this is what i bought. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > this is what i bought.
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-04-2015, 01:01 PM   #1
jesse12801
I have driven it a grand total of about a block.Not on the road yet since it's summer and this is my winter blizzard vehicle...it's got a water leak somewhere around the windshield that I posted a thread on already,rusted out rockers and now it also has black paint spots on where the rust is to maybe slow it down....and son of gun..I already love the damn thing.
jesse12801 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 08:24 AM   #2
bluejunior
You're in for an adventure.
Best way to slow rust down is to wire brush the scale off, hit it with a tanic-acid based converter (there's a Jasco one in a white bottle/brown label you can get next to the paint thinner in Home Depot/Lowe's that I use) and paint over it.
The rockers can be replaced with welded tubing if you've got the ability. LOTS of threads on it here.
Best of luck!
"I just need to do a couple tweaks on my jeep, I'll be done in a couple hours." - gone 3 days
bluejunior is online now   Reply With Quote Quick reply to this message
Unread 06-15-2015, 08:53 AM   #3
shooptube
1997 XJ Cherokee
Okay for those rust spots here is an effective way to keep them at bay. Pick up this Navel Jelly. http://www.lowes.com/pd_117792-69-01...8&kpid=3339340
Take off that spray paint. Put some of this on there. The rust will turn black. Then paint over it.
Here is a very good write-up on the rock replacement.
http://www.jeepforum.com/forum/f177/.../index138.html
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 08:39 AM   #4
jesse12801
Thanks guys! I'll look into that rust stopping stuff. My mechanic is looking it over and doing so maintenance. There is a water leak somewhere I'll need to tackle after this.
Unread 06-17-2015, 09:42 PM   #5
jesse12801
Unread 06-17-2015, 10:54 PM   #6
FairlanePhil
moar pics
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 06-18-2015, 07:25 AM   #7
bluejunior
In my experience those are usually either a bad hose or a water pump going (there's a weep hole on the front to warn you the seal is going). Might be a place to start eyeballing if nothing else.
Unread 06-18-2015, 09:21 AM   #8
bobthecatkiller
He just said "water leak" so possibly not engine related.
If so I'd check the windsheild and rubber boots for the wires in the hatch.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline   Reply With Quote Quick reply to this message
Unread 06-19-2015, 08:38 AM   #9
jesse12801
Got the jeep back from the mechanic. The noise was the belt not tight enough. The leak is still there so having the windshield looked at tomorrow hopefully. Overall in pretty good shape despite rust. The jeep is loud as hell going down the road. Must be the tires. Looking for different ones for summer/ spring / fall driving. Keep the ones on there for winter.
Unread 06-24-2015, 09:07 PM   #10
jesse12801
new windshield going in Saturday.It's very "loose" as far as windshields go.New muffler tomorrow, front drive shaft Next week.
Unread 06-25-2015, 05:22 AM   #11
bobthecatkiller
It's not all that hard with a razor to cut out your old windshield, I suggest doing this or have the person putting it in cut it out and come back the next day to put the new one in, this gives you time to sand any rust away and give your windsheild frame a nice coat of paint. I used self etching primer then the windsheild guy used some black paint, he said it was to help the glue stuff adhere better. Three years later there's no rust or leaks.
Unread 06-25-2015, 09:38 AM   #12
jesse12801
Yea he said they wire brush the rust away and coat the vehicle with primer or whatever it is before putting the new one in.I don't have time for stuff like that.
Unread 06-25-2015, 09:57 AM   #13
bluejunior
Ummmmm.....You may have bought the wrong vehicle
Unread 06-26-2015, 06:53 AM   #14
S8NNG8
1995 XJ Cherokee
Ya, if the woman in your life doesn't accuse you of loving the Jeep more, you're not spending the right amount of time with the Jeep.
D3<!L!>3D
S8NNG8 is online now   Reply With Quote Quick reply to this message
Unread 06-26-2015, 07:48 AM   #15
bobthecatkiller
Exactly. If you ever get the ultimatum of "its the jeep or me" and you choose her, that's a problem.
