum.com/forum/f11/0...hread-1371398/
Build Thread:
http://www.jeepforum.com/forum/f22/m...build-1119997/
jeepkid03 is offline   Reply With Quote Quick reply to this message
