what can i do about the rust on my Rocker Panels - JeepForum.com
post #1 of 8 Old 07-25-2008, 05:47 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
i have a lot of rust on my rocker panels back buy the rear tire what is a easy why to get rid of it.should i just replace it or can i buy somthung that can go there
burnsandrew62 is offline
post #2 of 8 Old 07-25-2008, 06:34 PM
aircruiser
aircruiser's Avatar
is it rusted through or surface rust? if you like a black two tone, you can do like i did and sand it off and herculine over it.
just make sure to sand it all off so it doesnt come back.
aircruiser is offline
post #3 of 8 Old 07-25-2008, 06:46 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
it is rusted all the why through pritty bad. i was just going to leave it because it is a trail truck but i would like to fix it
post #4 of 8 Old 07-25-2008, 06:59 PM
aircruiser
aircruiser's Avatar
well, you can do it the right way or just cover it up. ive got a small rust hole behind the rear drivers side tire in the wheel well. my plan is to cut out a square around it, get all the junk thats gotten in there from muddin, bend up a pieces of steel and get it welded in..then paint over it to prevent rust from coming back. other way would be to sand it and put some bondo or fiberglass filler over it. but the rust will just end up coming back.
post #5 of 8 Old 07-25-2008, 07:23 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
i might just do the fiberglass because i do alot of trail riding.if i spend alot of time fixing it most likely i will mess it up by hitting somthing . i'v also got the little hole right over my rear tire it's net big yet. think for helping me
post #6 of 8 Old 07-25-2008, 07:24 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
what is the red jeep club because my jeep is red to
post #7 of 8 Old 07-25-2008, 08:21 PM
aircruiser
aircruiser's Avatar
ive got a friend who works with auto body stuff so thats where i get all my info from. im gonna do the cut and re-weld repair on my jeep just because the area that is rusting sees alot of crap and junk that could easily get a rust hole re-started.
as for the red jeep club, just something to put in your sig. heres the thread
http://www.jeepforum.com/forum/f11/removing-97-doors-power-write-up-408138/
post #8 of 8 Old 07-26-2008, 11:46 AM
lilacsl2
OhDoyleRules
lilacsl2's Avatar
cut out the rockers weld in square tube, rocksliders and rockers combined.
search in the xj tech for erics write up on his, you can get a general idea and go from there, he cut his higher for better clearance not for rust but it is probably the best way to replace rockers in my opinion
2013 JK 4-door Sahara in Dune, stock for now
2010 JK 4-door Black, bead locks, 37's, 5.13's, mopar front bumper, warn rear bumper
1998 Cherokee, 33's. 4.56 gears, locked front and rear
2007 Dodge 1500 Laramie, Hemi, 20's, 33's, all the goodies.
lilacsl2 is offline
Rocker panels pintail131 XJ Cherokee Technical Forum 1 12-04-2009 06:40 PM
Rocker panels tommysly XJ Cherokee Technical Forum 2 07-19-2007 09:56 PM
XJ Rocker Panels mpro1 XJ Cherokee Technical Forum 2 07-12-2005 12:53 AM
rocker panels ilovjeep XJ Cherokee Technical Forum 11 08-30-2004 10:01 AM
rocker panels airbornexj XJ Cherokee Technical Forum 0 08-22-2004 06:19 PM
