What to do to keep it going a while longer - JeepForum.com
post #1 of 5 Old 12-06-2011, 03:05 PM Thread Starter
marianl
So I have a 2001 Cherokee Sport 4wd, a little over 115,000 miles (it is raining & I'm too lazy to walk downstairs to check the exact mileage). I bought it from a dealer in 2004 with 45,000 miles, in order to be able to negotiate, among other things, my unpaved half-mile western Mass. driveway before the snowplow came. I never thought it would become part of my identity, but it has, and even though I've no real need for it here in Georgia, I would love to keep it going as long as possible.
It has had no serious problems other than needing every single mechanical part of the AC replaced. It has had regular oil changes & I've taken a responsible approach to other preventive maintenance matters. BAck at 50,500 miles the dealer said they found loose ball joints, but I elected not to fix and no one's mentioned them since. It has a new fuel pump (apparently rodents ate the wiring, no hilbilly jokes please). Of course, the CEL comes on at the drop of a hat. At one point the dealer suspected a blown head gasket, but a tune up & cleaning the throttle body kept it off for 6 months & there were none of the typical symptoms, just misfiring cylinders 2 & 3. The CEL came on again over Thanksgiving after a rough idle at restart in the midst of a long road trip, and after doing some reading, I'm suspecting that this most recent incident could be that "heat soak" problem described in TSB 1803103 (I haven't had the codes read yet, but this is something it has done a time or two before).
But here's my question.
Tomorrow I'm going to the mechanic (I've decided to abandon the dealer, who just keeps trying to interest me in a new car) and assuming that I don't have something hideously wrong, I want to have them look at everything that possibly could be an issue with this particular vehicle. So give me your best advice on how to keep my dear Cherokee on the road and feeling secure a little while longer.
Thanks!
marianl is offline
post #2 of 5 Old 12-06-2011, 03:13 PM
Corcor4
1990 XJ Cherokee
Replace the 0331 head casting... the problem of it cracking is a little over played on the internet but from what i've read if you get unlucky enough for it to crack, its not a fun one to fix. I have the 0331 head casting and 180k miles so far.. Have them check steering components, u joints, etc. Check control arm bushings. Check the evap canister..
My second try: 1990 Jeep Cherokee Xj 6.5ish" lift with tj componets, 33" duratrac's, oversized roof rack, onboard air, body armor.
-OREGON JEEP OWNERS, NORTH WEST CREEPING JEEPERS
18 years old and lots to learn :D
Corcor4 is offline
post #3 of 5 Old 12-07-2011, 08:27 AM
Oregon187
Your smartest move so far was abandoning the Stealership. At 115,000 miles it is just getting broken in. As for the misfiring on 2 and 3, my '01 does it after restart all the time. Like you said, that is most likely the "heat soak" fuel injector issue. Make sure to keep an eye on the Anti-freeze level and the color of your oil. If the Anti-freeze starts to disappear and it's not on the ground, or if the oil looks like chocolate milk, then you will need to have the head looked at. A mechanic should be able to pull the valve cover and see if there is a crack.
Above all, just love it and it will last for a long time. And stay away from stealerships.
2001 XJ build thread --
Oregon187 is offline
post #4 of 5 Old 12-07-2011, 08:35 AM
robman8
often times jeep owners find that if you mod the piss out of it, then most of the weaker oem parts are replaced.....lol sounds like you've done the right thing so far staying away from the stealership
robman8 is offline
post #5 of 5 Old 12-07-2011, 11:09 AM
rsurran
Replace the CPS. About 120k is what I've seen posted as an estimate of life span for the OEM part.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
advice , heat soak , recommendations
Longer tie rod end Jeepxj5209 XJ Cherokee Technical Forum 3 05-10-2011 11:34 AM
Do I need longer shocks? Khary23 XJ Cherokee Technical Forum 8 11-01-2009 02:50 PM
SYE or longer driveshaft StrangeHighways XJ Cherokee Technical Forum 2 08-08-2009 06:50 PM
Ok? to run longer than 3,000 Miles???? 94HOCHEROKEE XJ Cherokee Technical Forum 27 07-27-2009 05:52 PM
How much longer... Goonowsky XJ Cherokee Technical Forum 3 10-14-2004 04:32 PM
