What is with the cost of motors for 00-01 - JeepForum.com
post #1 of 30 Old 04-21-2012, 09:16 PM Thread Starter
gunsworth
gunsworth's Avatar
What is with the cost of motors for 00-01 (pics added)
So aggrivating, a piston shot out the bottom of our 00 xj and cant find a motor for less than $1000, and most of those have 150k+ WTF? only reason I bought it was because I thought these motors were a dime a dozen, picked the wrong year i guess. any tips? Crazy part is that I pulled the valve cover to check the head and no cracks. how does a piston just shoot through the oil pan in golfball sized peices?
"Two roads diverged in a wood and I - I took the one less traveled by, and that has made all the difference. "
94 2.5L 5spd with some stuff
gunsworth is offline
post #2 of 30 Old 04-21-2012, 09:28 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any 1991-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee engine block will fit and work in your 00 XJ. Simply re-use the 0331 head, intake/exhaust manifold, flywheel, belt driven accessories, and other sensor/parts as required. Have your 0331 head tested and inspected for cracks.
CJ7-Tim is offline
post #3 of 30 Old 04-21-2012, 09:49 PM Thread Starter
gunsworth
gunsworth's Avatar
I am starting with pulling the head (I need to bring the one from my yj in anyways, head gasket started leaking a week after this happened, so 2 dead jeeps in the drive right now lol)
but I figure with the piston grenading, the head is gonna be jacked up underneath...
post #4 of 30 Old 04-21-2012, 10:42 PM
Motorcharge
Only 99+ (if I remember correctly) XJ 4.0's are direct bolt ins. Like Tim said though, anything fron a 91+ will work but it will take a bit more effort than just bolting in. Given that yours is a 2000 you still need to swap over compatible ECU's and sensors.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 30 Old 04-21-2012, 10:55 PM
lsmurphy
Look for a rust-bucket donor for $1000.......one with a bad trans or what have you........rape for good parts then scrap it for $450.
That's how smart folks do it.
lsmurphy is offline
post #6 of 30 Old 04-21-2012, 11:00 PM
lsmurphy
I just perused CL in MI for a few minutes........ http://southbend.craigslist.org/cto/2957583367.html
You folks are proud of your **** up there huh?
lsmurphy is offline
post #7 of 30 Old 04-22-2012, 06:11 AM Thread Starter
gunsworth
gunsworth's Avatar
I have been searching crazedlist for all the cities wthin 4hours of me for 3 weeks now and have yet to find one under 1000 with less than 140k. I check vehicles too, missed a 99 with 100k and blow trans for 700 by an hour.
The one you linked, is a wj, wont even come close to dropping in. I am gonna give it another week before I give up
post #8 of 30 Old 04-22-2012, 08:50 AM
lsmurphy
Yeah I know what I posted....just an example. But that can be found round here for $1200 every day of the week in good running condition and not wrecked. For some reason the Grands are undesirable........understandably so.
lsmurphy is offline
post #9 of 30 Old 04-22-2012, 09:42 AM
CJ7-Tim
CJ7-Tim's Avatar
Try www.car-part.com. Change the model year a few times to get more donors.
CJ7-Tim is offline
post #10 of 30 Old 04-22-2012, 11:09 AM Thread Starter
gunsworth
gunsworth's Avatar
seem to be just as expensive as the others, there is one for 1000$ with 112k nearby so might just go with that if i cant find another by weeks end. thanks, i had checked there when i first started looking, but wrote em off because i couldnt believe these engines could cost so much, now reality has sunk in....
post #11 of 30 Old 04-22-2012, 11:22 AM Thread Starter
gunsworth
gunsworth's Avatar
well **** balls ***, just found one on cl for 600$ with only 101k picking it up tomorrow, gonna take the trans as well, ours was hesitating and he only wants 250$ for it
post #12 of 30 Old 04-22-2012, 11:57 AM
jeepkid03
Winning
jeepkid03's Avatar
hahaha the guy in that ad is an idiot. The rear hatch on a WJ (probably dented) isn't worth $1400.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #13 of 30 Old 04-22-2012, 12:47 PM Thread Starter
gunsworth
gunsworth's Avatar
Haha, my favorite was the guy found who had a 4.0 for only 900, I emailed him and found it had 220k on it, I wished him luck lol
post #14 of 30 Old 04-23-2012, 02:51 AM
XJ-JekL
1995 XJ Cherokee
I'm going to not RTFT and just comment on the OP here.
Three main reasons of engine failure;
1. Overheating
2. Lack of lubrication
3. Ingesting dirt
If there is no damage to the block, and you know what you're doing, a rebuild is in order here.
XJ-JekL is offline
post #15 of 30 Old 04-27-2012, 09:44 PM Thread Starter
gunsworth
gunsworth's Avatar
well the 600$ motor turned out to be older and ****ty looking (after driving an hour to get it, passed and turned back home)
found this one for 700$ with "80k" looked good and bought it (grabbed a oil pan gasket, valve cover gasket, water pump, rear main seal, front main...)
got it home and pulled the oild pan, and it is clear it had a rebuild from the markings inside and hatch marrks from the pistone walls being honed. there was also some cat head stamped on the head along with a plug stamped "weller". guy had only had the jeep a few months before he totalled it and the odometer had around 80k. so it had a recent rebuild and all is good right now, just sucks that the head is still the 0331 but we will just make sure not to over heat and hope for the best
below you will see the old vs new used motor
Help with my window motors maybe? Joshharris98xj XJ/MJ Cherokee Non-Technical Forum 5 05-09-2011 12:56 AM
are these 4.0 motors the same? hwnmike XJ Cherokee Technical Forum 6 03-03-2009 12:15 AM
what motors came in an 86 cherokee platinumjeep XJ Cherokee Technical Forum 3 04-10-2007 12:51 PM
Anyone with remanufatured motors lbsnowryder XJ Cherokee Technical Forum 10 02-23-2007 05:38 PM
Window Motors Jeepin_XJ_101 XJ Cherokee Technical Forum 2 01-21-2005 10:42 AM
