What the hell? Rustoleum paint - JeepForum.com
post #1 of 23 Old 06-13-2011, 05:29 PM Thread Starter
DerMeister
I have used Rustoleum semi-gloss enamel rattle can paint for several things now on my jeep.
I have used it on all four steel rims, the gas door, my front JCR bumper, and my hitch. All I sandblasted, cleaned, used self-etching primer and used 2-3 coats of the enamel. All have been very durable, better than I could have asked for.
Now I have used it on my rear bumper from JCR and did everything the exact same way. I can scratch it off with my fingernail, and if I hit it with something hard it basically doesn't stick to the primer and peels right off.
Anyone know why? Kind of pissed considering how much prep work I did on this.
DerMeister is offline
post #2 of 23 Old 06-13-2011, 06:03 PM
sirlasvegas
same brand etch? Sometimes certain paints wont get along with the primer you used. Was the surface fully cleaned, oil free etc? Shake the rattle can thoroughly? Prepped the surface area before priming?
MY XJ
sirlasvegas is offline
post #3 of 23 Old 06-13-2011, 06:24 PM Thread Starter
DerMeister
Yeah, it was Rustoleum self-etching primer. I sand blasted, washed with brake cleaner, then used a very little bit of dish soap in hot water and washed it down, then used just hot water for a final rinse. I let it dry, then primer, It appears that the paint doesn't want to stick to the primer. And yeah I made note to fully shake the cans and did so.
I am really bummed out as I thought this was going to be another great finish.
post #4 of 23 Old 06-13-2011, 07:20 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Did you let the primer cure before painting?
xjfever is offline
post #5 of 23 Old 06-13-2011, 07:46 PM
Boodyrider
Might just be a bad can.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #6 of 23 Old 06-13-2011, 07:48 PM
MagicNelson
Was it the "clean metal primer"?
MagicNelson is offline
post #7 of 23 Old 06-13-2011, 08:05 PM
MJ300
I seem to have this problem all the time with Rustoleum products. Sometimes no matter how much I prep it just doesn't stick or hold up worth a damn. The only Rustoleum paint I like is their Hammered line.
Krylon however, never lets me down. If I'm feeling lazy and don't want to prep too much or just don't care how it turns out....Krylon almost never fails. Doesn't care what brand of paint it sticks to or how well its prepared within reason. Krylon FTW!
2001 XJ (4.0AW4NP242D30D35) 3.5" RE lift, Treadwright MTR's, Rubicon wheels
MJ300 is offline
post #8 of 23 Old 06-13-2011, 10:15 PM
AoA
1997 XJ Cherokee
this is happening on my front jcr bumper, same primer and paint and sand methods
You'll fine me chasing the Sun!
97' XJ 7" of lift 33's - Still Running Strong
97' XJ 5" of lift 33's - Sold
93' ZJ 4"of lift, 31's - Totaled
AoA is offline
post #9 of 23 Old 06-13-2011, 10:57 PM
Wearingthin
did you apply the paint when the primer was still tacky? If you let the primer dry, you really need to rough it up before applying the paint
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #10 of 23 Old 06-13-2011, 11:29 PM
Brookhart63
Woah.... literally just happened to me... I'm switching paint brands
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #11 of 23 Old 06-14-2011, 05:42 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I've had nothing but trouble with Rustoluem products. Won't use 'em any more. The final straw was when I painted a tow-truck bed one night so I could put all the lights back in and go on a call the following morning. The paint was still tacky 14 hours after application. I was done then.
cruiser54 is offline
post #12 of 23 Old 06-14-2011, 08:20 AM
Brookhart63
That would be more than enough to upset me
Bought not Built
post #13 of 23 Old 06-14-2011, 12:19 PM
LimeLJ
LimeLJ's Avatar
Rustoleum only works well if:
1.) You have about 75F temperatures.
2.) Very low humidity.(Humid weather instantly screws it leaving the only option to scrap it all off.)
3.) Properly prepared surface.
4.) Follow the timing directions exactly.
It is finicky stuff.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #14 of 23 Old 06-14-2011, 02:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I have enough finicky crap in my life. I don't need paint to join the party.
post #15 of 23 Old 06-15-2011, 12:05 AM Thread Starter
DerMeister
Yea i didnt let the primer fully cure, followed the directions exactly. Looks like i am finding a new brand as well. The two week actual cure time isnt worth it anymore.
Pictures of Rustoleum painted XJs. sktr021 XJ/MJ Cherokee Non-Technical Forum 40 02-28-2011 04:07 PM
rustoleum rattle can bed liner? jackdup XJ Cherokee Technical Forum 24 08-20-2010 02:39 PM
Rustoleum Hammered WAKETEK516 XJ Cherokee Technical Forum 9 05-11-2006 11:43 AM
Rustoleum and Powdercoating white01XJ XJ Cherokee Technical Forum 6 01-02-2006 09:37 PM
Time to Paint! Need Advice..Bedliner...Rustoleum? MadDogXJ XJ Cherokee Technical Forum 3 04-27-2005 01:15 AM
