#1 | |
Platinum Member
What axles should I go with?
I am thinking of pulling the trigger on a set of axles for my xj but I want to get some ideas from some of you. Keep in mind Im not spending $10k on a set of axles. I need to regear at the very least and I figure if Im going to do it I might as well do it all.
Here is what I am thinking, g2's dana 44's front and rear with 5.13 gears and a arb in the front and the detroit in the rear. Add disc brakes to the rear along with a few other odds and ends and it comes to about $5500. Lets hear it, what do you think I should do?
DURTYROK CAROLINA OFFROAD
#2 |
you could spend a lot less on that same set up without the name brand. you could set yourself up with dana 60s with ARBs and 5.13s for less than that....IMO if you are loking to save money, there is no reason to spend that kind of money. THe only time i would spend money like that on axles if i was building a buggy or something, which would include some sort of bad *** 9 inch like a ballistic or spider9.
Thats just my opinion. The good thing about that, however, is you know that you will be getting a good (and set up properly) axle. It also depends on what size tires you want to run. If you want to run 37s, go with dana 60s. If you want to run 35s, run a 60 rear (or even a little smaller 8.8) and a 44 front.
97 XJ. 4.0/5speed/NP231/4.10 gears. D30 open/8.8 spooled. 4.5" lift. RC Long arms, 35" Kevlars, Fox 2.0 Resi, Ruff Stuff, lots of armor, 1 ton, etc etc 97 TJ massive 2.5L engine. 5 speed. cherokee springs up front, skyjacker 7000, 31" BFG mall crawlers. |
#3 |
Under Construction
HP44/9", I was able to get my HP44 for about $150, going to spend another $80 for a 9" from the JY. BTF truss the front with some brackets from Ballistic, and UBE kit from TNT for the 9". Keep in mind a 9" may be a pricey build compared to a 8.8, 60, 14b, by the time you get 35 spline shafts, nodular 3rd, etc., but it's going to be Way lighter weight than either of the one ton axles, and if you shave it, more ground clearance than a D35. Best of all it is extremely easy to work on, change configurations, and can be built in stages.
#4 |
Platinum Member
Thanks for the input guys. Im not going any bigger than 35's on the xj. I thought about the 9" and 60 rears but once you build it like the g2 44's you are over the cost of the 44's. Im kinda going for bolt in axles right now. It would be different if I knew how to set gears but I havent learned yet. I have 2 d30's and 2 8.25's and plan on selling 3 and keep one to learn on. When I get another tj I plan to build axles for it.
#5 |
Not going over 35's? Stick with stock axles and build them up.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored 2012 Subaru WRX Limited |
#6 |
Platinum Member
If you know how to fit 5.13's in a 8.25 come on over and show me.
#7 |
Platinum Member
After trying to decide what axles to get I went with the 44's. Cost of the axles and the fact that I dont have to do any driveshaft mods or pay to have them put together is what sold me. Also the fact that 35's are too small for 60's. When I called 4wd to ask some questions the guy said he could give me a deal on them. I figured he was going to give me 1-2 hundred off but it ended up being $650 off the already discounted price i was getting and I dont have to pay shipping because I have a 4wheelparts 18 miles from me and they are shipping them there. I cant wait to get rid of the 3.55's and drive it with 5.13!
#8 |
Rockwells.....hands down
#9 |
I was just wondering why you needed the 5.13's with 35's? It would have been alot cheaper to run 4.88's in the stock axles, with chromoly shafts, then if you still needed to go lower you could have added a teralow 4:1 kit to a 231 transfercase. That would have gotten you a much lower low range and better highway rpm's...That said I'm envious of anyone who can convince their wife they $5500 axles lol
http://jeep4playoffroad.org/index.php --your local oregon coast club |
#10 |
forum supporter
I agree that 4:88's should have been plenty of gearing for 35's and the AW4. But it should be fun to drive around town with the 5:13's.
#11 |
XJ on 37's
Used set of Rubicon JK 44's already geared from the likes of JKOwners.com - The community for Jeep JK Owners classifieds section. I have seen some killer deals on there.... I know my JK axles are holding up great with a set of chromo shafts and CTM u joints I scored a good ($600 shipped) deal on.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#12 | |
Platinum Member
#13 | |
Platinum Member
#14 |
The Post man
The thing I don't like about the G2's IIRC, was the fact they keep the Dana 30 knuckles and ball joints (correct me if I'm wrong).
Any axle gets fairly expensive to build when you start adding all the extras. And there's nothing wrong with spending the money if you have it.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#15 | ||
And add me to the wishing he had gone with 5.13s on 35 group. ![]()
Boatsides/Hybrid Cage/Tube Dash== Custom Winch Bumper== Bolt in HP44 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
