Weeder1's xj build - Page 39 - JeepForum.com
post #571 of 752 Old 05-13-2013, 09:49 AM
Project1
I know you have seen his rig ... But just look through his thread again ... It's a sweet setup .... And you could do it pretty cheap and beefy ... Get some parts from blastic fab ..... And genright sells long arm tube cheap. Something worth thinking about. I decided I want to run coil overs from maybe blatic.
http://www.jeepforum.com/forum/f177/...5/index38.html
Project1 is offline
post #572 of 752 Old 05-13-2013, 10:12 AM
Project1
SFR has one of the nicest rig on here for sure ....preformance wise maybe the best. This is what he's running. I just like to drive faster too, and for my driving style, coilsovers will fit me better .... And for stability.... Coils and long arms are not less stable ...that's more of a misconception. Talk to nick(SFR) about them. He's a super cool guy and he build jeeps as his main job. He's a pro, and he ill point you in the right direction.
Project1 is offline
post #573 of 752 Old 05-13-2013, 06:36 PM Thread Starter
Weeder1
I think im gonna keep the leafs for now man. Later down the road id like to do the coil conv but when i do it a 3 link and 44s will go in. Lol
-98 xj sport-
http://www.jeepforum.com/forum/f177/weeder1s-xj-build-1391067
Weeder1 is offline
post #574 of 752 Old 05-13-2013, 06:51 PM
Project1
I'm doing the same my self .... For now
Project1 is offline
post #575 of 752 Old 05-14-2013, 11:23 AM
ibjeepin95
Just curious, why would you waste money on coilovers for stock axles? And it's only a misconception if a coil setup is done right. I've seen a lot of sh!tty 4 link rear setups in XJ's...
ibjeepin95 is offline
post #576 of 752 Old 05-14-2013, 11:51 AM Thread Starter
Weeder1
Ding ding. Its not as easy as to just put it in. I have a vert seperation that i want front and rear when and if i do coils out back. I will build a three link one day though. But right now its fine for me.
-98 xj sport-
Weeder1 is offline
post #577 of 752 Old 05-14-2013, 03:34 PM
Project1
$$ wise ... If you didn't have the money to do coils an axle swap at the same time..... Do the coils first and the axle later, on the axle side you just have the brackets which is not too bad .....
Plus .... If I gave him front and rear coils, and the upper genright mounts for 100$ .... He could fab some long arms and get rear mounts .... Use and old factory track bar .... And ended up with rear coil long arm set up for around 500ish
Project1 is offline
post #578 of 752 Old 05-15-2013, 10:31 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
For anyone who isn't going over 35s ever, c8.25 and HP30 is fine?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #579 of 752 Old 05-15-2013, 10:44 AM Thread Starter
Weeder1
All day long
-98 xj sport-
Weeder1 is offline
post #580 of 752 Old 05-15-2013, 11:02 AM
ibjeepin95
I guess. But other than going fast, I wouldn't spend that kind of coin on coilovers for junk axles to crawl with...
post #581 of 752 Old 05-15-2013, 11:03 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
The difference between you crawler guys and everyone else is amazing sometimes.
Previous:
DNFJ is offline
post #582 of 752 Old 05-15-2013, 11:05 AM
ibjeepin95
Not sure what you mean by that. I like going fast too. Coil overs would be the last thing I'd worry about if I was building a go fast XJ on stock axles.
post #583 of 752 Old 05-15-2013, 11:26 AM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Oh yeah it definitely wouldn't be the #1 mod, but I would surely consider it down the line.
Previous:
DNFJ is offline
post #584 of 752 Old 05-15-2013, 03:00 PM
Project1
I totally agree with you .... It's just a money thing that's all .... I'm just building on a budget so it's like 1 piece at a time, so I have to choose them carefully.
I decided I would rather have coilsovers front and rear vs coils. But I already have the coil set up just sitting around from another jeep I had .... So that we're this all came from. But I see what your saying ....
I hope my xj sees some dana 60's and some 37s some day ..... But first I'm going to cage and frame (hopefully this summer) ..... Then long arm and coilover... Then axles, steering, and tires last ... I would do it all in one shot if I had 10k to through at the jeep
Project1 is offline
post #585 of 752 Old 05-17-2013, 10:44 AM Thread Starter
Weeder1
3/4" spacers came in yesterday. Gonna try to get them on and adjust my tb and lowers this weekend.
-98 xj sport-
Weeder1 is offline
The Trev-Rock Build....noobie build.. Trev-Rock XJ/MJ Cherokee Non-Technical Forum 1 03-20-2012 02:50 PM
Best xj for a build overlandchris XJ/MJ Cherokee Non-Technical Forum 29 07-16-2011 10:05 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
86 MJ build 92XJCowboy XJ/MJ Cherokee Non-Technical Forum 3 01-17-2010 01:54 PM
I need your opinions. Build the one I have or buy a newer one to build up. Element96x XJ/MJ Cherokee Non-Technical Forum 5 02-13-2009 04:52 PM
