What to do with the TCase? - JeepForum.com
post #1 of 3 Old 06-08-2016, 10:44 PM Thread Starter
XJK
The Guru of Nothing
XJK's Avatar
Alrighty so I'm getting closer to the parts of my new build. Going with the RE 4.5 LA kit to get started.
Thinking about just pulling the trigger and going for an all together new TCase. What are you guys doing these days, taraflex? TJ Rubicon case?
Ideas? Keep in mind I don't have easy access to a welder so bolt on is preferable at this point.
XJK is offline
post #2 of 3 Old 06-09-2016, 09:45 AM
bluejunior
bluejunior's Avatar
Why the swap? Worried about strength? Power? Current one damaged?
Within reason the 231J is a pretty solid case and there are readily available 4:1 conversion kits and SYE's for it.
Lifted, Locked, Stiffened
bluejunior is online now
post #3 of 3 Old 06-09-2016, 10:11 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A new chain and some new shift fork tabs should all the other parts you need when you install your SYE. I say run it, and then figure out if you need something different.
CJ7-Tim is offline
