Weeder1's xj build - Page 39 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ/MJ Cherokee Non-Technical Forum > Weeder1's xj build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 05-13-2013, 09:49 AM   #571
Project1
I know you have seen his rig ... But just look through his thread again ... It's a sweet setup .... And you could do it pretty cheap and beefy ... Get some parts from blastic fab ..... And genright sells long arm tube cheap. Something worth thinking about. I decided I want to run coil overs from maybe blatic.
http://www.jeepforum.com/forum/f177/...5/index38.html
Project1 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 10:12 AM   #572
Project1
SFR has one of the nicest rig on here for sure ....preformance wise maybe the best. This is what he's running. I just like to drive faster too, and for my driving style, coilsovers will fit me better .... And for stability.... Coils and long arms are not less stable ...that's more of a misconception. Talk to nick(SFR) about them. He's a super cool guy and he build jeeps as his main job. He's a pro, and he ill point you in the right direction.
Unread 05-13-2013, 06:36 PM   #573
Weeder1
I think im gonna keep the leafs for now man. Later down the road id like to do the coil conv but when i do it a 3 link and 44s will go in. Lol
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 06:51 PM   #574
Project1
I'm doing the same my self .... For now
Unread 05-14-2013, 11:23 AM   #575
ibjeepin95
Just curious, why would you waste money on coilovers for stock axles? And it's only a misconception if a coil setup is done right. I've seen a lot of sh!tty 4 link rear setups in XJ's...
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2013, 11:51 AM   #576
Weeder1
Ding ding. Its not as easy as to just put it in. I have a vert seperation that i want front and rear when and if i do coils out back. I will build a three link one day though. But right now its fine for me.
-98 xj sport-
Unread 05-14-2013, 03:34 PM   #577
Project1
$$ wise ... If you didn't have the money to do coils an axle swap at the same time..... Do the coils first and the axle later, on the axle side you just have the brackets which is not too bad .....
Plus .... If I gave him front and rear coils, and the upper genright mounts for 100$ .... He could fab some long arms and get rear mounts .... Use and old factory track bar .... And ended up with rear coil long arm set up for around 500ish
Unread 05-15-2013, 10:31 AM   #578
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
For anyone who isn't going over 35s ever, c8.25 and HP30 is fine?
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 05-15-2013, 10:44 AM   #579
Weeder1
All day long
-98 xj sport-
Unread 05-15-2013, 11:02 AM   #580
ibjeepin95
I guess. But other than going fast, I wouldn't spend that kind of coin on coilovers for junk axles to crawl with...
Unread 05-15-2013, 11:03 AM   #581
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
The difference between you crawler guys and everyone else is amazing sometimes.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 05-15-2013, 11:05 AM   #582
ibjeepin95
Not sure what you mean by that. I like going fast too. Coil overs would be the last thing I'd worry about if I was building a go fast XJ on stock axles.
Unread 05-15-2013, 11:26 AM   #583
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Oh yeah it definitely wouldn't be the #1 mod, but I would surely consider it down the line.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
Unread 05-15-2013, 03:00 PM   #584
Project1
I totally agree with you .... It's just a money thing that's all .... I'm just building on a budget so it's like 1 piece at a time, so I have to choose them carefully.
I decided I would rather have coilsovers front and rear vs coils. But I already have the coil set up just sitting around from another jeep I had .... So that we're this all came from. But I see what your saying ....
I hope my xj sees some dana 60's and some 37s some day ..... But first I'm going to cage and frame (hopefully this summer) ..... Then long arm and coilover... Then axles, steering, and tires last ... I would do it all in one shot if I had 10k to through at the jeep
Unread 05-17-2013, 10:44 AM   #585
Weeder1
3/4" spacers came in yesterday. Gonna try to get them on and adjust my tb and lowers this weekend.
-98 xj sport-
