what kind of material for headliner - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > what kind of material for headliner
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 03-28-2015, 03:35 PM   #1
escapeartist
What kind of material have you used for a replacement headliner? What would you different, were there any issues with the spray adhesive bleeding through? Thanks
escapeartist is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 03:43 PM   #2
escapeartist
Were sp? Mobile sucks.
Unread 03-28-2015, 04:55 PM   #3
Motorcharge
Bandeded
Motorcharge's Avatar
1991 MJ Comanche
I did black denim on one of my XJs and it looked awesome. Wish I had pictures.
Use CRC Headliner Adhesive (find a car dealer in your area that has it in their parts department) and coat the liner with a can and the board with another and let them setup for about 10 minutes before putting them together. Nothing should come through and it will be a lot easier to spread the replacement liner out properly.
Looks like this but make sure it's the headliner adhesive and not the regular spray adhesive.
Motorcharge is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 05:10 PM   #4
workwagon
Here's mine it's a construction material basically foil bubble wrap
workwagon is online now   Reply With Quote Quick reply to this message
Unread 03-28-2015, 05:12 PM   #5
workwagon
Originally Posted by workwagon View Post
here's mine it's a construction material basically foil bubble wrap
Unread 03-28-2015, 07:18 PM   #6
FairlanePhil
Mine isn't sagging but I keep thinking about doing something weird
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 11:20 PM   #7
escapeartist
Fairlanephil, I like the last pic, definitely different so long as it doesn't give you a headache when you get in.
The local fabric superstore had the OEM color with the foam backing so I just got that, les than $50.00 I don't figure I will own it when the foam rots.
Those who say it cannot be done should be quiet and not interrupt those whom are doing it.
Unread 03-29-2015, 12:50 PM   #8
escapeartist
Done.
Unread 03-29-2015, 02:41 PM   #9
Motorcharge
Bandeded
1991 MJ Comanche
Pics or gtfo.
Unread 03-30-2015, 10:37 AM   #10
XJ2Timer
Yes these were factory.
http://www.thehogring.com/2014/01/02...side-of-mopar/
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 04:52 PM   #11
SmashDN
I have headliner material and that bubble wrap waiting me to start the project. I was planning on putting the bubble stuff under the rigid board thingy in hopes of insulating from noise and temps somewhat.
Anyone had success thing what I'm thinking?
SmashDN is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 12:09 PM   #12
VegasGT
Rustler of Jimmies
VegasGT's Avatar
I need to redo mine, been really wanting to use a red flannel type material just for the **** of it.
- '99 XJ Sport -
Lifted, Locked, Stiffened
July '13 and '14 COTM
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 07:53 PM   #13
PaYankee
Look for the foam backed headliner fabric at Joanns.
Do not do black headliner. You can see every spec of dirt, hair, etc that gets stuck to the headliner.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is online now   Reply With Quote Quick reply to this message
Unread 04-14-2015, 10:03 PM   #14
Rum_Maximus
Anyone have thoughts pro/con on putting Monstaliner on the inside of the roof with the headliner installed over it?
I am thinking it would add a slight bit of insulation and a small amount of sound deadening.
I am Mattimus Rum Maximus, and I approve this message.
Rum_Maximus is offline   Reply With Quote Quick reply to this message
Unread 04-16-2015, 08:42 PM   #15
jeepjunkie97
I too am one for using foam backed cloth. Just use 3-4 cans of super 77, let the thing air dry over night in a place you're okay with smelling like glue, slap it back in. It was one of the first things I did and has held up for at least a year now
jeepjunkie97 is offline   Reply With Quote Quick reply to this message
