what is the best size tire with a 2 inch lift - JeepForum.com
post #1 of 8 Old 07-26-2008, 05:09 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
what will the best size tire to run with a 2 inch lift and what kind of tire
burnsandrew62 is offline
post #2 of 8 Old 07-26-2008, 05:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Probably 30x9.50's, if you don't want to trim. with a small amount of trimming and proper bumpstopping you could run 31x10.50's. and bf goodrich at's FTW.
xjfever is offline
post #3 of 8 Old 07-26-2008, 07:17 PM
winkosmosis
I'm going to use 31x10.5 with mine. I was going to remove the flares... But xjfever do you mean a small amount of trimming of the flare or sheetmetal? I've seen some XJs with a little bit of the flares and the bumper endcap trimmed-- is that all you need to do to fit 31"?
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #4 of 8 Old 07-26-2008, 08:31 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You should be able to get by with removing the flares and trimming the end caps. If you use the factory wheels you will rub the control arms at full lock, but you can fix that by adjusting your steering stops. If you are planning on wheeling it you will need to extend the bumpstops, even with removing the flares you will rub when flexed, if you don't bumpstop correctly.
xjfever is offline
post #5 of 8 Old 07-26-2008, 09:01 PM Thread Starter
burnsandrew62
1993 XJ Cherokee
yea i don't mined triming. how many inches do i need to cut out
post #6 of 8 Old 07-30-2008, 12:26 PM
justinwalden
http://www.jeepforum.com/forum/f177/what-size-tires-poll-572038/
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline
post #7 of 8 Old 07-30-2008, 12:41 PM
winkosmosis
I forgot about your thread, otherwise I wouldn't have posted mine about 31" tires
post #8 of 8 Old 07-30-2008, 12:48 PM
justinwalden
oh well thats what we pay for
3 inch Lift and Tire Size SmittysXJ XJ Cherokee Technical Forum 10 05-29-2011 11:48 AM
Tire size question on 15 inch rim MoparBoy01 XJ Cherokee Technical Forum 10 04-20-2009 10:56 AM
good tire size for a 3 inch lift MxAjN XJ Cherokee Technical Forum 37 01-22-2009 09:46 PM
5 inch lift, tire size choice? Delox XJ Cherokee Technical Forum 13 01-13-2009 08:09 AM
3 inch lift. tire size? usarmy0101 XJ Cherokee Technical Forum 14 03-20-2008 10:21 AM
