What jack to get? - JeepForum.com
post #1 of 6 Old 07-30-2008, 01:35 PM Thread Starter
SugarHigh
What jack to get?
I am buying a 94 XJ with 4" lift and 33" tires. The jack on the car is useless. What jack should I get. What is the best, and what is cost effective?
SugarHigh is offline
post #2 of 6 Old 07-30-2008, 02:43 PM
TombRaider940
Best is the hi-lift brand.
I have the 60 Xtreme. And can do many things. And if you wheel alot then is worth it.
They come in different sizes and options. Black, red, then silver.
Each color is different lift options. I think of what is made of and what it can do.
TombRaider940 is offline
post #3 of 6 Old 07-30-2008, 04:00 PM
2005X
my stock jack works with 5.5 lift and 36s?? i would use a hilift for tire changes, i have one, and yes i have used it to change tires, it was very scary
2005X is offline
post #4 of 6 Old 07-30-2008, 04:29 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
I have a Hi Lift that I never bring with me. The stock jack stays under the seat. As mentioned above, tire changin with a Hi Lift is not recommended unless you can put a block under the axle. I'm going to get one of these when funds allow:
http://www.arbusa.com/exhaust_jacks.php
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #5 of 6 Old 07-30-2008, 04:33 PM
winkosmosis
Is there any jack that is a good replacement for the stock one? Bottlejacks are heavy and don't go high
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #6 of 6 Old 07-30-2008, 04:36 PM
McWood
McWood's Avatar
HI-lifts are not recommendable unless you have a solid jack point (read:solid bumpers and sliders) and even then its not the best idea to change a tire with one as they can get kinda tipsy. I would look for a long travel bottle jack, the hydrolic kind not the screw kind, and keep a block to use as a base if you have to jack in the soft stuff (like a 2"x8"x12" or so)
Edit: Double piston design is what im talkin bout
nothing to see here.
McWood is offline
How high the jack and jack stand must have? rexlam XJ Cherokee Technical Forum 20 02-26-2010 10:59 AM
High Lift Jack (farmers Jack) Jacking points pocquet MJ Comanche Technical Forum 10 03-16-2009 09:16 PM
what floor jack and jack stands should i get for my XJ mattathayde XJ/MJ Cherokee Non-Technical Forum 12 11-08-2008 09:39 AM
jack shepdogwv XJ Cherokee Technical Forum 6 10-31-2007 04:34 AM
Do I need a new jack??? 00XJEric XJ Cherokee Technical Forum 5 03-24-2004 12:38 AM
