What alternators are you guys using? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Non-Technical Forum > What alternators are you guys using?
Rough Country Lift Kits and Parts!Father's Day & Moving Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-20-2012, 10:54 PM   #1
fourlow
1994 XJ Cherokee
So the OEM alternator in my 94 XJ is on its last legs and its time to replace it. Not a bad run to be honest.
What are you guys running in your XJ's, and what do you suggest? I'd love to get a Mean-Green but i really dont want to spend that much on an alternator, and I also don't want to be a piece of crap.
Im not running a winch, I will be running lights in the future, and most of my wheeling involves water crossings.
Current setup:
94 Xj 110,000 miles
Rustys Air Tube
JeepersandCreepers Bored out TB
GDI 3 core radiator
Flowkooler Water Pump
Suspension:
RE 3.5" (actual about 4 inches) 6030 SUPER-FLEX, RE1600 Adjustable Track Bar
Wheels/Tires:
Rock Crawler 152 Series, 3.75 Backspacing
31inch BFG MT's
fourlow is offline   Reply With Quote
Unread 06-21-2012, 07:28 AM   #2
slickfreeze
Thats what she said
slickfreeze's Avatar
1995 XJ Cherokee
I gave in and bought the mean green. What a pain in the A** to install. I had to take the bolts off the motor mount and jack to motor up for it to squeez in.(even after romoving the battery and tray) Then it was too big and hit the mounting bracket. so I had to pull it back out and try to fit a grinder down there to take the bracket down. It took about 4 hrs to get it installed
________oooo
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|[]lllll[]|
_\_/==== |; _\\ \\
_(o)_)___(o)_)--o-)_)
"ask not what your country can do for you; ask what you can do for your country." John F. Kennedy
Cherokee Of The Month August 2012
slickfreeze is offline   Reply With Quote
Unread 06-21-2012, 12:16 PM   #3
fourlow
1994 XJ Cherokee
I reeeealy dont want to spend that much money right now, but I cant really find an alternative. Apparently they dont make Load Bosses for my year.
Current setup:
94 Xj 110,000 miles
Rustys Air Tube
GDI 3 core radiator
Suspension:
Wheels/Tires:
31inch BFG MT's
Unread 06-21-2012, 01:22 PM   #4
whitexj98
Stock alternator will be fine for a couple lights wired corretley. I don't know if its the same for a 94, but on my 98 I replaced the toasted stock alternator with one from a grand cherokee, I think it was like 120 amp output or somthing, required grinding the bracket to fit but everything "pluged in".
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline   Reply With Quote
Unread 06-21-2012, 04:25 PM   #5
CamdogXIII
1997 XJ Cherokee
There's a way to get a 5.9 Durango alt to fit (just some grinding apparently). Puts out 160 amps or so. It may have only come on a certain package
CamdogXIII is offline   Reply With Quote
