What to do with a 95 two door jeep Cherokee sport - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Non-Technical Forum > What to do with a 95 two door jeep Cherokee sport
THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaSavvy Billet LED Tail LightsCurrie
Unread 09-24-2014, 01:52 PM   #1
rwest394
1995 XJ Cherokee
I have a jeep cherokee sport and want to put a lift on it, but i'm not sure what would be the best. preferred 4.5" lift, any suggestions?
rwest394 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 06:18 PM   #2
sAe23
1995 XJ Cherokee
First off, what kind of off roading do you do, and what size tires are you planning on running under the lift?
At 4.5" you'll likely need lots of additional hardware that you MIGHT not need at 3".
Here is a good selection of kits to look at:
http://www.jeep4x4center.com/jeep-li...e-xj/index.htm
You should also consider starting with a shackle relocation bracket / extended shackle for the rear.
One of these kits is easy to install but can add up to two inches to your lift.
Another kit doesn't add to the lift, but it requires cutting away the factory shackle pocket, and possibly welding.
If you do ANY kind of off roading you should start with tow points and skids (trans and or engine).
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 06:13 AM   #3
S8NNG8
1995 XJ Cherokee
I'd definitely recommend doing the fullest kit. Upper and lower control arms should be replaced for proper function and don't waste the money on any add-a-leaf or blocks. Another option with fair prices is Rustysoffroad.
D3<!L!>3D
S8NNG8 is offline   Reply With Quote Quick reply to this message
